Home › Forums › Products › Stompboxes › Space Pedal: Disabled Knob Functionality
September 17, 2015 at 5:49 pm #112857
JSlimm
ParticipantHi all!I somehow created a way to scroll through parameters using the X Knob only and adjusting each parameter individually using the Encoder. I need a solution to disable this and restore the use of all 11 knobs again. Tried restoring factory settings and couldn’t correct this.Thanks for your assistance!J -
September 17, 2015 at 6:37 pm #140606Jslimm wrote:Hi all!I somehow created a way to scroll through parameters using the X Knob only and adjusting each parameter individually using the Encoder. I need a solution to disable this and restore the use of all 11 knobs again. Tried restoring factory settings and couldn't correct this.Thanks for your assistance!J
If you press and hold X, Y, or Z it will toggle that button from Simple to Expert mode. Expert mode lets you scroll through all the parameters with an X, Y, or Z button.
September 17, 2015 at 7:14 pm #140607
spaceJam
MemberSpace doesn’t have a Z knob.
I think you are talking about the H9 and OP is talking about the Space.
September 18, 2015 at 1:09 am #140609spaceJam wrote:
Space doesn't have a Z knob.
Oops, you're right! Brain glitch! Ok, OP, can you perhaps provide a little more detail, or even a video of this behavior? Becuase if it is indeed a Space pedal, this is pretty strange from the way it reads, never heard of anything like this before.
Also, make sure the Knob Mode (in the System Menu under Utilities) isn't set to Catchup or Locked.
September 22, 2015 at 1:26 pm #140682
JSlimm
ParticipantThanks so much, all! Got it all sorted 🙂
March 27, 2016 at 7:14 pm #143003
JSlimm
ParticipantHi,
Reopening this thread as this is now happening again. I can’t seem to get out of this mode causing this issue which is disabling all knobs but the preset/encoder knob.
I’m currently in Preset Mode. Suggestions?
Jac
March 27, 2016 at 7:39 pm #143004
JSlimm
ParticipantI’m able to edit the preset paramets with all knobs when using the H9 Control software. It just will not work when actually using the physical knobs on the stompbox.
