SPACE problem.
Home Forums Products Stompboxes SPACE problem.
    • #115440
      Daniel
      I’ve had my SPACE pedal as last in a chain, with no issues, for a few months.
      Just this weekend, several of the pedals in the chain switched on or off with a loud pop. Only when I remove the SPACE pedal does the noise disappear.
      I’ve done a reset, I’ve flipped the small toggles – nothing seems to help.
      Does this sound like a problem has surfaced with the SPACE pedal? I haven’t changed anything since putting it on my board.
    • #152396
      It is unlikely that the Space could interfere with pedals before it in a chain.
      More likely is some kind of power supply issue. If you are using a common power supply, it may be being overloaded and removing the Space could remedy this.
    • #152397
      Daniel
      Thanks for the reply.
      The post can be deleted (I’m not sure hoe to do that), as I went over everything again, and found the culprit (another pedal).
