Home › Forums › Products › Stompboxes › Space – Shimmer
November 30, 2015 at 2:14 am #113059
Hi all,
New eventide space player here..
So I just joined the Dropbox group that has a bunch of presets — I have not been able to go through all of them, but I figure I’d post here to help get some direction on making my own presets. Programming a nice shimmer is my first goal I set for myself. Right now I am as new as its gets when it comes to programming reverb, so if anybody has any reading materials or can help point me in the right direction that would be great. Some of the shimmers that I really like are Polara’s lexicon shimmer as well as this Brian Eno’s Prophecy Theme from Dune. I imagine the programmers at eventide made the space capable of getting these sounds, it just may be a challange for a rookie. Any thoughts?
December 1, 2015 at 1:24 am #141692
December 1, 2015 at 5:09 pm #141695
There is an algorithm on the Space called "Shimmer." Try it with a nice synth pad and/or strings. Eno's sound is a bit more complex, but it seems like he's also got more than one voice going at a time.
December 2, 2015 at 1:52 am #141699
To clairify I meant that I would like some help on making the default preset of Shimmer to sound better. It is rather complicated to tweak, so besides using the manual for help I came here to see if anybody else had any thoughts.
December 2, 2015 at 1:43 pm #141701
Here’s one. It doesn’t sound the same in the youtube clip but you can tweak this to get close.
Khuko,
Thanks! I am not infront of the Space right now, but when I get home I will try this out. It looks like I didn’t go too crazy on the low-decay and the size as well as the a-pitch. Is the expression pedal controlling a parameter?
December 3, 2015 at 2:23 am #141709
No, it doesn’t. On this preset, I believe my EXP pedal is used to control the input volume (volume swells)
December 3, 2015 at 2:29 am #141710
Pitch A is just set to do +2 octaves up. B is +1 octave.
For reference
500c = P4th
700c = P5th
1200c = 1 Octave
1900c = 1 Octave + P5
2400c = 2 Octaves
December 3, 2015 at 3:16 pm #141714baloo wrote:
Hi all,
So I just joined the Dropbox group that has a bunch of presets — I have not been able to go through all of them, but I figure I'd post here to help get some direction on making my own presets. Programming a nice shimmer is my first goal I set for myself. Right now I am as new as its gets when it comes to programming reverb, so if anybody has any reading materials or can help point me in the right direction that would be great. Some of the shimmers that I really like are Polara's lexicon shimmer as well as this Brian Eno's Prophecy Theme from Dune. I imagine the programmers at eventide made the space capable of getting these sounds, it just may be a challange for a rookie. Any thoughts?
I find that turning the Mid Decay down, or all the way down, and turning the delay up approaches some of these smoother Eno sounds. The mids add an organ like character that creates a dense shimmer, but it's not quite a smooth. Adding some time (i.e. delay) between the reverb tails and the pitchshifters also give the Shimmer some room to breathe a bit. You can also turn the Pitch Decay up to make draw out the shimmer rise and fall.
