Home › Forums › Products › Stompboxes › spill over function
July 10, 2008 at 8:04 am #105731labalouMember
Hi Gang,
ive downloaded and installed the latest software upgrade which says it corrects the spill over function for a smooth transition but i played a gig yesterday and i scared the hell out of the audience and my band members as i changed patches!the upgrade doesnt seem to make a difference yet in this department or am i doing something wrong? i know that trurning the mix global function off helps but then i loose the individual desired mix preset programed parameters.
It really bums me out because i sold my DD20 which did this really nicely,is there a work around to this?
thanx!
July 10, 2008 at 9:25 pm #117664achaputModerator
What happened when you changed patches?
July 11, 2008 at 8:30 am #117669labalouMember
well t just went "bang" really loud ! i was doing some feedback intro soundscapes and wanted the feedback to keep trailing off while changing patches and doing some David Gilmour type of rhythmic multi tap delays,this worked wonderful with my dd20,too bad it wont work with the timefactor because the sound is great;-((
July 11, 2008 at 4:17 pm #128804achaputModerator
Just to make sure, after you updated the pedal did you go into System Mode and turn SPILL to ON?
Alan
July 12, 2008 at 7:57 am #128809labalouMember
Yes this is the first thing i did after updating.
cheers
Louie
July 12, 2008 at 11:09 am #128810RoobinMember
Are you set to DSP + FX in terms of bypass options? Also, a loud bang would suggest that you're in relay bypass with the level switches set differently – you might want to have a look at them.
July 14, 2008 at 10:31 am #128813labalouMember
yes, i am set to DSP + FX
July 15, 2008 at 7:44 pm #128816achaputModerator
Do you remember which effect types you started from and switched to when that happened?
Alan
July 15, 2008 at 9:29 pm #128818labalouMember
I believe it happens between the digital delay and the vintage delay,i have the expression pedal setup to increase the feedback regeneration on both of them.But even without the expression pedal there is sometimes a loud bump,warble or glitch when alternating between the presets and the transition is just not smooth at all,it is only smooth when engaging and desengaging the effect.
cheers
louie
