Space reverb stomp box – volume problem
Home › Forums › Products › Stompboxes › Space reverb stomp box – volume problem
    • #113409
      I am having volume levels drop when I increase the mix knob on any reverb setting. Is this normal? Around 17% volume is great 100% the volume is really diminished
    • #143186
      wedelich
        I can understand the reverb being a bit quieter than the dry signal in many cases, but I'm not sure what you mean by really diminished.  Could you record some audio, make a video, and/or a report a measured volume difference number in dB?
        Thanks
      • #143190
        Antti
          Are you using the Out Lvl in Amp or Line setting?
          After recently updating my Space to 5.2.0(6), the effected signal always acts as if the Out Lvl was set to Amp (dry signal uses the actual setting). This would also explain why the active button doesn’t seem to do anything for some people.
