Home › Forums › Products › Stompboxes › Space power cable
June 24, 2019 at 8:17 pm #115396
jinx1050
ParticipantHeya everyone.
I am finally thinking of powering my Space pedal from a power brick rather than my eventide plug but whilst my power supply ‘Palmer pwt12’ will power it just fine I honestly don’t know what cable to use. None seem to fit it except the eventide wall power although I have a red cable that came with a t rex power that fits the input. I havent tried pluging that in yet to the actual power. i don’t understand about the negative ring etc so could use a little help in finding the correct cable. I am UK based 🙂 Thanks.
June 25, 2019 at 6:28 pm #152213jinx1050 wrote:
I am finally thinking of powering my Space pedal from a power brick rather than my eventide plug but whilst my power supply 'Palmer pwt12' will power it just fine I honestly don't know what cable to use. None seem to fit it except the eventide wall power although I have a red cable that came with a t rex power that fits the input. I havent tried pluging that in yet to the actual power. i don't understand about the negative ring etc so could use a little help in finding the correct cable. I am UK based 🙂 Thanks.
We don't recommand users use any other power supply other than our factory power supply or PowerMax. If you use other power supply you may lose your warrenty (if you still have). You will also be responsible for any damage caused by the power supply.
So I've made clear I don't recommand this. If you insist to use your power brick for your Space, this might be what you want: https://www.sweetwater.com/store/detail/1SpotCL6–truetone-1-spot-l6-converter
June 25, 2019 at 7:56 pm #152215
jinx1050
ParticipantThank you and advice taken on board happily.
Do you have a link to a shop that would ship that to the UK?
Many thanks 🙂
June 30, 2019 at 9:14 pm #152241
benriddell
ParticipantIt annoys me when companies say “you should only use our power supplies” when touring artist all use power bricks (Voodoo Lab, CAE, Truetone etc.) – none of them use the Eventide supplied plug!
I’m betting a large proportion of the Eventide staff don’t use the supplied plug?
If you’re happy with your Palmer you only need a cable like this (I’d be surprised if it didn’t come with one): https://www.andertons.co.uk/guitar-dept/guitar-pedals/pedal-power-supplies/voodoo-labs-ppl6-black-to-red-l6-25mm-connector-cable-for-pedal-power-2-plus
Personally I went with the GigRig modular system. It’s a bit pricey but the most flexable option out there. I power an Atomic Amplifire 3 and two Eventide H9s (with the GR Evenflo adapter) with it and it still have enough juice available to power a number of 9v pedals and a couple of Strymons before maxing out the 5 amp it gives out
