SPACE Low Knob is Creeping
Home Forums Products Stompboxes SPACE Low Knob is Creeping
Viewing 5 reply threads
    • #113936
      Jonnyangle
      The Low knob on my Space starts creeping all by itself.  Watch in the video below.
      This is super annoying.  I did the reset and that did not fix the problem.  Any other suggestions?
    • #145401
      gkellum
      Do you have an expression pedal plugged into the Space or MIDI?  Could it be that it's creeping due to external control?  If that's the problem, you could just unmap this knob from the expression pedal mapping.
      • #145402
        Jonnyangle
        gkellum wrote:
        Do you have an expression pedal plugged into the Space or MIDI?  Could it be that it’s creeping due to external control?  If that’s the problem, you could just unmap this knob from the expression pedal mapping.
        I am not using any expression or midi controllers.  Just the space…. super boring
    • #145403
      Jonnyangle
      It sounds like this is the same as other people’s pedal “freak outs”
      I’ll take the bottom off, check the ribbon connection and clean it.
    • #145404
      Judging by your video, there's probably nothing wrong with your Space – it is sitting at about 49.5, and circuit noise is making it flicker between 49 and 50 – this is mainly a display effect and can probably be ignored. You may find it distracting, however.
      If you move the knob to other positions, does it still happen ? If it happens on all values, it may be a dirty pot or a fault in the circuit that reads the pot. I don't think it is the ribbon, but if you can fix it, well and good.
      • #145407
        Jonnyangle
        nickrose wrote:
        Judging by your video, there’s probably nothing wrong with your Space – it is sitting at about 49.5, and circuit noise is making it flicker between 49 and 50 – this is mainly a display effect and can probably be ignored. You may find it distracting, however.
        If you move the knob to other positions, does it still happen ? If it happens on all values, it may be a dirty pot or a fault in the circuit that reads the pot. I don’t think it is the ribbon, but if you can fix it, well and good.
        It does it regardless of where the pot is.  I sprayed some contact cleaner in the pot and that did not fix it.  HOWEVER, I noticed in the sheilding tape (on the top PCB) there was an indentation from one of the legs of the “low” encoder.  It was not punctured through, but there was definately enough pressure to put a bump in the shielding piece.  I cut a 1/2″ x 1/2″ piece of electrical tape and put it over the soldered legs.  I’ll have to see if that fixed it this evening.
    • #145408
      DGillespie
      Engaging catchup mode is also a workaround if this is bothering you.
    • #145431
      Jonnyangle
      I’m going to call this fixed with the electrical tape barrier between the pcb and the sheilding.  While it was apart, I painted the aluminum as well!
      • #145432
        gkellum
        JonnyAngle wrote:
        I'm going to call this fixed with the electrical tape barrier between the pcb and the sheilding.  While it was apart, I painted the aluminum as well!
        Awesome, that's a nice look!
