August 23, 2008 at 10:48 am #105792
quinton
MemberHello,
i'd want to connect my Eclipse to my soundcard using the SPDIF coaxial output. When i do that, it looks like there's no synchronization available in the signal…Do i need to use the wordclock output to feed my soundcard ? This is a Hercules 16/12 FW, with wordclock input/output.
Hoping this is not a too "newbie" question 🙂
Thanks,
Vincent
August 25, 2008 at 12:12 pm #117793
IDeangelis
MemberHi Vincent
you can either clock the Eclipse via S/Pdif or using WC.
The easiest is S/Pdif.
Under SETUP > DIG-IN set DIG_IN : RCA then set CLOCK: DigIn
Hz.best
I
August 25, 2008 at 3:48 pm #117796
quinton
MemberThanks Italo, but i want to synchronize in the opposite way : Eclipse SPDIF out -> Souncard SPDIF In, to record the sound going out from the Eclipse. When i try with the Coax. cable alone, my soundcard seems to not d?tect any synchronization source. With another cable Eclipse wordclock out -> soundcard wordclock in, the wordclock synchronization is available, but i still hear nothing but some littles clicks…I've tried anything int the Setuo-Dig-Out menu, without any change. I wonder if my soundcard is actually working properly, but i haven't another gear that can output SPDIF Coax. signal.
Thanks for any idea…
August 25, 2008 at 4:32 pm #128947
IDeangelis
MemberVincent
I need to know all settings you use for Eclipse, including sampling frequency and OS version.
Have you tried slaving Eclipse to the card?
I
August 25, 2008 at 5:25 pm #128948
quinton
MemberOS : 3.5
Fs : 48kHz (have tried other values)
SCMS : copy_OK
Had tried all Cs-TYPE, Emphasis and bits value, just to be shure.Meanwhile, i've made several tests :
1 – soundcard SPDIF out -> Eclipse SPDIF in : works well !
2 – soundcard SPDIF out -> soundcard SPDIF in : works well too (SPDIF Coax appear in the synchronisation signals available) ; so my soundcard SPDIF input is not down…So it seems that it's the Eclipse SPDIF out which brings the problem.
Hoping this is not a harware problem…
Vincent
August 25, 2008 at 5:42 pm #128949
IDeangelis
MemberHard to say what the problem is. We would need to have your unit and computer/soundcard……
I assume you are using a true S/Pdif cable.
best
I
August 25, 2008 at 5:56 pm #128950
quinton
Memberthe cable worked well when i made the two tests above. I think this is a good cable. I will try to make more tests someday if i have another audio system with a SPDIF input. For the moment i switch back to analog links…
All the best,
Vincent
