Spacial Audio Algorithm
Home Forums Products Rackmount Spacial Audio Algorithm
    • #171712
      gustebeast
        With all the surround sound effects on the unit, it would be cool to be able to downsample them into stereo using a spacial audio algorithm. Would be especially cool if the algorithm parameters allowed you to adjust the location of each speaker. Not sure if this exists already but if not I thought I’d put the idea out there.
      • #171727
        Puppeteer
          There are some spacialisation algorithms in the H9000 starting at 5910.
          One of the problems with trying to cram surround information into the stereo field is that to be effective you will often have phase coherence problems, and you need to know the surround sound configuration to attempt a conversion.
          QSound have the best surround to stereo encoding technology I know of, but it certainly messes up the phase. If you have an inside line to their algorithms, I’d be happy to have a go at building them on the H9000, but they hold it pretty close to their chests.
