Split-Eq in Reason
Home Forums Products Plug-Ins Split-Eq in Reason
    • #167934
      pinballmagnetic
        I’m using the Demo in Reason 12 of spliteq.
        The latency compensation is not working properly.
        There is no latency when i load the plugin on a track. But when i bounce the song to audio and play it back, there is quite a bit of latency on the track that uses SplitEQ.
        Is this normal? Is this a bug? Am i missing something?
        best
      • #168222
        tlongabaugh
          Hi, just to confirm, you have Delay Compensation “On” in Reason? http://docs.propellerheads.se/reason10/wwhelp/wwhimpl/common/html/wwhelp.htm#href=PDC.18.2.html&single=true
          If that is turned on correctly, could you provide us with a bit more information so we can try and reproduce?
          – What OS are you using?
          – Does the issue occur in a simple test session, e.g. two tracks where one has no plugins and one has SplitEQ?
