Space ver 4.0.1 update kills Active switch
Home Forums Products Stompboxes Space ver 4.0.1 update kills Active switch
Viewing 6 reply threads
    • #113296
      sduck
      As per the subject, I just updated my Space pedal to ver. 4.0.1, and now the Active switch doesn’t do anything, which basically renders the device useless.
      Any ideas?
    • #142695
      Sorry – it sounds like something got corrupted – it will have to come for service. support@eventide.com
    • #142696
      sduck
      Would it be possible to install an older, working version of the firmware? Are any of these available anywhere? I’m sure you’ve got them there, somewhere, at leasrt I could try that before sending it in?
    • #142697
      sunfalls
      member “sunfalls” here..
      yes, this happened to my pedal as well. so it is obviously a software issue. and not a “unit” issue.
      it wiped my serial from internal memory as well.
      would be greatly appreciated if you could send us pervious software versions to get our Spaces working.
      I read in another thread that you sent software out for other folks. And since its a common software bug.
      we need an update, or at the least v3.
      thanks,
      sunfalls
    • #142701
      Sorry – right now we do not know what causes this. It cannot be fixed be re-installing the previous software.
    • #142702
      sunfalls
      Well, Can we at least try. Can’t hurt to give it a go eh.
      It says on the site that we are supposed to be able to “revert to previous software”
    • #142703
      sunfalls
      also, like i mentioned before. I’m not even seeing v5 anywhere in my eventide direct updater, nor any previous versions before 4.0.1[0].
      so, .. ?
