Split Eq Side processing
Home Forums Products Plug-Ins Split Eq Side processing
    • #170544
      vyanezf
      Hi!
      I guess there’s a way around this, but I can’t find a way where I can only process the side channel.
      I understand the Mid Side controls are only for imaging proposes.
    • #170557
      tlongabaugh
      You are correct that the Mid/Side controls in the plugin are for imaging purposes only. There’s no way to only process the side channel.
      However, with a bit of routing in your DAW, you should be able to set up a track to only process the side channel, and feed that to SplitEQ.
