Home › Forums › Products › Stompboxes › Space – no output?
November 2, 2012 at 8:38 pm #109253GregoryMember
I've suddenly developed a problem with my Space stompbox. When it's powered off it outputs the inputs directly, but as soon as I power it up all sound is muted from the outputs totally. In bypass or not, no sound comes out. Is there something I'm overlooking? Last time I used it it was working just fine and nothing has changed but I go to use it today and although the input levels are lighting up and sound passes through when off – the audio just gets cut off when I turn it on.
Any suggestions anyone? I tried updating the firmware just incase that would kick it back into action but nothing.
Thank you for the help.
November 2, 2012 at 8:51 pm #123959
This would happen if you had Killdry on, Mix set to 0 and Bypass Mode set to DSP.
If it is not the above, you should try a CLEAR SETUP (see UM).
November 2, 2012 at 8:59 pm #123960GregoryMember
Thanks for the response.
Killdry is off, mix is 100, and I've tried a CLEAR SETUP and firmware update. Still no effect output or bypassed output.
Felt like I must be missing something but I'm starting to think I have a problem here.
November 2, 2012 at 9:01 pm #123961GregoryMember
Kildry is off and Mix is set to 100. I've tried a CLEAR SETUP and a firmware update and the problem is still here – no audio output.
I was thinking I was overlooking something but am starting to think I have a real problem..
Any other ideas?
November 5, 2012 at 5:14 pm #134981
The next most likely cause is some cabling problem at your end. Try different cables, with the unit connected guitar-Space-amp. If it is still no good it will need looking at – support@eventide.com
