Home › Forums › Products › Stompboxes › SPACE update
May 16, 2019 at 12:43 am #115315
It’s been a while since I’ve used my SPACE pedal, but I’m putting it back on my board.
I know there are updates for this, but I forget/can’t find exactly how to do an update. The booklet isn’t helpful in that regard, so is there a page at Eventide that walks this dummy through the process? Any direction is appreciated.
May 16, 2019 at 12:50 am #151893
Try: https://www.eventideaudio.com/support/product/691/installers
But, as always, unless you NEED an update – don't bother. You will be happy with the SPACE as it is.
Updates are work, have a finite risk of problems, and require some re-learning.
May 16, 2019 at 1:06 am #151895
Thanks, Nick.
I was actually looing for a step-by-step page for downloading and installing an update, but I was able to do that using the page you referenced.
The only reason I wanted to update is that it’s been a good while since my SPACE has been in regular usage. That’s about to change.
Is there a way to learn which is the latest update I’ve installed?
May 16, 2019 at 2:15 am #151897Daniel wrote:
Thanks, Nick.
The only reason I wanted to update is that it's been a good while since my SPACE has been in regular usage. That's about to change.
Is there a way to learn which is the latest update I've installed?
Updates usually have associated release notes which describe the changes.
But SPACE is a pretty mature product now, so maybe not.
May 16, 2019 at 1:12 am #151896
Forgot.
The H9 was released subsequent to my purchase of the SPACE pedal.
Is there something I now need to know about updating via H9? I don’t have an H9, so I’m wondering if I’m missing something.
May 16, 2019 at 2:18 am #151898Daniel wrote:
Forgot.
Is there something I now need to know about updating via H9? I don't have an H9, so I'm wondering if I'm missing something.
H9 has a lot more (optional) algorithms and can be updated over Bluetooth. So, it's a bigger deal.
SPACE is a great reverb – if you want more you should consider H9.
H9 is also smaller and lighter.
