Home › Forums › Products › Stompboxes › Split: Eventide Device Manager not working properly
- This topic has 15 replies, 8 voices, and was last updated 5 months, 3 weeks ago by
Eventide Staff.
October 14, 2021 at 9:52 pm #159392
Im having a similar issue. I connect my Space and open H9>Pedal>Software update. I get a message to launch Device Manager which send me to the website. I have Device Manger already installed. Launch Device Manger. Shows my serial number. I come to the main screen. Select update and I receive a message to reboot in to update mode. Reboot in to update mode and Device Manager shows “Invalid” and then crashes. I’m on a Mac. Tried on 3 different Macs and created a new Admin User. Same issue. Complete uninstall and reinstalls. Same issue. Extremely frustrating.
October 14, 2021 at 10:28 pm #159394
Thank you for bringing this to our attention. I can recreate this behavior. I’ll have our team take a look at this.
October 15, 2021 at 3:01 pm #159430
Until we resolve the issue with updating Factor pedals on EDM, users may use the Direct Updater application: https://www.eventideaudio.com/downloads/?product=Space
Download it, put your pedal in update mode, and conduct the update.
August 10, 2022 at 6:30 pm #164968
I’ve got this same issue here with my TimeFactor … Any news from Eventide Staff?
August 10, 2022 at 6:50 pm #164969
No. Disappointed w/ their support. Not a cheap pedal. Expected way more. I’m al honesty, no one even reached out to me. Was planning on grabbing a couple more, but their support left a bad taste in my mouth.
August 10, 2022 at 7:07 pm #164970
Have either of you tried the solution posted recommending using the Direct Updater?
August 10, 2022 at 11:42 pm #164971
I have. I’m an Apple engineer. I tried everything. All 3 of my Macs have the same issue
August 10, 2022 at 11:47 pm #164972
Just so it’s clear, I understand EDM is giving you issues with your Factor pedals. Are you now saying the Direct Updater method also is not working for you?
August 11, 2022 at 12:22 am #164973
I just tried the Direct Updater on a MacBook Pro running Monterey 12.5. Works fine, updated my Factor pedal without issue.
- Download and install the Direct Updater for your system: https://www.eventideaudio.com/downloads/?product=TimeFactor
- Connect your pedal to your computer via USB
- Turn the pedal on while holding down the middle footswitch until the display says UPDATE.
- Open the Direct Updater application (NOT EDM). It will automatically scan for any devices. Once it detects your pedal, click OK.
- Whether the application shows the serial number of your pedal or it says INVALID, it will show you the available firmware updates regardless.
- Choose the first option (5.2.0[6]) to highlight it in blue and click “Install Update.”
- After about 5 minutes, you should be ready to rock n roll.
If this is not working, please let me know at what step in the process you get stuck.
December 5, 2022 at 7:02 pm #167437
February 25, 2024 at 11:50 am #178463
Same here !!
February 26, 2024 at 10:01 am #178499
Sorry you are having issues. Please contact support@eventide.com directly.
December 30, 2024 at 8:45 pm #187251
I also tried everything here and can not get my Space Pedal to be recognized after following every step on this thread.
It is not recognizing Pedal in Reboot Mode but even when I tap OK on the Select Device window and Device Manager disconnects ??
I have Mac OS 15.1
Any help ????
You must be logged in to view attached files.-
January 2, 2025 at 10:10 am #187324
Sorry to hear you are having issues. It would be best to email support@eventideaudio.com for further troubleshooting.
January 4, 2025 at 4:07 am #187448
I have the same problem… any solution?
January 6, 2025 at 11:33 am #187488
Have you tried these instructions?
- After about 5 minutes, the pedal should be updated.
