Space popping and crackling noise
Home Forums Products Stompboxes Space popping and crackling noise
Viewing 5 reply threads
    • #113532
      D_Boult
      So occasionally the box pops and crackles, sounds like bits of static especially when doing loooong reverbs. Anyone else ever got this? Kind of renders it useless as I use it live and its very audible (I play very quiet music….).
      i have checked everything, I’m not clipping or getting anywhere near it. Eventide arent responding to Support email. I’m in the UK if anyone knows people that fix them there.
      Its out of warranty.
      Any help, knowledge greatly appreciated!
      Thanks
      M
    • #143663
      gkellum
      Is this a new behavior?  Did it just start doing this recently?  I can think of two cases where I've heard this in the past.  One, the unit has a bad memory chip, or two, a software update didn't install correctly.  You might want to try reinstalling the Space's software if it had it's software updated recently and you think that might be the problem.
      • #143664
        D_Boult
        gkellum wrote:
        Is this a new behavior?  Did it just start doing this recently?  I can think of two cases where I’ve heard this in the past.  One, the unit has a bad memory chip, or two, a software update didn’t install correctly.  You might want to try reinstalling the Space’s software if it had it’s software updated recently and you think that might be the problem.
        Thanks for the reply! The box is new to me, It’s been in a box for quite some time unused. So i have no real idea if this is a new problem.
        I reinstalled the software the other day with no success in getting rid of the pops. I’ll try it again. If it is the memory chip is that something that can be sorted in your experience? Thanks again….
      • #143665
        gkellum
        D_Boult wrote:
        I reinstalled the software the other day with no success in getting rid of the pops. I'll try it again. If it is the memory chip is that something that can be sorted in your experience? Thanks again….
        Yes, memory chips can be replaced.  Even if your unit is out of warranty, Eventide will repair it for a flat fee.
        I didn't mean to suggest those are the only two possibilities however.  My colleague, Nick, might chime in with a few more ideas.
        But in any case you might want to try emailing support@eventide.com again.  Emails sent to that address are tracked, and normally, all emails should be answered.  Did you check your junk mail folder to see if a response might have landed there?
      • #143666
        D_Boult
        [/quote]
        I didn’t mean to suggest those are the only two possibilities however.  My colleague, Nick, might chime in with a few more ideas.
        [/quote]
        Ok, thanks. No message in my junk unfortunately but I’ll try again.
    • #149776
      manukainfinity
      I’ve had the same problem. What was the outcome, did you get it fixed?
    • #151206
      matthieu canuet
      Same problem for me. Any solution? I alsozteizd to réinstalle the software without success
    • #151207
      There are two causes that occur to me:
      1) Some kind of connection or wiring issue at your end.
      2) A faulty memory chip in the unit.
      Best way to determine:
      If it varies with the preset and settings it's probably (2), otherwise (1).
      If (2), support@eventide.com
    • #158698
      zejj
      I’ve purchased a used Space pedal and i’m having the same problem as described here : “the box pops and crackles, sounds like bits of static especially when doing loooong reverbs”
      I live in France and I guess there is no Eventide technical support in my country, so I wonder what I can do with my box… :-(((
