Home › Forums › Products › Stompboxes › Space pedal keeps editing patches in the middle of shows
January 25, 2016 at 6:22 pm #113189roryogloryMember
Weird issue started happening to me lately – in the middle of shows or rehearsal all of a sudden my guitar will sound like soup – the space pedal randomly turns the MIX knob up to 100 (obviously not the physical knob is switching, the effect just seems to be doing it). It has happened on several different patches, I tried a factory reset and remaking patches but it’s still having the issue. Any ideas? Thanks guys!!!
January 25, 2016 at 7:41 pm #142275
Not good. Does anything appear on the display when this happens ?
Thanks for the response. No nothing changes on the display, I can simply hear it all of a sudden with a crazy long tail. I’m confident it’s a mix knob thing because I am able to replicate it by switching the patch, going back to it (it goes back to normal) and then turn the Mix knob all the way up, making it sound the same as it does when it does it’s weird little glitch. Tried resetting the firmware and the system, re-importing the patches and setting all the knobs to LOCK about an hour ago – so far so good but it’s gone several days without repeating the problem before and then boom, here we go again.
January 25, 2016 at 10:16 pm #142278
Just to help us debug it, are you running an expression pedal, aux switch, midi, or USB into the Space?
Thanks,
Dan
January 25, 2016 at 10:18 pm #142279roryogloryMember
Hey Dan, no it’s on my guitar pedal board in between an overdrive and the amp
January 25, 2016 at 10:24 pm #142280
We also wonder if this is associated with any particular presets or algorithms.
