Space Pedal Midi Clock
Home › Forums › Products › Stompboxes › Space Pedal Midi Clock
    • #112955
      urogi
        Hello. Can somebody help me how can I setup my Eventide Space pedal to ignore the midi clock massege from the USB on which I send CC automation and to be able to send the Midi Clock to the pedal thru its Midi Input ??? Thanks. So maybe I need to filter out the Midi Clock message from USB and I want to send the clock message from a Midi Clock source to the midi input !!! Thanks for the help …
      • #141180
          Alas, the pedal can only use one of MIDI and USB, so you probably can't do this.
          When the Factors were designed, we expected the USB only to be used for updates, and had not expected it to be used at the same time as DIN MIDI.
