- This topic has 11 replies, 3 voices, and was last updated 3 years, 5 months ago by
robbarner.
November 23, 2021 at 10:48 am #160795
Hi all,
I have an issue with Split EQ (version installer is 1.0.4). Every time I try to close the plugin window Logic crashes instantly.
I am on Mac OS Sierra (10.12.6) and Logic X 10.4.3.
Any fix for that?
Best, robi
November 23, 2021 at 12:01 pm #160800
Hi, sorry to hear about the issue. Could you provide us with the following so we can more easily solve the issue?
- Support Information -> Right-click the Eventide logo in the plugin UI and select “Copy Support Information to Clipboard”, and then attach it here
- Any and all crash reports that are generated when Logic crashes
November 23, 2021 at 3:13 pm #160819
Hi tlongabaugh, thank you for your swift reply.
Find the info below:
1. Support info ->
==== BEGIN PLUGIN SUPPORT DATA ====
“PluginInfoComponentVersion”: “1.0.0”,
“System”: {
“JUCEVersion”: “JUCE v6.0.7”,
“OperatingSystemName”: “Mac OSX 10.12.6”,
“OperatingSystem64Bit”: true,
“ComputerName”: “Robis-MBP-2”,
“UserLanguage”: “en”,
“UserRegion”: “SI”,
“DisplayLanguage”: “en-SI”,
“DeviceDescription”: “MacBookPro13,3”,
“DeviceManufacturer”: “Apple”,
“DeviceIdentifiers”: [
“9a42e”
“NumCpus”: 8,
“NumPhysicalCpus”: 4,
“CpuSpeedInMegahertz”: 2600,
“CpuVendor”: “GenuineIntel”,
“CpuModel”: “Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz”,
“MMX”: true,
“3DNow”: false,
“SSE”: true,
“SSE2”: true,
“SSE3”: true,
“SSSE3”: true,
“SSE41”: true,
“SSE42”: true,
“AVX”: true,
“AVX2”: true,
“AVX512F”: false,
“AVX512BW”: false,
“AVX512CD”: false,
“AVX512DQ”: false,
“AVX512ER”: false,
“AVX512IFMA”: false,
“AVX512PF”: false,
“AVX512VBMI”: false,
“AVX512VL”: false,
“AVX512VPOPCNTDQ”: false,
“Neon”: false,
“MemorySizeInMegabytes”: 16384,
“PageSize”: 4096,
“RunningInAppExtensionSandbox”: false
“HostSettings”: {
“Host”: “Apple Logic”,
“Format”: “AU”
“PluginEnvironment”: {
“PluginName”: “SplitEQ”,
“PluginVersion”: “1.0.4”,
“PluginArchitecture”: “Intel”,
“PluginSupportInformationVersion”: “0.1.0”,
“SampleRate”: 44100.0,
“BlockSize”: 2048,
“TotalInputChannels”: 2,
“TotalOutputChannels”: 2,
“MainBusInputChannels”: 2,
“MainBusOutputChannels”: 2,
“DoublePrecision”: false,
“LatencySamples”: 3592,
“NonRealTime”: false
“STATE”: {
“plugId”: 1399866705,
“plugVer”: “1.0.4”,
“PARAMETERS”: {
“PARAM”: {
“id”: “prc1”,
“value”: “0.0”
“PARAM_1”: {
“id”: “trf1”,
“value”: “10.10000038146973”
“PARAM_2”: {
“id”: “tof1”,
“PARAM_3”: {
“id”: “tos1”,
“value”: “1.0”
“PARAM_4”: {
“id”: “trq1”,
“value”: “1.0”
“PARAM_5”: {
“id”: “toq1”,
“value”: “1.0”
“PARAM_6”: {
“id”: “trp1”,
“value”: “0.0”
“PARAM_7”: {
“id”: “trw1”,
“value”: 0.0
“PARAM_8”: {
“id”: “top1”,
“value”: “0.0”
“PARAM_9”: {
“id”: “tow1”,
“value”: 0.0
“PARAM_10”: {
“id”: “mss1”,
“value”: “0.0”
“PARAM_11”: {
“id”: “slb1”,
“value”: “0.0”
“PARAM_12”: {
“id”: “prc2”,
“value”: “1.0”
“PARAM_13”: {
“id”: “typ2”,
“value”: “0.0”
“PARAM_14”: {
“id”: “tof2”,
“value”: “100.0”
“PARAM_15”: {
“id”: “trb2”,
“value”: “0.0”
“PARAM_16”: {
“id”: “tob2”,
“value”: “0.0”
“PARAM_17”: {
“id”: “srb2”,
“value”: “1.0”
“PARAM_18”: {
“id”: “tos2”,
“value”: “1.0”
“PARAM_19”: {
“id”: “trq2”,
“value”: “1.0”
“PARAM_20”: {
“id”: “toq2”,
“value”: “1.0”
“PARAM_21”: {
“id”: “trp2”,
“value”: “0.0”
“PARAM_22”: {
“id”: “trw2”,
“value”: 0.0
“PARAM_23”: {
“id”: “top2”,
“value”: “0.0”
“PARAM_24”: {
“id”: “tow2”,
“value”: 0.0
“PARAM_25”: {
“id”: “mss2”,
“value”: “0.0”
“PARAM_26”: {
“id”: “slb2”,
“value”: “0.0”
“PARAM_27”: {
“id”: “prc3”,
“value”: “1.0”
“PARAM_28”: {
“id”: “typ3”,
“value”: “1.0”
“PARAM_29”: {
“id”: “tof3”,
“value”: “400.0000305175781”
“PARAM_30”: {
“id”: “trb3”,
“value”: “0.0”
“PARAM_31”: {
“id”: “tob3”,
“value”: “0.0”
“PARAM_32”: {
“id”: “srb3”,
“value”: “1.0”
“PARAM_33”: {
“id”: “tos3”,
“value”: “1.0”
“PARAM_34”: {
“id”: “trq3”,
“value”: “1.0”
“PARAM_35”: {
“id”: “toq3”,
“value”: “1.0”
“PARAM_36”: {
“id”: “trp3”,
“value”: “0.0”
“PARAM_37”: {
“id”: “trw3”,
“value”: 0.0
“PARAM_38”: {
“id”: “top3”,
“value”: “0.0”
“PARAM_39”: {
“id”: “tow3”,
“value”: 0.0
“PARAM_40”: {
“id”: “mss3”,
“value”: “0.0”
“PARAM_41”: {
“id”: “slb3”,
“value”: “0.0”
“PARAM_42”: {
“id”: “prc4”,
“value”: “1.0”
“PARAM_43”: {
“id”: “typ4”,
“value”: “1.0”
“PARAM_44”: {
“id”: “tof4”,
“value”: “800.0000610351562”
“PARAM_45”: {
“id”: “trb4”,
“value”: “0.0”
“PARAM_46”: {
“id”: “tob4”,
“value”: “0.0”
“PARAM_47”: {
“id”: “srb4”,
“value”: “1.0”
“PARAM_48”: {
“id”: “tos4”,
“value”: “1.0”
“PARAM_49”: {
“id”: “trq4”,
“value”: “1.0”
“PARAM_50”: {
“id”: “toq4”,
“value”: “1.0”
“PARAM_51”: {
“id”: “trp4”,
“value”: “0.0”
“PARAM_52”: {
“id”: “trw4”,
“value”: 0.0
“PARAM_53”: {
“id”: “top4”,
“value”: “0.0”
“PARAM_54”: {
“id”: “tow4”,
“value”: 0.0
“PARAM_55”: {
“id”: “mss4”,
“value”: “0.0”
“PARAM_56”: {
“id”: “slb4”,
“value”: “0.0”
“PARAM_57”: {
“id”: “prc5”,
“value”: “1.0”
“PARAM_58”: {
“id”: “typ5”,
“value”: “1.0”
“PARAM_59”: {
“id”: “tof5”,
“value”: “1599.999877929688”
“PARAM_60”: {
“id”: “trb5”,
“value”: “0.0”
“PARAM_61”: {
“id”: “tob5”,
“value”: “0.0”
“PARAM_62”: {
“id”: “srb5”,
“value”: “1.0”
“PARAM_63”: {
“id”: “tos5”,
“value”: “1.0”
“PARAM_64”: {
“id”: “trq5”,
“value”: “1.0”
“PARAM_65”: {
“id”: “toq5”,
“value”: “1.0”
“PARAM_66”: {
“id”: “trp5”,
“value”: “0.0”
“PARAM_67”: {
“id”: “trw5”,
“value”: 0.0
“PARAM_68”: {
“id”: “top5”,
“value”: “0.0”
“PARAM_69”: {
“id”: “tow5”,
“value”: 0.0
“PARAM_70”: {
“id”: “mss5”,
“value”: “0.0”
“PARAM_71”: {
“id”: “slb5”,
“value”: “0.0”
“PARAM_72”: {
“id”: “prc6”,
“value”: “1.0”
“PARAM_73”: {
“id”: “typ6”,
“value”: “1.0”
“PARAM_74”: {
“id”: “tof6”,
“value”: “3200.00048828125”
“PARAM_75”: {
“id”: “trb6”,
“value”: “0.0”
“PARAM_76”: {
“id”: “tob6”,
“value”: “0.0”
“PARAM_77”: {
“id”: “srb6”,
“value”: “1.0”
“PARAM_78”: {
“id”: “tos6”,
“value”: “1.0”
“PARAM_79”: {
“id”: “trq6”,
“value”: “1.0”
“PARAM_80”: {
“id”: “toq6”,
“value”: “1.0”
“PARAM_81”: {
“id”: “trp6”,
“value”: “0.0”
“PARAM_82”: {
“id”: “trw6”,
“value”: 0.0
“PARAM_83”: {
“id”: “top6”,
“value”: “0.0”
“PARAM_84”: {
“id”: “tow6”,
“value”: 0.0
“PARAM_85”: {
“id”: “mss6”,
“value”: “0.0”
“PARAM_86”: {
“id”: “slb6”,
“value”: “0.0”
“PARAM_87”: {
“id”: “prc7”,
“value”: “1.0”
“PARAM_88”: {
“id”: “typ7”,
“value”: “3.0”
“PARAM_89”: {
“id”: “tof7”,
“value”: “10000.001953125”
“PARAM_90”: {
“id”: “trb7”,
“value”: “0.0”
“PARAM_91”: {
“id”: “tob7”,
“value”: “0.0”
“PARAM_92”: {
“id”: “srb7”,
“value”: “1.0”
“PARAM_93”: {
“id”: “tos7”,
“value”: “1.0”
“PARAM_94”: {
“id”: “trq7”,
“value”: “1.0”
“PARAM_95”: {
“id”: “toq7”,
“value”: “1.0”
“PARAM_96”: {
“id”: “trp7”,
“value”: “0.0”
“PARAM_97”: {
“id”: “trw7”,
“value”: 0.0
“PARAM_98”: {
“id”: “top7”,
“value”: “0.0”
“PARAM_99”: {
“id”: “tow7”,
“value”: 0.0
“PARAM_100”: {
“id”: “mss7”,
“value”: “0.0”
“PARAM_101”: {
“id”: “slb7”,
“value”: “0.0”
“PARAM_102”: {
“id”: “prc8”,
“value”: “0.0”
“PARAM_103”: {
“id”: “trf8”,
“value”: “20000.0”
“PARAM_104”: {
“id”: “tof8”,
“value”: “20000.0”
“PARAM_105”: {
“id”: “tos8”,
“value”: “1.0”
“PARAM_106”: {
“id”: “trq8”,
“value”: “1.0”
“PARAM_107”: {
“id”: “toq8”,
“value”: “1.0”
“PARAM_108”: {
“id”: “trp8”,
“value”: “0.0”
“PARAM_109”: {
“id”: “trw8”,
“value”: 0.0
“PARAM_110”: {
“id”: “top8”,
“value”: “0.0”
“PARAM_111”: {
“id”: “tow8”,
“value”: 0.0
“PARAM_112”: {
“id”: “mss8”,
“value”: “0.0”
“PARAM_113”: {
“id”: “slb8”,
“value”: “0.0”
“PARAM_114”: {
“id”: “styp”,
“value”: “0.0”
“PARAM_115”: {
“id”: “trsp”,
“value”: “0.5”
“PARAM_116”: {
“id”: “trdc”,
“value”: “0.300000011920929”
“PARAM_117”: {
“id”: “smoo”,
“value”: “0.01999999955296516”
“PARAM_118”: {
“id”: “rLev”,
“value”: “0.0”
“PARAM_119”: {
“id”: “rSol”,
“value”: “0.0”
“PARAM_120”: {
“id”: “oLev”,
“value”: “0.0”
“PARAM_121”: {
“id”: “oSol”,
“value”: “0.0”
“PARAM_122”: {
“id”: “phsi”,
“value”: 0.0
“PARAM_123”: {
“id”: “rpan”,
“value”: 0.0
“PARAM_124”: {
“id”: “rwdt”,
“value”: 0.0
“PARAM_125”: {
“id”: “opan”,
“value”: 0.0
“PARAM_126”: {
“id”: “owdt”,
“value”: 0.0
“PARAM_127”: {
“id”: “gbmd”,
“value”: 0.0
“PARAM_128”: {
“id”: “rgsc”,
“value”: “1.0”
“PARAM_129”: {
“id”: “ogsc”,
“value”: “1.0”
“PARAM_130”: {
“id”: “bypi”,
“value”: “0.0”
“PARAM_131”: {
“id”: “bype”,
“value”: 0.0
“DATAPARAMS”: {
“PROPERTY”: {
“name”: “prSl”,
“value”: “Default.tidex 1”,
“persist”: 2,
“undoable”: false
“PROPERTY_1”: {
“name”: “abSl”,
“value”: 0,
“persist”: 0,
“undoable”: false
“PROPERTY_2”: {
“name”: “anSt”,
“value”: “0 0 1 2 2 1 0 1 1 0”,
“persist”: 2,
“undoable”: true
“PROPERTY_3”: {
“name”: “azeb”,
“value”: true,
“persist”: 0,
“undoable”: false
“PROPERTY_4”: {
“name”: “eqMn”,
“value”: false,
“persist”: 0,
“undoable”: false
“PROPERTY_5”: {
“name”: “zLvl”,
“value”: “-12 12”,
“persist”: 2,
“undoable”: false
“PROPERTY_6”: {
“name”: “epTb”,
“value”: 0,
“persist”: 2,
“undoable”: false
==== END PLUGIN SUPPORT DATA ==== -
November 23, 2021 at 3:15 pm #160820
2. and here the Logic crash report:
Process: Logic Pro X [11091]
Path: /Applications/Logic Pro X.app/Contents/MacOS/Logic Pro X
Identifier: com.apple.logic10
Version: 10.4.3 (4980.97)
Build Info: MALogic-4980097000000000~2
App Item ID: 634148309
App External ID: 828823649
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Logic Pro X [11091]
User ID: 501Date/Time: 2021-11-23 21:13:50.028 +0100
OS Version: Mac OS X 10.12.6 (16G1710)
Report Version: 12
Anonymous UUID: 8CE94B24-679F-8D36-0F5E-64F91864C3D1Sleep/Wake UUID: 8A875E5F-4C0E-4806-B7EF-89A7D8F9AD7E
Time Awake Since Boot: 44000 seconds
Time Since Wake: 1700 secondsSystem Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFYApplication Specific Information:
*** Terminating app due to uncaught exception ‘NSInternalInconsistencyException’, reason: ‘An instance 0x608000401a80 of class AVPlayer was deallocated while key value observers were still registered with it. Current observation info: <NSKeyValueObservationInfo 0x61800083fa40> (
<NSKeyValueObservance 0x618000a5f0e0: Observer: 0x600000216200, Key path: rate, Options: <New: YES, Old: YES, Prior: NO> Context: 0x7fa888a98cb0, Property: 0x608001442490>
<NSKeyValueObservance 0x600002e4b550: Observer: 0x600000216200, Key path: status, Options: <New: YES, Old: NO, Prior: NO> Context: 0x7fa888a98cb0, Property: 0x608001442520>
MALondonII | 94d3b910e514cb711d268bc5d953046c3bb629e70a5564a403b3bde53d2a75b7 | b5a3763eeeb9cd03d024bdb84b9d5975b70318b3 | 2018-12-03_14:10:56abort() called
terminating with uncaught exception of type NSExceptionApplication Specific Backtrace 1:
0 CoreFoundation 0x00007fffb1e6824b __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fffc6ca548d objc_exception_throw + 48
2 CoreFoundation 0x00007fffb1ee6bfd +[NSException raise:format:] + 205
3 Foundation 0x00007fffb38461a4 NSKVODeallocate + 293
4 libsystem_blocks.dylib 0x00007fffc7613952 _Block_release + 102
5 libdispatch.dylib 0x00007fffc75a98fc _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fffc75b6aac _dispatch_main_queue_callback_4CF + 925
7 CoreFoundation 0x00007fffb1e1db19 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9
8 CoreFoundation 0x00007fffb1ddeb2d __CFRunLoopRun + 2205
9 CoreFoundation 0x00007fffb1dde034 CFRunLoopRunSpecific + 420
10 HIToolbox 0x00007fffb133eebc RunCurrentEventLoopInMode + 240
11 HIToolbox 0x00007fffb133ecf1 ReceiveNextEventCommon + 432
12 HIToolbox 0x00007fffb133eb26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
13 AppKit 0x00007fffaf8d3a54 _DPSNextEvent + 1120
14 AppKit 0x00007fffb004f7ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
15 Logic Pro X 0x0000000104f4a9dd _Z11FindFreeBusIK11AUDIODEVICEENSt3__111conditionalIXsr3std8is_constINS2_14remove_pointerIDtfp0_EE4typeEEE5valueEPK12SAUCONFUNIONPS8_E4typeEP5CSongPT_PNS2_3setIiNS2_4lessIiEENS2_9allocatorIiEEEE + 17042237
16 AppKit 0x00007fffaf8c83db -[NSApplication run] + 926
17 AppKit 0x00007fffaf892e0e NSApplicationMain + 1237
18 Logic Pro X 0x00000001042e120d _Z11FindFreeBusIK11AUDIODEVICEENSt3__111conditionalIXsr3std8is_constINS2_14remove_pointerIDtfp0_EE4typeEEE5valueEPK12SAUCONFUNIONPS8_E4typeEP5CSongPT_PNS2_3setIiNS2_4lessIiEENS2_9allocatorIiEEEE + 4027245
19 libdyld.dylib 0x00007fffc75df235 start + 1
20 ??? 0x0000000000000001 0x0 + 1Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fffc770dd42 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fffc77fb457 pthread_kill + 90
2 libsystem_c.dylib 0x00007fffc7673420 abort + 129
3 libc++abi.dylib 0x00007fffc617394a abort_message + 266
4 libc++abi.dylib 0x00007fffc6198c2f default_terminate_handler() + 267
5 libobjc.A.dylib 0x00007fffc6ca76fe _objc_terminate() + 103
6 libc++abi.dylib 0x00007fffc6195d49 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fffc6195dc3 std::terminate() + 51
8 libdispatch.dylib 0x00007fffc75a9910 _dispatch_client_callout + 28
9 libdispatch.dylib 0x00007fffc75b6aac _dispatch_main_queue_callback_4CF + 925
10 com.apple.CoreFoundation 0x00007fffb1e1db19 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9
11 com.apple.CoreFoundation 0x00007fffb1ddeb2d __CFRunLoopRun + 2205
12 com.apple.CoreFoundation 0x00007fffb1dde034 CFRunLoopRunSpecific + 420
13 com.apple.HIToolbox 0x00007fffb133eebc RunCurrentEventLoopInMode + 240
14 com.apple.HIToolbox 0x00007fffb133ecf1 ReceiveNextEventCommon + 432
15 com.apple.HIToolbox 0x00007fffb133eb26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
16 com.apple.AppKit 0x00007fffaf8d3a54 _DPSNextEvent + 1120
17 com.apple.AppKit 0x00007fffb004f7ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
18 com.apple.logic10 0x0000000104f4a9dd 0x1038c5000 + 23615965
19 com.apple.AppKit 0x00007fffaf8c83db -[NSApplication run] + 926
20 com.apple.AppKit 0x00007fffaf892e0e NSApplicationMain + 1237
21 com.apple.logic10 0x00000001042e120d 0x1038c5000 + 10600973
22 libdyld.dylib 0x00007fffc75df235 start + 1Thread 1:
0 libsystem_kernel.dylib 0x00007fffc770dbf2 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fffc77f97fa _pthread_cond_wait + 712
2 libc++.1.dylib 0x00007fffc61234cd std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3 com.apple.JavaScriptCore 0x00007fffb4dec43c void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 108
4 com.apple.JavaScriptCore 0x00007fffb4dec3bb bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 155
5 com.apple.JavaScriptCore 0x00007fffb4dec28d bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadEntryPoint(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*) + 29
6 com.apple.JavaScriptCore 0x00007fffb4dec53d void* std::__1::__thread_proxy<std::__1::tuple<void (*)(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*), bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*> >(void*) + 93
7 libsystem_pthread.dylib 0x00007fffc77f893b _pthread_body + 180
8 libsystem_pthread.dylib 0x00007fffc77f8887 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 2:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fffc770634a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fffc7705797 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fffb1ddf354 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fffb1dde7e1 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fffb1dde034 CFRunLoopRunSpecific + 420
5 com.apple.AppKit 0x00007fffafa20f02 _NSEventThread + 205
6 libsystem_pthread.dylib 0x00007fffc77f893b _pthread_body + 180
7 libsystem_pthread.dylib 0x00007fffc77f8887 _pthread_start + 286
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 3:: MIDIClientNotificationThread
5 com.apple.Foundation 0x00007fffb37f1182 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
6 com.apple.Foundation 0x00007fffb38817d5 -[NSRunLoop(NSRunLoop) runUntilDate:] + 111
7 com.apple.logic10 0x0000000103dc3ae9 0x1038c5000 + 5237481
8 libsystem_pthread.dylib 0x00007fffc77f893b _pthread_body + 180
9 libsystem_pthread.dylib 0x00007fffc77f8887 _pthread_start + 286
10 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 4:: SeqTimer
1 libsystem_pthread.dylib 0x00007fffc77f9833 _pthread_cond_wait + 769
2 com.apple.CoreServices.CarbonCore 0x00007fffb2d12984 TSWaitOnConditionTimedRelative + 147
3 com.apple.CoreServices.CarbonCore 0x00007fffb2d12585 TSWaitOnSemaphoreCommon + 433
4 com.apple.CoreServices.CarbonCore 0x00007fffb2cf90ae TimerThread + 71
5 libsystem_pthread.dylib 0x00007fffc77f893b _pthread_body + 180
6 libsystem_pthread.dylib 0x00007fffc77f8887 _pthread_start + 286
7 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 5:
2 com.apple.audio.midi.CoreMIDI 0x00000001067b59c1 XServerMachPort::ReceiveMessage(int&, void*, int&) + 107
3 com.apple.audio.midi.CoreMIDI 0x00000001067cbba9 MIDIProcess::RunMIDIInThread() + 105
4 com.apple.audio.midi.CoreMIDI 0x00000001067d8a9a XThread::RunHelper(void*) + 10
5 com.apple.audio.midi.CoreMIDI 0x00000001067dc053 CAPThread::Entry(CAPThread*) + 85
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 6:: ExtendedAudioFileScheduler::WorkerThreadProc
2 com.apple.music.apps.MAFiles 0x000000010823a6cb ExtendedAudioFileScheduler::WorkerThreadProc() + 123
3 com.apple.music.apps.MAFiles 0x000000010823a649 ExtendedAudioFileScheduler::WorkerThreadProc(void*) + 9
4 libsystem_pthread.dylib 0x00007fffc77f893b _pthread_body + 180
5 libsystem_pthread.dylib 0x00007fffc77f8887 _pthread_start + 286
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 7:: ExtendedAudioFileScheduler::WorkerThreadProc
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 8:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fffb0f190f4 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6 com.apple.Foundation 0x00007fffb38017dd __NSThread__start__ + 1243
9 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 9:: FileIOThread 4
0 libsystem_kernel.dylib 0x00007fffc7706386 semaphore_wait_trap + 10
1 com.apple.music.apps.MAAudioEngine 0x000000010838b6b2 0x10833c000 + 325298
2 libsystem_pthread.dylib 0x00007fffc77f893b _pthread_body + 180
3 libsystem_pthread.dylib 0x00007fffc77f8887 _pthread_start + 286
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 10:: FileIOThread 3
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 11:: FileIOThread 2
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 12:: FileIOThread 1
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 13:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fffc770deb6 __select + 10
1 com.apple.CoreFoundation 0x00007fffb1e1a5ba __CFSocketManager + 682
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 14:
1 com.apple.logic10 0x0000000104ac9aca 0x1038c5000 + 18893514
2 com.apple.logic10 0x0000000104701e5d 0x1038c5000 + 14929501
3 libsystem_pthread.dylib 0x00007fffc77f893b _pthread_body + 180
4 libsystem_pthread.dylib 0x00007fffc77f8887 _pthread_start + 286
5 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 15:: CVDisplayLink
2 com.apple.CoreVideo 0x00007fffb349a977 CVDisplayLink::waitUntil(unsigned long long) + 233
3 com.apple.CoreVideo 0x00007fffb349a762 CVDisplayLink::runIOThread() + 520
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 16:: MetronomeUItriggerThread
1 com.apple.logic10 0x00000001039fec13 0x1038c5000 + 1285139
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 17:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x00007fffb1948935 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 127
3 com.apple.audio.CoreAudio 0x00007fffb19488a6 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x00007fffb19458d0 HALC_ProxyIOContext::IOWorkLoop() + 1196
5 com.apple.audio.CoreAudio 0x00007fffb1945264 HALC_ProxyIOContext::IOThreadEntry(void*) + 128
6 com.apple.audio.CoreAudio 0x00007fffb1944fa3 HALB_IOThread::Entry(void*) + 75
9 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 18:: com.apple.audio.IOThread.client
9 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 19:: ProcessThread1/2048
1 com.apple.music.apps.MAAudioEngine 0x0000000108379595 MD::CallProcessThread(long) + 613
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 20:: ProcessThread2/2048
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 21:: ProcessThread3/2048
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 22:: ProcessThread4/2048
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 23:: ProcessThread5/2048
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 24:: ProcessThread6/2048
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 25:: ProcessThread7/2048
4 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 26:: CVDisplayLink
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 27:
2 libc++.1.dylib 0x00007fffc6123572 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 126
3 com.paceap.eden.WrapPersist 0x000000015c60f572 0x15c41c000 + 2045298
4 com.paceap.eden.WrapPersist 0x000000015c6169b1 0x15c41c000 + 2075057
5 com.paceap.eden.WrapPersist 0x000000015c616938 0x15c41c000 + 2074936
6 com.paceap.eden.WrapPersist 0x000000015c61680d 0x15c41c000 + 2074637
9 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 28:: Dispatch queue: com.apple.coremedia.surrogatePlaybackItem[0x610000139fa0]
2 com.apple.SkyLight 0x00007fffc391d69f _CGSGetWindowOwner + 132
3 com.apple.SkyLight 0x00007fffc3a7636d window_update_rights_cache + 74
4 com.apple.SkyLight 0x00007fffc389a761 SLSReleaseConnection + 155
5 com.apple.AppleGVAFramework 0x00007fffbb0f4af8 0x7fffbb0b6000 + 256760
6 com.apple.AppleGVAFramework 0x00007fffbb0f6e7e 0x7fffbb0b6000 + 265854
7 com.apple.VideoToolbox 0x00007fffb88aaba3 0x7fffb8803000 + 687011
8 com.apple.CoreMedia 0x00007fffb2b24a1f FigBaseObjectFinalize + 73
9 com.apple.CoreFoundation 0x00007fffb1eac123 _CFRelease + 291
10 com.apple.VideoToolbox 0x00007fffb880b89b VTDecompressionSessionInvalidate + 94
11 com.apple.MediaToolbox 0x00007fffb51a94c8 0x7fffb5142000 + 423112
12 com.apple.MediaToolbox 0x00007fffb51a91ab VMC2Invalidate + 103
13 com.apple.MediaToolbox 0x00007fffb527c908 0x7fffb5142000 + 1288456
14 com.apple.MediaToolbox 0x00007fffb527c9fb 0x7fffb5142000 + 1288699
15 com.apple.CoreMedia 0x00007fffb2b24a1f FigBaseObjectFinalize + 73
16 com.apple.CoreFoundation 0x00007fffb1eac123 _CFRelease + 291
17 com.apple.MediaToolbox 0x00007fffb5187b33 FigPlayabilityMonitorSetRenderPipelines + 124
18 com.apple.MediaToolbox 0x00007fffb52186f3 0x7fffb5142000 + 878323
19 com.apple.MediaToolbox 0x00007fffb5217ca8 0x7fffb5142000 + 875688
20 com.apple.MediaToolbox 0x00007fffb5226d20 0x7fffb5142000 + 937248
21 com.apple.MediaToolbox 0x00007fffb5228c68 0x7fffb5142000 + 945256
22 libdispatch.dylib 0x00007fffc75a98fc _dispatch_client_callout + 8
23 libdispatch.dylib 0x00007fffc75aa536 _dispatch_barrier_sync_f_invoke + 83
24 com.apple.MediaToolbox 0x00007fffb546b0ed 0x7fffb5142000 + 3313901
25 com.apple.MediaToolbox 0x00007fffb52fbc7c 0x7fffb5142000 + 1809532
26 com.apple.MediaToolbox 0x00007fffb5202f9b 0x7fffb5142000 + 790427
27 com.apple.CoreMedia 0x00007fffb2bb6230 FigCFWeakReferenceTableApplyFunction + 294
28 com.apple.MediaToolbox 0x00007fffb5202c37 0x7fffb5142000 + 789559
29 libdispatch.dylib 0x00007fffc75a98fc _dispatch_client_callout + 8
30 libdispatch.dylib 0x00007fffc75bf9a0 _dispatch_queue_serial_drain + 896
31 libdispatch.dylib 0x00007fffc75b2306 _dispatch_queue_invoke + 1046
32 libdispatch.dylib 0x00007fffc75b8020 _dispatch_queue_override_invoke + 369
33 libdispatch.dylib 0x00007fffc75ab6b5 _dispatch_root_queue_drain + 476
34 libdispatch.dylib 0x00007fffc75ab48c _dispatch_worker_thread3 + 99
35 libsystem_pthread.dylib 0x00007fffc77f85a2 _pthread_wqthread + 1299
36 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 29:: JUCE Timer
3 com.eventide.spliteq 0x000000015ae7a5d6 0x15ac08000 + 2565590
4 com.eventide.spliteq 0x000000015aeb18b8 0x15ac08000 + 2791608
5 com.eventide.spliteq 0x000000015ae839d9 0x15ac08000 + 2603481
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 30:
0 libsystem_kernel.dylib 0x00007fffc770e44e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fffc77f8621 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 31:: com.apple.coremedia.imagequeue.coreanimation
2 com.apple.CoreMedia 0x00007fffb2b611bb WaitOnCondition + 14
3 com.apple.CoreMedia 0x00007fffb2b60e45 FigSemaphoreWaitRelative + 153
4 com.apple.MediaToolbox 0x00007fffb534e352 0x7fffb5142000 + 2147154
5 com.apple.CoreMedia 0x00007fffb2b61b5a figThreadMain + 277
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 32:: com.apple.coremedia.videomediaconverter
4 com.apple.MediaToolbox 0x00007fffb534bab6 0x7fffb5142000 + 2136758
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 33:: com.apple.coremedia.vtremotedecompressionclient.notifier
2 com.apple.VideoToolbox 0x00007fffb88af150 0x7fffb8803000 + 704848
3 com.apple.CoreMedia 0x00007fffb2b61b5a figThreadMain + 277
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 34:: com.apple.coremedia.scheduledfileio
4 com.apple.CoreMedia 0x00007fffb2b58183 FigScheduledFileIOThread + 141
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 35:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 36:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 37:: com.apple.coremedia.vtremotedecompressionclient.notifier
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 38:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 39:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 40:
2 com.apple.AppleGVAFramework 0x00007fffbb0ef632 0x7fffbb0b6000 + 235058
3 com.apple.AppleGVAFramework 0x00007fffbb0ef561 0x7fffbb0b6000 + 234849
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 41:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 42:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 43:: com.apple.coremedia.vtremotedecompressionclient.notifier
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 44:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 45:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 46:
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 47:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 48:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 49:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 50:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 51:
6 libsystem_pthread.dylib 0x00007fffc77f808d thread_start + 13Thread 52:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 53:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 54:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 55:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 56:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 57:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 58:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 59:: Dispatch queue: NSCGSDisableUpdates
2 com.apple.SkyLight 0x00007fffc391ca96 _CGSReenableUpdateForConnectionSync + 99
3 com.apple.SkyLight 0x00007fffc39293d0 CGSUpdateManager::enable_update(unsigned long long) + 532
4 libdispatch.dylib 0x00007fffc75b2524 _dispatch_call_block_and_release + 12
6 libdispatch.dylib 0x00007fffc75bf9a0 _dispatch_queue_serial_drain + 896
7 libdispatch.dylib 0x00007fffc75b2306 _dispatch_queue_invoke + 1046
8 libdispatch.dylib 0x00007fffc75b8020 _dispatch_queue_override_invoke + 369
9 libdispatch.dylib 0x00007fffc75ab6b5 _dispatch_root_queue_drain + 476
10 libdispatch.dylib 0x00007fffc75ab48c _dispatch_worker_thread3 + 99
11 libsystem_pthread.dylib 0x00007fffc77f85a2 _pthread_wqthread + 1299
12 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 60:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 61:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 62:
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 63:
1 libsystem_pthread.dylib 0x00007fffc77f848e _pthread_wqthread + 1023
2 libsystem_pthread.dylib 0x00007fffc77f807d start_wqthread + 13Thread 64:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff5c338d88 rdx: 0x0000000000000000
rdi: 0x0000000000000307 rsi: 0x0000000000000006 rbp: 0x00007fff5c338db0 rsp: 0x00007fff5c338d88
r8: 0x00007fffc769c650 r9: 0x00007fffc765ea50 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x00007fff5c338f10 r13: 0x0000000000000030 r14: 0x00007fffd05023c0 r15: 0x0000000000000008
rip: 0x00007fffc770dd42 rfl: 0x0000000000000206 cr2: 0x00007fffd04e4128Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133Binary Images:
0x1038c5000 – 0x10555efef com.apple.logic10 (10.4.3 – 4980.97) <1105C137-0178-37D8-88EE-9A77E6BA1199> /Applications/Logic Pro X.app/Contents/MacOS/Logic Pro X
0x105d1a000 – 0x1061e2fff com.apple.music.apps.MALogicLegacySong (10.3.2 – 4980.97) <BAD40C18-57FB-3720-882C-080EF604EAD4> /Applications/Logic Pro X.app/Contents/Frameworks/MALogicLegacySong.framework/Versions/A/MALogicLegacySong
0x1062c9000 – 0x1062cbfff com.apple.music.apps.MAResourcesPlugInsShared (10.3.2 – 4980.97) <594568E3-AE7B-3C8C-B824-A7A5677AEA9C> /Applications/Logic Pro X.app/Contents/Frameworks/MAResourcesPlugInsShared.framework/Versions/A/MAResourcesPlugInsShared
0x1062d2000 – 0x1062e9ff3 com.apple.music.apps.MAAudioUnitSupport (10.3.2 – 4980.97) <8612C7E4-38D7-3DE6-B722-E6704B35C1C2> /Applications/Logic Pro X.app/Contents/Frameworks/MAAudioUnitSupport.framework/Versions/A/MAAudioUnitSupport
0x1062f8000 – 0x106337fff com.apple.iTunesLibrary (12.8 – 12.8.0) <98FDEE03-6BF5-3164-A7C0-7297E42D0D29> /Library/Frameworks/iTunesLibrary.framework/Versions/A/iTunesLibrary
0x106366000 – 0x1063adff7 com.apple.music.apps.MALoopManagement (10.3.2 – 4980.97) <84F4ECCA-2C8D-3830-A51E-E0A8A49DF676> /Applications/Logic Pro X.app/Contents/Frameworks/MALoopManagement.framework/Versions/A/MALoopManagement
0x1063d7000 – 0x106644fff com.apple.music.apps.MACore (10.3.2 – 4980.97) <3B71E1B9-CA01-3E71-AF5B-06315F6A5F3F> /Applications/Logic Pro X.app/Contents/Frameworks/MACore.framework/Versions/A/MACore
0x1067a8000 – 0x1067e6ff7 com.apple.audio.midi.CoreMIDI (1.10 – 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x10680f000 – 0x106955ffb com.apple.music.apps.MAVectorUIKit (10.3.2 – 4980.97) <D8DF36B3-CA44-384B-A370-1B1ADA4812A5> /Applications/Logic Pro X.app/Contents/Frameworks/MAVectorUIKit.framework/Versions/A/MAVectorUIKit
0x1069ca000 – 0x106aedfff com.apple.music.apps.MAHarmony (10.3.2 – 4980.97) <63709F1C-EE84-3916-8B9E-817605122DF6> /Applications/Logic Pro X.app/Contents/Frameworks/MAHarmony.framework/Versions/A/MAHarmony
0x106b2c000 – 0x106c5efff com.apple.music.apps.OMF (10.3.2 – 4980.97) <F4BFF38E-E25E-3B6D-90C8-D3CF360B1E00> /Applications/Logic Pro X.app/Contents/Frameworks/OMF.framework/Versions/A/OMF
0x106c88000 – 0x107807fff com.apple.music.apps.MADSP (10.3.2 – 4980.97) <A6A8B89C-67D4-3D66-8DB9-2A86C30E0E70> /Applications/Logic Pro X.app/Contents/Frameworks/MADSP.framework/Versions/A/MADSP
0x108151000 – 0x108155ff7 com.apple.music.apps.MAResources (10.3.2 – 4980.97) <8E5E62ED-A429-32CC-9886-2AF4952C3186> /Applications/Logic Pro X.app/Contents/Frameworks/MAResources.framework/Versions/A/MAResources
0x10815e000 – 0x1081baff7 com.apple.audio.CoreAudioKit (1.6.6 – 1.6.6) <DD6F8D1F-69EE-335A-8654-72B24E25423D> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x108207000 – 0x1082f2fff com.apple.music.apps.MAFiles (10.3.2 – 4980.97) <113A9017-1F91-3561-B016-EA7CBF2C4674> /Applications/Logic Pro X.app/Contents/Frameworks/MAFiles.framework/Versions/A/MAFiles
0x10833c000 – 0x108488ff7 com.apple.music.apps.MAAudioEngine (10.3.2 – 4980.97) <E39C12AE-C22D-3789-A6FF-DD882E66A825> /Applications/Logic Pro X.app/Contents/Frameworks/MAAudioEngine.framework/Versions/A/MAAudioEngine
0x10864a000 – 0x108d81fff com.apple.music.apps.MAPlugInGUI (10.3.2 – 4980.97) <557F402B-CD07-3F29-9723-66C282436E6E> /Applications/Logic Pro X.app/Contents/Frameworks/MAPlugInGUI.framework/Versions/A/MAPlugInGUI
0x1090e7000 – 0x1093f2fff com.apple.music.apps.MAMusicAnalysis (10.3.2 – 4980.97) <2DCDEB61-F9B6-3228-A737-86E4DB3EE3BA> /Applications/Logic Pro X.app/Contents/Frameworks/MAMusicAnalysis.framework/Versions/A/MAMusicAnalysis
0x109471000 – 0x10949affb com.apple.music.apps.MAVideo (10.3.2 – 4980.97) <D660AD37-9A09-3973-B10F-F19F60153BB1> /Applications/Logic Pro X.app/Contents/Frameworks/MAVideo.framework/Versions/A/MAVideo
0x1094b0000 – 0x10989bff7 com.apple.LogicUIKit (10.3.2 – 4980.97) <B632BEDB-88D5-3042-88FF-7CA3CDB1070D> /Applications/Logic Pro X.app/Contents/Frameworks/MAToolKit.framework/Versions/A/MAToolKit
0x109a00000 – 0x109eb3fff com.apple.music.apps.Animal (10.3.2 – 4980.97) <2D57B24D-1AED-348C-A6FA-4AC17D39FCD8> /Applications/Logic Pro X.app/Contents/Frameworks/Animal.framework/Versions/A/Animal
0x10a0f7000 – 0x10a11effb com.apple.music.apps.MALoopBrowser (10.3.2 – 4980.97) <4F3D1922-5C3C-3209-AF1E-B2055EBCF961> /Applications/Logic Pro X.app/Contents/Frameworks/MALoopBrowser.framework/Versions/A/MALoopBrowser
0x10a133000 – 0x10a23fff7 com.apple.music.apps.MAWorkspace (10.3.2 – 4980.97) <8E87A015-E3F5-33EA-9C2B-B4F8C3C7E3B6> /Applications/Logic Pro X.app/Contents/Frameworks/MAWorkspace.framework/Versions/A/MAWorkspace
0x10a2a8000 – 0x10a2f9ffb com.apple.LogicUIKitHighLevel (10.3.2 – 4980.97) <D70D0466-1CF9-3F23-BF73-221678D1D925> /Applications/Logic Pro X.app/Contents/Frameworks/MAToolKitHighLevel.framework/Versions/A/MAToolKitHighLevel
0x10a327000 – 0x10a329ff3 com.apple.music.apps.MAResourcesLg (10.3.2 – 4980.97) <95B4D218-8A82-3CE9-ACE1-BC35D6F932D4> /Applications/Logic Pro X.app/Contents/Frameworks/MAResourcesLg.framework/Versions/A/MAResourcesLg
0x10a32e000 – 0x10a330ff3 com.apple.music.apps.MAContentDownloading (10.3.2 – 4980.97) <3270EFEA-E651-3D76-BD1E-1DB5B5A81C9D> /Applications/Logic Pro X.app/Contents/Frameworks/MAContentDownloading.framework/Versions/A/MAContentDownloading
0x10a336000 – 0x10a345fff +com.nxtbgthng.OAuth2Client (1.1.0 – 4980.97) <D703F52B-6D8D-3A0F-903D-FC9B0F06E923> /Applications/Logic Pro X.app/Contents/Frameworks/OAuth2Client.framework/Versions/A/OAuth2Client
0x10a354000 – 0x10a357ffb +com.yourcompany.SoundCloudAPI (2.0b6 – 4980.97) <D8B5877D-D16E-3ED0-A6BD-FCAB55E48AF8> /Applications/Logic Pro X.app/Contents/Frameworks/SoundCloudAPI.framework/Versions/A/SoundCloudAPI
0x10a35f000 – 0x10a361ff3 com.apple.music.apps.MAResourcesGB (10.3.2 – 4980.97) <0A2C766A-2C48-3C2D-8B44-601650D813F9> /Applications/Logic Pro X.app/Contents/Frameworks/MAResourcesGB.framework/Versions/A/MAResourcesGB
0x10a369000 – 0x10a382fff libexpat.1.dylib (15.1) <588CA992-60BB-363B-BEE7-3CC0A26C1AFA> /usr/lib/libexpat.1.dylib
0x10a38d000 – 0x10a55efc0 com.apple.mobiledevice (1253.100.28.100.2 – 1253.100.28.100.2) <AEDEF315-51B0-327D-B6C9-CEA8617DB513> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x10a621000 – 0x10a74dff7 com.apple.AudioVideoBridging (506.1 – 506.1) <ABFF7D29-9D86-37CD-9F05-2D5388ECDA09> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x10a806000 – 0x10a81aff3 com.apple.AudioServerApplication (1.0 – 200.9) <4977039B-FC27-3D6E-9B3E-81B3071ADBB3> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
0x10a82d000 – 0x10a83cfff com.apple.TimeSync (1.0 – 503.1) <D06817FE-7DEC-3F8C-9484-2EA4CFBC0889> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x10a851000 – 0x10aff1ff7 com.apple.music.apps.MAAlchemy (10.3.2 – 4980.97) <55B6ABFF-E42E-3EE5-9649-DC3C374EB468> /Applications/Logic Pro X.app/Contents/Frameworks/MAAlchemy.framework/Versions/A/MAAlchemy
0x10b26f000 – 0x10b2afff3 libpcre.0.dylib (9) <B3E07AF3-5DF9-3BBD-9ADD-A697B433BA36> /usr/lib/libpcre.0.dylib
0x10b2bc000 – 0x10b2f5fff com.apple.MAGFFoundation (1.0 – 4980.97) <31639176-8CFA-3758-A079-0B49633FE215> /Applications/Logic Pro X.app/Contents/Frameworks/MAGFFoundation.framework/Versions/A/MAGFFoundation
0x10d9b0000 – 0x10da93ff3 +com.celemony.melodyne.au (5.1.1 – 5.1.1.003) <9E0C585B-36C2-3E68-BCE2-428E59590492> /Library/Audio/Plug-Ins/Components/Melodyne.component/Contents/MacOS/Melodyne
0x10db04000 – 0x10db1eff7 com.apple.security.csparser (3.0 – 57740.60.26) <9237B0D6-50BD-32DE-B702-299CC0A0391C> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x10fc89000 – 0x10fc8bfff com.apple.music.apps.midi.device.plugin.GiO (10.3.2 – 4980.97) <C76257AE-4018-325A-83C7-0A5A4AC9F142> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/GiO.bundle/Contents/MacOS/GiO
0x110110000 – 0x110112fff com.apple.music.apps.midi.device.plugin.CS-32 (10.3.2 – 4980.97) <ABB99E2D-C44B-3262-B329-3DE519EC9941> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/CS-32.bundle/Contents/MacOS/CS-32
0x110132000 – 0x1101f8ffb com.apple.AMDRadeonX4000GLDriver (1.54.1 – 1.5.4) <7214A45C-831D-3E61-83B6-34CBE1B867FB> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x110212000 – 0x11023cfff GLRendererFloat (14.0.16) <F17BA0F2-3ACE-3B59-B713-3FA64A88329E> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x110469000 – 0x11046afff com.apple.music.apps.midi.device.plugin.MCS3 (10.3.2 – 4980.97) <100E42AD-26E0-38D7-ADDA-CA275C8DDEF1> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/MCS3.bundle/Contents/MacOS/MCS3
0x110570000 – 0x110572ff3 com.apple.music.apps.midi.device.plugin.iControl (10.3.2 – 4980.97) <950A2D75-7558-3F8B-98A4-5B24492E9B93> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/iControl.bundle/Contents/MacOS/iControl
0x110578000 – 0x110578ff7 com.apple.music.apps.midi.device.plugin.Recording-Light (10.3.2 – 4980.97) <16DCC2E6-62A0-3DC9-95D8-EE49A51FA4CC> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/Recording Light.bundle/Contents/MacOS/Recording Light
0x110691000 – 0x110694ff3 com.apple.music.apps.midi.device.plugin.microKONTROL (10.3.2 – 4980.97) <1B4A7FFD-ED41-3621-88F2-BD5ABF679AA0> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/microKONTROL.bundle/Contents/MacOS/microKONTROL
0x1107a5000 – 0x1107a8fff com.apple.music.apps.midi.device.plugin.TranzPort (10.3.2 – 4980.97) <185EAA26-6E22-3225-8774-78B7A234591E> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/TranzPort.bundle/Contents/MacOS/TranzPort
0x110d94000 – 0x110d99ff3 com.apple.music.apps.midi.device.plugin.US-2400 (10.3.2 – 4980.97) <EE53684C-9F05-3D77-8552-135BEBD04A27> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/US-2400.bundle/Contents/MacOS/US-2400
0x110f7b000 – 0x110f7ffff com.apple.audio.AppleHDAHALPlugIn (279.48 – 279.48) <ECA84145-2AC4-347D-BBC0-933AAAC15356> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x110f97000 – 0x110fd4dc7 dyld (434) <33DB4E37-BC29-37A4-92AB-30328E66A8FA> /usr/lib/dyld
0x111cf7000 – 0x111d3eff3 +com.izotope.AU.RXPROMUSICREBLNC (8.3.0 – 8.3.0.789) <9EADF414-BE7B-30F7-A2B2-0F682DC3BE03> /Library/Audio/Plug-Ins/Components/iZRXProMusicRebalanceARAAUHook.component/Contents/MacOS/PluginHooksAU
0x1129a9000 – 0x1129acffb com.apple.music.apps.midi.device.plugin.TouchOSC (10.3.2 – 4980.97) <3593D208-F7BE-302C-9307-CB4C1DC22742> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/TouchOSC.bundle/Contents/MacOS/TouchOSC
0x113a47000 – 0x113c6dffb +com.audiomovers.listento (1.03.20200416 – 1.03.20200416) <6083B446-2F42-351A-B077-CC1716252478> /Library/Audio/Plug-Ins/Components/Listento.component/Contents/MacOS/Listento
0x113d48000 – 0x113d76fff +libsoxr.0.1.1.dylib (0) <07159124-834E-33F1-B4D5-7A6722AEC75E> /Library/Audio/Plug-Ins/Components/Listento.component/Contents/MacOS/libsoxr.0.1.1.dylib
0x113db6000 – 0x11412eff7 com.apple.audio.codecs.Components (7.0 – 7.0) <6550F01F-BDB0-389B-8148-DC1B52B41E8D> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x11420c000 – 0x114255fff +com.arturia.component.MiniFilter-V (65536 – 65536) <73D977DC-5409-3ADE-9A85-EDD5FFEDB302> /Library/Audio/Plug-Ins/Components/MiniFilter V.component/Contents/MacOS/MiniFilter V
0x1142a1000 – 0x1150c5fc7 +com.Arturia.MiniFilter-V.vst3 (1.0.0.116 – 1.0.0.116) <D18DB609-C1C9-33EF-A398-88BDEA912F29> /Library/Audio/Plug-Ins/Components/MiniFilter V.component/Contents/Resources/plugin.vst3/Contents/MacOS/MiniFilter V
0x115670000 – 0x115674ff7 com.apple.music.apps.midi.device.plugin.Logic-Remote (10.3.2 – 4980.97) <4E87625B-7AA2-3565-8587-2D1D689EF1DA> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/Logic Remote.bundle/Contents/MacOS/Logic Remote
0x115685000 – 0x11568affb com.apple.music.apps.midi.device.plugin.HUI (10.3.2 – 4980.97) <00E6AE06-B4F9-334C-8A6D-174493167457> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/HUI.bundle/Contents/MacOS/HUI
0x115eda000 – 0x116080fff GLEngine (14.0.16) <E9D6F955-A48F-3757-8D8A-33D868835AEB> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x1160bf000 – 0x116b14ff7 com.apple.driver.AppleIntelSKLGraphicsGLDriver (10.25.21 – 10.2.5) <CB129B3C-7FE2-3F3A-9179-0E84A559555C> /System/Library/Extensions/AppleIntelSKLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsGLDriver
0x116e43000 – 0x117381ff3 ATIRadeonX4000SCLib.dylib (1.54.1) <75D63591-F71A-3DCE-B159-9519F9E2C6A7> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x117420000 – 0x1174aeff7 com.apple.driver.AppleIntelSKLGraphicsMTLDriver (10.25.21 – 10.2.5) <1C824362-D276-342B-9F88-947A7FCD832A> /System/Library/Extensions/AppleIntelSKLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsMTLDriver
0x118cdd000 – 0x118cf4ff3 com.apple.music.apps.midi.device.plugin.Logic-Control (10.3.2 – 4980.97) <56BBAD7D-77CF-37D8-9540-BB235B1690DD> /Applications/Logic Pro X.app/Contents/MIDI Device Plug-ins/Logic Control.bundle/Contents/MacOS/Logic Control
0x1191f6000 – 0x1191f8fff com.apple.music.apps.anvil.resources (10.3.2 – 4980.97) <66569D6E-3DED-37AC-B19B-ED0B85DDE42A> /Applications/Logic Pro X.app/Contents/PlugIns/anvil.res/Contents/MacOS/anvil
0x1196c6000 – 0x1196cbff3 libgermantok.dylib (17) <35A589D9-5F0E-31D7-9188-37237CC471EC> /usr/lib/libgermantok.dylib
0x11a0cf000 – 0x11a0d1fff com.apple.music.apps.common.resources (10.3.2 – 4980.97) <568CD548-4E9B-3957-9B37-143D3CCDABF3> /Applications/Logic Pro X.app/Contents/PlugIns/common.res/Contents/MacOS/common
0x11a0d7000 – 0x11a0d9ff3 com.apple.music.apps.ebp.resources (10.3.2 – 4980.97) <AFF7D32C-B3BA-3DDB-A3EE-AD77341EEA6F> /Applications/Logic Pro X.app/Contents/PlugIns/ebp.res/Contents/MacOS/ebp
0x11a0df000 – 0x11a0e1ff3 com.apple.music.apps.efx.resources (10.3.2 – 4980.97) <E9CD5159-E060-32BC-88FC-172C1D0E1D80> /Applications/Logic Pro X.app/Contents/PlugIns/efx.res/Contents/MacOS/efx
0x11a12a000 – 0x11a12cff3 com.apple.music.apps.egt.resources (10.3.2 – 4980.97) <9A71FD06-00A7-3510-9A93-A590A4BEC155> /Applications/Logic Pro X.app/Contents/PlugIns/egt.res/Contents/MacOS/egt
0x11a338000 – 0x11a33aff3 com.apple.music.apps.emx.resources (10.3.2 – 4980.97) <5A778263-A741-391B-BFAF-3E9C06A41E00> /Applications/Logic Pro X.app/Contents/PlugIns/emx.res/Contents/MacOS/emx
0x11a34c000 – 0x11a34eff3 com.apple.music.apps.es1.resources (10.3.2 – 4980.97) <07CB503D-0FE7-3AB1-8DE1-3EB87BE14829> /Applications/Logic Pro X.app/Contents/PlugIns/es1.res/Contents/MacOS/es1
0x11a357000 – 0x11a359ff3 com.apple.music.apps.es2.resources (10.3.2 – 4980.97) <D4B2FE32-C594-38D5-99FF-CFEE9DB896FD> /Applications/Logic Pro X.app/Contents/PlugIns/es2.res/Contents/MacOS/es2
0x11a35f000 – 0x11a361ff3 com.apple.music.apps.esp.resources (10.3.2 – 4980.97) <906BE991-A4F3-3A8C-BC00-1BD0FC87C189> /Applications/Logic Pro X.app/Contents/PlugIns/esp.res/Contents/MacOS/esp
0x11a367000 – 0x11a369ff3 com.apple.music.apps.evb3.resources (10.3.2 – 4980.97) <5892D3E0-3DDF-3A58-B303-AD7C198593DE> /Applications/Logic Pro X.app/Contents/PlugIns/evb3.res/Contents/MacOS/evb3
0x11a36f000 – 0x11a371ff3 com.apple.music.apps.evd6.resources (10.3.2 – 4980.97) <C7F861AD-AD00-3E03-B1E8-8C9F310C44BF> /Applications/Logic Pro X.app/Contents/PlugIns/evd6.res/Contents/MacOS/evd6
0x11a377000 – 0x11a379ff3 com.apple.music.apps.evoc.resources (10.3.2 – 4980.97) <F02E959C-0584-3379-B954-D6C6B079E175> /Applications/Logic Pro X.app/Contents/PlugIns/evoc.res/Contents/MacOS/evoc
0x11a37f000 – 0x11a381fff com.apple.music.apps.evp88.resources (10.3.2 – 4980.97) <0B967414-FD73-36A3-B776-89B8B0D0F3A4> /Applications/Logic Pro X.app/Contents/PlugIns/evp88.res/Contents/MacOS/evp88
0x11a387000 – 0x11a389fff com.apple.music.apps.exs24.resources (10.3.2 – 4980.97) <D87491AF-5265-3C45-AD4E-60A2169C94DE> /Applications/Logic Pro X.app/Contents/PlugIns/exs24.res/Contents/MacOS/exs24
0x11a38f000 – 0x11a391fff com.apple.music.apps.guitarcontrols.resources (10.3.2 – 4980.97) <E8CC91A1-DB8B-3057-AA32-F27953E08180> /Applications/Logic Pro X.app/Contents/PlugIns/guitarcontrols.res/Contents/MacOS/guitarcontrols
0x11a397000 – 0x11a399fff com.apple.music.apps.mutapdel.resources (10.3.2 – 4980.97) <DF5803C6-CE41-3E3E-860E-711068B73A65> /Applications/Logic Pro X.app/Contents/PlugIns/mutapdel.res/Contents/MacOS/mutapdel
0x11a39f000 – 0x11a3a1ff3 com.apple.music.apps.pedalboard.resources (10.3.2 – 4980.97) <9E44AA37-00EF-3623-B4BC-C943BAEDC067> /Applications/Logic Pro X.app/Contents/PlugIns/pedalboard.res/Contents/MacOS/pedalboard
0x11a3a7000 – 0x11a3a9fff com.apple.music.apps.revolver.resources (10.3.2 – 4980.97) <3EFE49B8-EBA7-3EAC-946B-D64F639ECD3C> /Applications/Logic Pro X.app/Contents/PlugIns/revolver.res/Contents/MacOS/revolver
0x11a3f2000 – 0x11a3f4fff com.apple.music.apps.sphere.resources (10.3.2 – 4980.97) <9A68FB82-60BC-3CFF-9F45-3C764ACB7419> /Applications/Logic Pro X.app/Contents/PlugIns/sphere.res/Contents/MacOS/sphere
0x11b8d6000 – 0x11baefff3 +com.audiomovers.listento-recv (1.03.20200416 – 1.03.20200416) <FA06AB91-29F7-3A9C-976C-6A01E5E7119D> /Library/Audio/Plug-Ins/Components/Listento-Receiver.component/Contents/MacOS/Listento-Receiver
0x11bbca000 – 0x11bbf8fff +libsoxr.0.1.1.dylib (0) <07159124-834E-33F1-B4D5-7A6722AEC75E> /Library/Audio/Plug-Ins/Components/Listento-Receiver.component/Contents/MacOS/libsoxr.0.1.1.dylib
0x11cecc000 – 0x11ee53fe7 +com.izotope.RXPROMUSICREBLNC_ARA (8.3.0 – 8.3.0.789) <43E8FE39-7695-3420-BF30-BE9981539366> /Library/Audio/Plug-Ins/Components/iZRXProMusicRebalanceARAAUHook.component/Contents/Resources/iZRXProMusicRebalanceARA.bundle/Contents/MacOS/iZRXProMusicRebalanceARA
0x128b98000 – 0x12affe57f +com.celemony.melodyne.shared (5.1.1 – 5.1.1.003) <42E71906-2356-38BB-83DB-2B276C007C3A> /Library/Application Support/Celemony/*/MelodyneCore
0x13da8b000 – 0x13da8dfff com.apple.AppleIntelSKLGraphicsVAME (10.25.21 – 10.2.5) <E7F9A868-BA86-3AFC-A3CB-4BD77D9D7BDE> /System/Library/Extensions/AppleIntelSKLGraphicsVAME.bundle/Contents/MacOS/AppleIntelSKLGraphicsVAME
0x14c01b000 – 0x14c09afff com.apple. AMDRadeonVADriver (1.54.1 – 1.5.4) <78A91FAA-DC1B-3EAC-9357-749968AC1FA4> /System/Library/Extensions/AMDRadeonVADriver.bundle/Contents/MacOS/AMDRadeonVADriver
0x14dc63000 – 0x14dc83fff com.apple.CoreNLP (1.0 – 78.2) <B686BDA2-A162-3D70-9257-FEB0592DBD7E> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x15ac08000 – 0x15be67ffb +com.eventide.spliteq (1.0.4 – 1.0.4) <CBBB614F-70C3-3AF7-91C6-87A3B5819482> /Library/Audio/Plug-Ins/Components/SplitEQ.component/Contents/MacOS/SplitEQ
0x15c41c000 – 0x15c70bff7 +com.paceap.eden.WrapPersist (5.3.2 GM [b3151, 04dfd8e080] – 5.3.2.3151) <3873B07E-583F-32C3-BDB0-52562FC7CB2B> /Library/Frameworks/PACEEdenExperience.framework/Versions/Current/WrapPersist.bundle/Contents/MacOS/WrapPersist
0x16537d000 – 0x1655e1fff com.apple.AppleIntelSKLGraphicsVADriver (10.25.21 – 10.2.5) <90C1FB58-EC0B-36EE-B085-CAFED71CCC63> /System/Library/Extensions/AppleIntelSKLGraphicsVADriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsVADriver
0x7fffaca06000 – 0x7fffacd4bff7 com.apple.RawCamera.bundle (7.04 – 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fffacd4c000 – 0x7ffface7dff3 com.apple.AMDMTLBronzeDriver (1.54.1 – 1.5.4) <A4F4A70B-FD31-3E92-B802-411B031EBB7A> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fffae57b000 – 0x7fffae57fffb com.apple.agl (3.3.1 – AGL-3.3.1) <2FDA8B53-0223-3654-85CE-4A5AFDDA191F> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fffae580000 – 0x7fffae741fff com.apple.avfoundation (2.0 – 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fffae742000 – 0x7fffae7e4ff7 com.apple.audio.AVFAudio (1.0 – ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fffae7e5000 – 0x7fffae8aeff3 com.apple.AVKit (1.1 – 356.12) <1A0929CC-BD23-377D-8A22-6C092409AA9D> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
0x7fffae8af000 – 0x7fffae8affff com.apple.Accelerate (1.11 – Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fffae8b0000 – 0x7fffae8c7ffb libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fffae8c8000 – 0x7fffaede1feb com.apple.vImage (8.1 – ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fffaede2000 – 0x7fffaef53ff3 libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fffaef54000 – 0x7fffaef68ffb libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fffaef69000 – 0x7fffaf35ffef libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fffaf360000 – 0x7fffaf376fff libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fffaf377000 – 0x7fffaf37dfff libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fffaf37e000 – 0x7fffaf392ff7 libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fffaf393000 – 0x7fffaf51afe7 libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fffaf51b000 – 0x7fffaf5cdfff libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fffaf5ce000 – 0x7fffaf5cefff com.apple.Accelerate.vecLib (3.11 – vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fffaf5cf000 – 0x7fffaf60cffb com.apple.Accounts (113 – 113) <8550BD08-7D05-3AC4-A0CC-B67ECB2DE950> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fffaf60d000 – 0x7fffaf88cff7 com.apple.AddressBook.framework (10.0 – 1756.20) <E512B69B-8DBE-3085-95BE-750B8EFC97FD> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fffaf88d000 – 0x7fffb0666ff3 com.apple.AppKit (6.9 – 1504.83.101) <3ACDFF37-A5C2-3235-B272-1DD528245A6D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fffb0678000 – 0x7fffb0678fff com.apple.ApplicationServices (48 – 48) <81488826-9260-339A-B5FF-916194241ED3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fffb0679000 – 0x7fffb06e7ff7 com.apple.ApplicationServices.ATS (377 – 422.4) <7386D298-C65B-3FE8-B4F8-1A1C26F662F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fffb0781000 – 0x7fffb08b0fff libFontParser.dylib (194.14) <35E2D4A9-8B28-33FB-8C60-8F57D249F6B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fffb08b1000 – 0x7fffb08fbff7 libFontRegistry.dylib (196.8) <5E5F95FD-F69B-3F1A-9592-C0AB8F5FF57C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fffb0959000 – 0x7fffb098cfff libTrueTypeScaler.dylib (194.14) <33F2CEAE-7915-3739-AC1F-0F4CC4408F08> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fffb09f9000 – 0x7fffb0aa3ff7 com.apple.ColorSync (4.12.0 – 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fffb0aa4000 – 0x7fffb0af5fff com.apple.HIServices (1.22 – 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fffb0af6000 – 0x7fffb0b05ff3 com.apple.LangAnalysis (1.7.0 – 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fffb0b06000 – 0x7fffb0b53fff com.apple.print.framework.PrintCore (12 – 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fffb0b54000 – 0x7fffb0b8ffff com.apple.QD (3.12 – 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fffb0b90000 – 0x7fffb0b9bfff com.apple.speech.synthesis.framework (6.6.2 – 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fffb0b9c000 – 0x7fffb0da8ff7 com.apple.audio.toolbox.AudioToolbox (1.14 – 1.14) <1F4026C6-23C1-39E8-823D-72298FECF75C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fffb0da9000 – 0x7fffb0da9fff com.apple.audio.units.AudioUnit (1.14 – 1.14) <2CEE36AF-79E6-3B3E-B369-285E6C1886F7> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fffb0f12000 – 0x7fffb12effff com.apple.CFNetwork (811.11 – 811.11) <5E5A7D4D-BCBA-3995-8C13-4D01DE1FAB33> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fffb1309000 – 0x7fffb1309fff com.apple.Carbon (154 – 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fffb130a000 – 0x7fffb130dfff com.apple.CommonPanels (1.2.6 – 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fffb130e000 – 0x7fffb1617fff com.apple.HIToolbox (2.1.1 – 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fffb1618000 – 0x7fffb161bff7 com.apple.help (1.3.5 – 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fffb161c000 – 0x7fffb1621fff com.apple.ImageCapture (9.0 – 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fffb1622000 – 0x7fffb16b9ff3 com.apple.ink.framework (10.9 – 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fffb16ba000 – 0x7fffb16d4fff com.apple.openscripting (1.7 – 172.1) <78F3256B-AF4C-324A-A591-ECA4443A469F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fffb16d5000 – 0x7fffb16d6ff3 com.apple.print.framework.Print (12 – 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fffb16d7000 – 0x7fffb16d9ff7 com.apple.securityhi (9.0 – 55006) <135BC15F-6CC4-3847-A7C9-5AB3F3FD0388> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fffb16da000 – 0x7fffb16e0ff7 com.apple.speech.recognition.framework (6.0.1 – 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fffb16e1000 – 0x7fffb17c0ffb com.apple.cloudkit.CloudKit (651.14 – 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fffb17c1000 – 0x7fffb17c1fff com.apple.Cocoa (6.11 – 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fffb190b000 – 0x7fffb1998fff com.apple.audio.CoreAudio (4.3.0 – 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fffb1999000 – 0x7fffb19acfff com.apple.CoreBluetooth (1.0 – 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fffb19ad000 – 0x7fffb1ca8fff com.apple.CoreData (120 – 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fffb1ca9000 – 0x7fffb1d56ff7 com.apple.CoreDisplay (1.0 – 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fffb1d57000 – 0x7fffb21f0ff7 com.apple.CoreFoundation (6.9 – 1349.93) <0EEBE5E5-66D3-3FA7-82EA-DA5883120DA5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fffb21f1000 – 0x7fffb2873fff com.apple.CoreGraphics (2.0 – 1070.22.1) <8A053296-AA99-371C-B9C5-FCBF87C6CEFE> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fffb2874000 – 0x7fffb2ab7ffb com.apple.CoreImage (12.4.0 – 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fffb2ab8000 – 0x7fffb2b1dff7 com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fffb2b1e000 – 0x7fffb2bcffff com.apple.CoreMedia (1.0 – 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fffb2bd0000 – 0x7fffb2c1bff7 com.apple.CoreMediaIO (805.0 – 4932) <13F90EEF-27E5-3873-89ED-F1C94ED4D754> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fffb2c1c000 – 0x7fffb2c1cfff com.apple.CoreServices (775.20 – 775.20) <BECD6AF0-134A-3EF8-BFE1-83A5AEF6A1D0> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fffb2c1d000 – 0x7fffb2c6efff com.apple.AE (712.5 – 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fffb2c6f000 – 0x7fffb2f4aff7 com.apple.CoreServices.CarbonCore (1159.6 – 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fffb2f4b000 – 0x7fffb2f7efff com.apple.DictionaryServices (1.2 – 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fffb2f7f000 – 0x7fffb2f87ff3 com.apple.CoreServices.FSEvents (1230.50.1 – 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fffb2f88000 – 0x7fffb30f4ffb com.apple.LaunchServices (775.20 – 775.20) <044A0413-CF32-3A1C-BE8E-FAA0AB2153DC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fffb30f5000 – 0x7fffb31a5ffb com.apple.Metadata (10.7.0 – 1075.41) <558F5979-7B84-3569-80CB-B37381129396> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fffb31a6000 – 0x7fffb3205fff com.apple.CoreServices.OSServices (775.20 – 775.20) <45CB995C-1E56-3E61-B4B9-113986CF34E6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fffb3206000 – 0x7fffb3276fff com.apple.SearchKit (1.4.0 – 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fffb3277000 – 0x7fffb32bcff7 com.apple.coreservices.SharedFileList (38 – 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fffb3345000 – 0x7fffb3492ffb com.apple.CoreText (352.0 – 544.18) <B883809B-561B-31C5-949E-D2564B6F808A> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fffb3493000 – 0x7fffb34c8ff3 com.apple.CoreVideo (1.8 – 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fffb34c9000 – 0x7fffb353affb com.apple.framework.CoreWLAN (11.0 – 1200.31) <F2369C0E-3B44-3A5C-9837-5AB45369B723> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fffb356d000 – 0x7fffb3578ff3 com.apple.DirectoryService.Framework (10.12 – 194) <45BEA292-4550-3082-8CE7-5D6CE7E0052A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fffb3579000 – 0x7fffb3637ff7 com.apple.DiscRecording (9.0.3 – 9030.4.5) <9397E609-CB54-37B2-B28E-D4BC6C34BFAB> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fffb3638000 – 0x7fffb363dfff com.apple.DiskArbitration (2.7 – 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fffb37cc000 – 0x7fffb37ceff7 com.apple.ExceptionHandling (1.5 – 12) <23464743-95E9-3EA7-868F-FE6DA0B17449> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
0x7fffb37cf000 – 0x7fffb3b75ff3 com.apple.Foundation (6.9 – 1349.92) <99B1320B-7E15-3E84-AB6E-574B57E81D64> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fffb3ba1000 – 0x7fffb3bd2fff com.apple.GSS (4.0 – 2.0) <F548823F-E626-37A9-AC57-52D74466B169> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fffb3c92000 – 0x7fffb3d35fff com.apple.Bluetooth (5.0.5 – 5.0.5f3) <586E8B4C-C5C5-3B80-A5E0-E4A5BA29A911> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fffb3d36000 – 0x7fffb3dccff7 com.apple.framework.IOKit (2.0.2 – 1324.60.6) <72AEAC01-3FDF-3F0F-8A4F-1D7CB00B569C> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fffb3dcd000 – 0x7fffb3dd3ffb com.apple.IOSurface (159.12 – 159.12) <E3D6FCED-F938-30A3-AD08-0998B674A492> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fffb3dd4000 – 0x7fffb3e25ff7 com.apple.ImageCaptureCore (7.0 – 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fffb3e26000 – 0x7fffb3f86fef com.apple.ImageIO.framework (3.3.0 – 1599.13) <443879A7-48C6-37ED-AC0B-166EEEABA662> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fffb3f87000 – 0x7fffb3f8bfff libGIF.dylib (1599.13) <11C5D9D7-B8A1-3D53-BA50-B25976FE6379> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fffb3f8c000 – 0x7fffb407cff7 libJP2.dylib (1599.13) <C495FB08-0CD2-36FC-8196-FAD3D598A010> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fffb407d000 – 0x7fffb40a0ffb libJPEG.dylib (1599.13) <D22E2431-76A5-39B4-AF0B-174CF282A1CE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fffb40a1000 – 0x7fffb40c8ff7 libPng.dylib (1599.13) <561865FA-A51B-3EFF-ABFF-B4566B90B1A2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fffb40c9000 – 0x7fffb40cbff3 libRadiance.dylib (1599.13) <6559253B-8FE2-3884-BC93-95BB7705A6D1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fffb40cc000 – 0x7fffb411affb libTIFF.dylib (1599.13) <8FC594B3-6BBF-3A70-9994-203E9B330B5F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fffb4278000 – 0x7fffb4e82fff com.apple.JavaScriptCore (12603 – 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fffb4e83000 – 0x7fffb4e9cff7 com.apple.Kerberos (3.0 – 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fffb4e9d000 – 0x7fffb4ed3fff com.apple.LDAPFramework (2.4.28 – 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fffb5126000 – 0x7fffb512cfff com.apple.MediaAccessibility (1.0 – 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fffb5142000 – 0x7fffb567bff7 com.apple.MediaToolbox (1.0 – 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fffb567c000 – 0x7fffb56d7fff com.apple.Metal (87.18 – 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fffb56d8000 – 0x7fffb56f0fff com.apple.MetalKit (1.0 – 76.1) <BA9002FF-00C1-32C8-BC06-634C81C3DB02> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fffb56f1000 – 0x7fffb5f70fff com.apple.ModelIO (1.0 – 1) <366820F9-6795-3D93-AAF2-630D94B395E6> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
0x7fffb5f71000 – 0x7fffb5fbfff7 com.apple.MultipeerConnectivity (135.3 – 135.3) <068FDF41-9BA2-39C4-98EF-5ED6167FE026> /System/Library/Frameworks/MultipeerConnectivity.framework/Versions/A/MultipeerConnectivity
0x7fffb5fc0000 – 0x7fffb5fc8fff com.apple.NetFS (6.0 – 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fffb619f000 – 0x7fffb61a7ff7 libcldcpuengine.dylib (2.8.5) <78863694-6DB1-3E0D-BF60-089E76916A04> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fffb61a8000 – 0x7fffb61f6ff3 com.apple.opencl (2.8.6 – 2.8.6) <48800D5A-79D9-3C7F-9395-5BF5D666450D> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fffb61f7000 – 0x7fffb6210ffb com.apple.CFOpenDirectory (10.12 – 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fffb6211000 – 0x7fffb621cff7 com.apple.OpenDirectory (10.12 – 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fffb621d000 – 0x7fffb621ffff libCVMSPluginSupport.dylib (14.0.16) <6815FB89-62F5-3775-88B1-C7C5F44B66BC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fffb6220000 – 0x7fffb6223ff7 libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fffb6224000 – 0x7fffb6228fff libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fffb6229000 – 0x7fffb6232ff7 libGFXShared.dylib (14.0.16) <5B323793-E2D9-325C-8B10-DD89FB79191D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fffb6233000 – 0x7fffb623efff libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fffb623f000 – 0x7fffb627bff7 libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fffb627c000 – 0x7fffb63f2ff3 libGLProgrammability.dylib (14.0.16) <E9FF3C90-DAEF-312C-9F9E-92D7F3BBAF33> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fffb63f3000 – 0x7fffb6434ff7 libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fffb6d9c000 – 0x7fffb6daafff com.apple.opengl (14.0.16 – 14.0.16) <9603EAF7-2D2F-34F4-8A01-2EF1B0EDBC6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fffb6e47000 – 0x7fffb6f8efff com.apple.QTKit (7.7.3 – 2978.8) <80B27C5D-087F-3B83-AF99-AD6BA2E1105D> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fffb6f8f000 – 0x7fffb71f9ff7 com.apple.imageKit (3.0 – 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fffb71fa000 – 0x7fffb72c1fff com.apple.PDFKit (1.0 – 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fffb72c2000 – 0x7fffb77e8ff7 com.apple.QuartzComposer (5.1 – 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fffb77e9000 – 0x7fffb780cffb com.apple.quartzfilters (1.10.0 – 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fffb780d000 – 0x7fffb78fafff com.apple.QuickLookUIFramework (5.0 – 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fffb78fb000 – 0x7fffb78fbfff com.apple.quartzframework (1.5 – 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fffb78fc000 – 0x7fffb7afcfff com.apple.QuartzCore (1.11 – 453.40.1) <4E1D05A4-85B8-3142-86DF-D6AEB8DE2684> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fffb7afd000 – 0x7fffb7b52fff com.apple.QuickLookFramework (5.0 – 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fffb7b53000 – 0x7fffb7b6bfff com.apple.SafariServices.framework (12606 – 12606.3.4.1.4) <43B28971-A89E-3BAC-8AD8-7715BE3ABFD8> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fffb804e000 – 0x7fffb8065ff7 com.apple.ScriptingBridge (1.3.3 – 69) <F51B85CD-9C80-317E-B594-4A03612EAF52> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fffb8066000 – 0x7fffb8368fff com.apple.security (7.0 – 57740.60.26) <1C910BB7-5E7C-3738-BB1F-4118C0BBB5A2> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fffb8369000 – 0x7fffb83defff com.apple.securityfoundation (6.0 – 55132.50.7) <7879522A-7976-376F-9267-003B778A622F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fffb83df000 – 0x7fffb8408fff com.apple.securityinterface (10.0 – 55079.50.4) <E435CAD1-40E2-3C1A-9786-1E4BEED2E0DE> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fffb8409000 – 0x7fffb840cff3 com.apple.xpc.ServiceManagement (1.0 – 1) <C56EFEF9-C9CD-3948-9448-E7B9FF4C8429> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fffb864c000 – 0x7fffb8657ffb com.apple.StoreKit (1.0 – 584) <A3111CF4-FB8C-3A75-8953-36EB447D4809> /System/Library/Frameworks/StoreKit.framework/Versions/A/StoreKit
0x7fffb8793000 – 0x7fffb8802ff7 com.apple.SystemConfiguration (1.14 – 1.14) <9B617B63-75E0-3F49-90F9-54C384C66063> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fffb8803000 – 0x7fffb8bb1fff com.apple.VideoToolbox (1.0 – 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fffb8bb2000 – 0x7fffb9f39ff3 com.apple.WebCore (12603 – 12603.3.8) <FE0B8503-5E89-3D55-BF48-1370FE81910A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fffb9f3a000 – 0x7fffba126ff3 com.apple.WebKitLegacy (12603 – 12603.3.8) <28A763DA-BA6C-3350-8200-6DEA86FF7878> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fffba127000 – 0x7fffba4d2fff com.apple.WebKit (12603 – 12603.3.8) <38192059-8C02-3BBC-BF1F-E1D5E3150E16> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fffba8de000 – 0x7fffba8e5ffb com.apple.APFS (1.0 – 1) <6E79797E-26BD-3E49-891C-03B223F7BD59> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fffba93a000 – 0x7fffba9acff3 com.apple.ICE (3.0 – 917.49) <AFFE4B65-4AA4-3F12-BC23-E945EC89866C> /System/Library/PrivateFrameworks/AVConference.framework/Frameworks/ICE.framework/Versions/A/ICE
0x7fffba9ad000 – 0x7fffba9adff7 com.apple.LegacyHandle (3.0 – 917.49) <C958DF47-0E5F-3DDB-A08C-D3295A23E2EE> /System/Library/PrivateFrameworks/AVConference.framework/Frameworks/LegacyHandle.framework/Versions/A/LegacyHandle
0x7fffba9ae000 – 0x7fffba9b4fff com.apple.SimpleKeyExchange (3.0 – 917.49) <39E71042-3F56-3C43-A87D-79F37FCFDED6> /System/Library/PrivateFrameworks/AVConference.framework/Frameworks/SimpleKeyExchange.framework/Versions/A/SimpleKeyExchange
0x7fffba9b5000 – 0x7fffba9d5fff com.apple.ViceroyTrace (3.0 – 917.49) <2E50A71E-9DBC-3B79-97C1-814F95099B52> /System/Library/PrivateFrameworks/AVConference.framework/Frameworks/ViceroyTrace.framework/Versions/A/ViceroyTrace
0x7fffba9d6000 – 0x7fffba9d8ff3 com.apple.snatmap (3.0 – 917.49) <B0B66C1D-078D-3C30-932F-B15CC86563F2> /System/Library/PrivateFrameworks/AVConference.framework/Frameworks/snatmap.framework/Versions/A/snatmap
0x7fffbb059000 – 0x7fffbb074ff3 com.apple.AppContainer (4.0 – 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fffbb075000 – 0x7fffbb082ff3 com.apple.AppSandbox (4.0 – 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fffbb083000 – 0x7fffbb0a5ffb com.apple.framework.Apple80211 (12.0 – 1200.47.1) <730E01DB-E3AC-3494-A77C-CF5D13CE3A65> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fffbb0a6000 – 0x7fffbb0b5feb com.apple.AppleFSCompression (88.50.3 – 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fffbb0b6000 – 0x7fffbb17efff com.apple.AppleGVAFramework (10.1.17 – 10.1.17) <4DC7FAF2-A377-3B82-B2BB-9DA3F0D496E5> /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
0x7fffbb1ae000 – 0x7fffbb23997f com.apple.AppleJPEG (1.0 – 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fffbb24d000 – 0x7fffbb268fff com.apple.aps.framework (4.0 – 4.0) <6CA07CDF-1E35-34E9-95BF-BD565FF42BAD> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fffbb269000 – 0x7fffbb271ffb com.apple.AppleSRP (5.0 – 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fffbb272000 – 0x7fffbb275ff3 com.apple.AppleSystemInfo (3.1.5 – 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fffbb276000 – 0x7fffbb2c8fff com.apple.AppleVAFramework (5.0.36 – 5.0.36) <7BE51581-B4BC-31A5-BBC4-95EC5968B5BD> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fffbb2d2000 – 0x7fffbb2d9ff7 com.apple.AssetCacheServices (48.3 – 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fffbb66c000 – 0x7fffbb6eaff7 com.apple.backup.framework (1.8.6 – 1.8.6) <2D75451A-8818-3D72-8480-489DF77D708B> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fffbb713000 – 0x7fffbb750ffb com.apple.bom (14.0 – 194.1) <0CBECAF1-B5E0-302F-99EC-D7ED14E12B84> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fffbb991000 – 0x7fffbb9baffb com.apple.CacheDelete (1.0 – 1) <D9678282-6F34-3EE4-94E2-42B2F6A055A5> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
0x7fffbbd86000 – 0x7fffbbdadfff com.apple.CalendarAgentLink (8.0 – 250) <E50E29F6-2BAB-3B8B-BBEA-7DC0B8B077AD> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x7fffbc375000 – 0x7fffbc39cff3 com.apple.ChunkingLibrary (173 – 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fffbc39d000 – 0x7fffbc429ff7 com.apple.CloudDocs (1.0 – 486.30) <74EA66DC-294A-3AFA-9FDF-711926907A35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fffbccb5000 – 0x7fffbccc0ff7 com.apple.CommerceCore (1.0 – 584) <F13121B4-5F5B-3BDE-AFE3-341F56A8DD11> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fffbccc1000 – 0x7fffbcccaffb com.apple.CommonAuth (4.0 – 2.0) <3B7FFF45-1D2D-3CAC-A102-E16D3AF681D8> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffbcccb000 – 0x7fffbccd7fff com.apple.commonutilities (8.0 – 900) <B0C96E6D-2C68-36EF-86BE-A2E5F380C78B> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fffbcd91000 – 0x7fffbcde2ff7 com.apple.AddressBook.ContactsFoundation (8.0 – 2250.11) <1324A70E-A093-3DB9-A802-07B8F4A499B5> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fffbcde3000 – 0x7fffbce05fff com.apple.contacts.ContactsPersistence (1.0 – 2250.11) <7CDEB852-B3B7-328F-9537-DFB3A58B882C> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fffbce4f000 – 0x7fffbd22eff7 com.apple.CoreAUC (226.0.0 – 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fffbd22f000 – 0x7fffbd25ffff com.apple.CoreAVCHD (5.9.0 – 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fffbd2fa000 – 0x7fffbd302ffb com.apple.frameworks.CoreDaemon (1.3 – 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fffbd413000 – 0x7fffbd423fff com.apple.CoreEmoji (1.0 – 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fffbd4e8000 – 0x7fffbd4feff3 com.apple.CoreMediaAuthoring (2.2 – 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fffbd505000 – 0x7fffbd595ffb com.apple.CorePDF (4.0 – 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fffbd75e000 – 0x7fffbd78eff3 com.apple.CoreServicesInternal (276.2 – 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fffbda1f000 – 0x7fffbdaaeff7 com.apple.CoreSymbolication (62046) <02145527-4A5D-378B-B768-21C2342038DC> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fffbdaaf000 – 0x7fffbdbeefe7 com.apple.coreui (2.1 – 431.3) <8D0FA478-9B6C-3D6D-8ADF-8677BA0BF134> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fffbdbef000 – 0x7fffbdcbfff3 com.apple.CoreUtils (5.1 – 510.31) <0DB85A25-0DB5-35DF-95AB-5932719CC5BC> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fffbdd0f000 – 0x7fffbdd74ff3 com.apple.framework.CoreWiFi (12.0 – 1200.31) <C2D090BA-438C-3752-AE23-8A41E6E39742> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffbdd75000 – 0x7fffbdd83ff7 com.apple.CrashReporterSupport (10.12 – 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fffbddf5000 – 0x7fffbddffffb com.apple.framework.DFRFoundation (1.0 – 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fffbde00000 – 0x7fffbde04ff3 com.apple.DSExternalDisplay (3.1 – 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fffbde3a000 – 0x7fffbdeafffb com.apple.datadetectorscore (7.0 – 539.1) <D84B64BA-CD56-368E-A31A-AC47C3780D0B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffbdeeb000 – 0x7fffbdf2afff com.apple.DebugSymbols (137 – 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fffbdf2b000 – 0x7fffbe03cfff com.apple.desktopservices (1.11.6 – 1.11.6) <225B3746-8626-34CD-8FA9-48A7C04ACCCF> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fffbe03f000 – 0x7fffbe040ff3 com.apple.diagnosticlogcollection (10.0 – 1000) <8FAE46F9-77CF-3652-82F0-872977C5F45C> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x7fffbe041000 – 0x7fffbe116fff com.apple.DiskImagesFramework (444.50.18 – 444.50.18) <3FAE824B-B72E-3280-86CA-A856D1458D77> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fffbe17f000 – 0x7fffbe18afff com.apple.DisplayServicesFW (3.1 – 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fffbe1cf000 – 0x7fffbe1d1ffb com.apple.EFILogin (2.0 – 2) <A74B0065-643F-3BC1-8FE9-E7CEAA29AD9A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fffbe324000 – 0x7fffbe755ff7 com.apple.vision.FaceCore (3.3.2 – 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffbe793000 – 0x7fffbeb25ff7 com.apple.FinderKit (1.5.6 – 1.5.6) <4CE7DA59-CB88-3459-B616-C9A119BE0F9B> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x7fffbfaac000 – 0x7fffbfaacfff libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fffbfab9000 – 0x7fffbfac4ff3 libGPUSupportMercury.dylib (14.0.16) <7ACAB4BF-560E-3F39-B774-B5449600C556> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fffbfd7d000 – 0x7fffbfd99fff com.apple.GenerationalStorage (2.0 – 267.2) <22381303-B9A8-32D8-BDBF-871F0CDD81A5> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fffbfdb2000 – 0x7fffc0464fff com.apple.GeoServices (1.0 – 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fffc04aa000 – 0x7fffc0520ff3 com.apple.Heimdal (4.0 – 2.0) <39CF9772-0359-3745-AF77-BC6B29A210F2> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fffc0521000 – 0x7fffc0532fff com.apple.HelpData (2.1.12 – 100.1) <EEB8CC44-9AFF-3005-A25D-18FE46574FD5> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fffc0a87000 – 0x7fffc0aeaffb com.apple.imfoundation (10.0 – 1000) <5D06CD08-8F99-357B-B90B-3F2F8C22D4F8> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fffc0b30000 – 0x7fffc0b3afff com.apple.IOAccelMemoryInfo (1.0 – 1) <2A8F10EE-A442-3C5F-94D8-EC44E918F30B> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fffc0b3b000 – 0x7fffc0b42ffb com.apple.IOAccelerator (311.16.2 – 311.16.2) <96FA28B6-B03D-3A5E-AF07-0AE4486D2968> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fffc0b44000 – 0x7fffc0b58ff7 com.apple.IOPresentment (1.0 – 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fffc0b59000 – 0x7fffc0b7bfff com.apple.IconServices (74.4 – 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fffc0c17000 – 0x7fffc0c27ff3 com.apple.IntlPreferences (2.0 – 216) <7A417848-2A43-35A3-9CD4-61F33D573C56> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fffc0c62000 – 0x7fffc0e19fff com.apple.LanguageModeling (1.0 – 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fffc0e65000 – 0x7fffc0e69ff7 com.apple.LoginUICore (4.0 – 4.0) <64DB7ABF-27A6-366E-89D4-0FDF82247150> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fffc0f15000 – 0x7fffc0fd7ff3 com.apple.MMCS (1.3 – 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fffc1489000 – 0x7fffc148cfff com.apple.Mangrove (1.0 – 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fffc14cb000 – 0x7fffc14cdffb com.apple.marco (10.0 – 1000) <A4D35D48-6020-3FF7-BB4F-8193534A4B8F> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x7fffc1565000 – 0x7fffc1599ff3 com.apple.MediaKit (16 – 845) <883DC63F-F90F-3FB9-8C23-9CECD72EBCDE> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fffc159a000 – 0x7fffc16faffb com.apple.MediaRemote (1.0 – 1) <24B6D0D5-E41F-366E-8881-BD427639BD34> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
0x7fffc16fb000 – 0x7fffc1716ffb com.apple.MediaServices (1.0 – 1) <C7097932-E6BF-396A-B838-785000FBF58D> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
0x7fffc173a000 – 0x7fffc17b3ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 – 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fffc192f000 – 0x7fffc193dfff com.apple.MobileKeyBag (2.0 – 1.0) <D0983DB7-EF9D-3E19-A084-21319ECE5846> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fffc194e000 – 0x7fffc1976ff7 com.apple.MultitouchSupport.framework (368.16 – 368.16) <AEA94167-8559-3846-9F43-40E7CDFB2209> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fffc1a28000 – 0x7fffc1a33fff com.apple.NetAuth (6.2 – 6.2) <348EB96D-9947-3B02-BB82-D9E618D04FA5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fffc1e80000 – 0x7fffc1e82fff com.apple.OAuth (25 – 25) <D6E5F36D-71B8-3E12-9601-CE2A1D6ED60B> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
0x7fffc1ea4000 – 0x7fffc1fa7fef com.apple.PackageKit (3.0 – 629) <6852D890-F4A8-37A1-BF8D-87763616A117> /System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/PackageKit
0x7fffc230b000 – 0x7fffc234cff3 com.apple.PerformanceAnalysis (1.148.3 – 148.3) <CBBF5565-C9BB-35B0-B561-5C5103D8B166> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fffc238f000 – 0x7fffc2396ff3 com.apple.phonenumbers (1.1.1 – 105) <B8EFDDD3-BA26-39B8-9EA0-3649184BF527> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fffc2984000 – 0x7fffc29a6fff com.apple.pluginkit.framework (1.0 – 1) <B09BC1B5-63C4-368E-A7BA-4155D3798E27> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fffc29f9000 – 0x7fffc2a33ffb com.apple.ProtectedCloudStorage (1.0 – 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fffc2a34000 – 0x7fffc2a4efff com.apple.ProtocolBuffer (1 – 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fffc2a4f000 – 0x7fffc2a5eff7 com.apple.QuickLookThumbnailing (1.0 – 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fffc2a67000 – 0x7fffc2a8aff3 com.apple.RemoteViewServices (2.0 – 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fffc3754000 – 0x7fffc3757fff com.apple.SecCodeWrapper (4.0 – 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fffc37e6000 – 0x7fffc3873fff com.apple.Sharing (696.2.67 – 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffc3874000 – 0x7fffc3893ff7 com.apple.shortcut (2.16 – 98) <6C0435B1-83DD-3254-B0D3-3B86C6CE606A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fffc3894000 – 0x7fffc3afaff7 com.apple.SkyLight (1.600.0 – 170.3.11.2) <D033643B-DDEF-3E3E-8A43-B84809892B6F> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fffc3cd9000 – 0x7fffc3ce5ff7 com.apple.SpeechRecognitionCore (3.3.2 – 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fffc406f000 – 0x7fffc40d0fff com.apple.Suggestions (6.0 – 197) <9DD142A2-82A5-3202-B36C-20E19B4C5D56> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x7fffc43d1000 – 0x7fffc4445fdf com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fffc4665000 – 0x7fffc4691ff3 com.apple.framework.SystemAdministration (1.0 – 1.0) <CD5B74B1-01ED-369E-AB11-1DA59F2C2A24> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fffc4884000 – 0x7fffc488aff7 com.apple.TCC (1.0 – 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fffc4916000 – 0x7fffc49dcff7 com.apple.TextureIO (2.8 – 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fffc4a25000 – 0x7fffc4a3aff3 com.apple.ToneKit (1.0 – 1) <B709293D-0A79-398A-8AA9-50F6340C227C> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fffc4a3b000 – 0x7fffc4a49ffb com.apple.ToneLibrary (1.0 – 1) <F2ED5DFC-5F11-3012-BCD7-17753413141F> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fffc4a50000 – 0x7fffc4a51fff com.apple.TrustEvaluationAgent (2.0 – 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fffc4a52000 – 0x7fffc4be2ff3 com.apple.UIFoundation (1.0 – 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fffc56b1000 – 0x7fffc5771fff com.apple.ViewBridge (283 – 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fffc5bbc000 – 0x7fffc5bc2fff com.apple.XPCService (2.0 – 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fffc5c0f000 – 0x7fffc5c8dff7 com.apple.iLifeMediaBrowser (2.11.2 – 733) <13B4CC92-9DFE-3C01-A519-6E32CC504662> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x7fffc5c93000 – 0x7fffc5c95ffb com.apple.loginsupport (1.0 – 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fffc5cc1000 – 0x7fffc5ce8ff7 com.apple.contacts.vCard (1.0 – 2250.11) <DD615DAF-AF34-3AB4-9CB4-DA0A882D59A5> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fffc5cea000 – 0x7fffc5d05ff7 libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
0x7fffc5d06000 – 0x7fffc5d11fff libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
0x7fffc5d12000 – 0x7fffc5da2ff7 libCoreStorage.dylib (540.30.1) <85C0A366-F901-36E3-854A-FE8A14A04A72> /usr/lib/libCoreStorage.dylib
0x7fffc5da3000 – 0x7fffc5da4ff3 libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fffc5da5000 – 0x7fffc5fb8fff libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
0x7fffc5fd4000 – 0x7fffc5fdbfff libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
0x7fffc5fdc000 – 0x7fffc5fdcfff libOpenScriptingUtil.dylib (172.1) <0F1BA407-97D1-36F6-882D-A355EAAD5E00> /usr/lib/libOpenScriptingUtil.dylib
0x7fffc5fdd000 – 0x7fffc5fe1ffb libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
0x7fffc5fe2000 – 0x7fffc5fe3ffb libSystem.B.dylib (1238.60.2) <2F1FC9DB-3ED2-392B-A157-6EF1EE2B996A> /usr/lib/libSystem.B.dylib
0x7fffc604f000 – 0x7fffc607aff3 libarchive.2.dylib (41.70.2) <907D1FB1-9A65-33F5-AFC8-0B6E5AE9D83A> /usr/lib/libarchive.2.dylib
0x7fffc607b000 – 0x7fffc60f7fc7 libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
0x7fffc60fb000 – 0x7fffc60fbff3 libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
0x7fffc60fc000 – 0x7fffc610cff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fffc610d000 – 0x7fffc611bff7 libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
0x7fffc611c000 – 0x7fffc6172ff7 libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
0x7fffc6173000 – 0x7fffc619cff7 libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
0x7fffc619d000 – 0x7fffc61adffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fffc61ae000 – 0x7fffc61c4fcf libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
0x7fffc61c5000 – 0x7fffc61c5ff7 libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
0x7fffc61c6000 – 0x7fffc61c7ff3 libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
0x7fffc6281000 – 0x7fffc6365ff7 libcrypto.0.9.8.dylib (64.50.7) <B34BC0FA-18ED-37C5-9D46-393803CADEBB> /usr/lib/libcrypto.0.9.8.dylib
0x7fffc6366000 – 0x7fffc64f6ff7 libcrypto.35.dylib (11.50.4) <11578EE7-5538-3543-AAE5-A9B3E91536B2> /usr/lib/libcrypto.35.dylib
0x7fffc64f7000 – 0x7fffc6502fff libcsfde.dylib (540.30.1) <0C2B183B-16D9-3D5F-962D-0A09C7063211> /usr/lib/libcsfde.dylib
0x7fffc6503000 – 0x7fffc6556ff7 libcups.2.dylib (450.3) <D2756AA0-6276-3D5F-9F69-4A9903AA43FE> /usr/lib/libcups.2.dylib
0x7fffc6557000 – 0x7fffc65a9fff libcurl.4.dylib (95.70.5) <ED932C5D-6FA2-364A-B562-3F67D1B40C71> /usr/lib/libcurl.4.dylib
0x7fffc65aa000 – 0x7fffc65b1ff3 libdscsym.dylib (148.3) <9AFDF120-B0EC-3FD8-BC18-AB32ED9E6522> /usr/lib/libdscsym.dylib
0x7fffc65d3000 – 0x7fffc65d3fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
0x7fffc65e1000 – 0x7fffc65e2fff libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
0x7fffc65e3000 – 0x7fffc65e8ff7 libheimdal-asn1.dylib (498.50.10) <F7B77939-35A5-327A-B8BF-BF71EF5DC230> /usr/lib/libheimdal-asn1.dylib
0x7fffc65e9000 – 0x7fffc66dbff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fffc66dc000 – 0x7fffc6901ffb libicucore.A.dylib (57168.0.1) <99D53A36-19F6-34F0-86AB-D8BD6C9BD3AD> /usr/lib/libicucore.A.dylib
0x7fffc6907000 – 0x7fffc6908fff liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
0x7fffc6909000 – 0x7fffc6922ffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fffc6923000 – 0x7fffc6939ff7 libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
0x7fffc693a000 – 0x7fffc6be2ff7 libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
0x7fffc6c15000 – 0x7fffc6c8fff3 libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
0x7fffc6c90000 – 0x7fffc7062047 libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
0x7fffc7063000 – 0x7fffc7064fff libodfde.dylib (23.50.1) <744F1E66-11EB-3A4D-8944-722F39C55278> /usr/lib/libodfde.dylib
0x7fffc7065000 – 0x7fffc7069fff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
0x7fffc706a000 – 0x7fffc709bfff libpcap.A.dylib (67.60.2) <B2D36AD8-D5C8-3875-AC81-4787A15E44C2> /usr/lib/libpcap.A.dylib
0x7fffc70b8000 – 0x7fffc70d4ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
0x7fffc70d5000 – 0x7fffc710efff libsandbox.1.dylib (592.70.2) <3ACB63BE-9CED-3BAA-A5D4-18FC9C95EC91> /usr/lib/libsandbox.1.dylib
0x7fffc710f000 – 0x7fffc7121ffb libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
0x7fffc7122000 – 0x7fffc7123ff3 libspindump.dylib (231.3) <6BCD9245-3237-32F3-9075-6AC04D0F366D> /usr/lib/libspindump.dylib
0x7fffc7124000 – 0x7fffc7272ff7 libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
0x7fffc72ce000 – 0x7fffc7321ffb libssl.35.dylib (11.50.4) <81C74F15-DE70-3B59-BB9D-9224646B49CC> /usr/lib/libssl.35.dylib
0x7fffc7322000 – 0x7fffc7372fff libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
0x7fffc7384000 – 0x7fffc73b6fff libtidy.A.dylib (15.18.1) <513B2676-8EE0-3A4C-845C-CACDD25280CA> /usr/lib/libtidy.A.dylib
0x7fffc73b7000 – 0x7fffc73baff7 libutil.dylib (47.30.1) <88CC63B3-0EDF-306E-9AB5-D87EBE0F3F16> /usr/lib/libutil.dylib
0x7fffc73bb000 – 0x7fffc73c8fff libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
0x7fffc73c9000 – 0x7fffc74b8ff3 libxml2.2.dylib (30.23) <307564E4-7CF2-3010-BA8F-1D302E662EAF> /usr/lib/libxml2.2.dylib
0x7fffc74b9000 – 0x7fffc74e2fff libxslt.1.dylib (15.9.1) <A1EFC225-2115-3710-A2FD-B11FDE15B01F> /usr/lib/libxslt.1.dylib
0x7fffc74e3000 – 0x7fffc74f4ff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fffc7503000 – 0x7fffc7507ff7 libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
0x7fffc7508000 – 0x7fffc7512fff libcommonCrypto.dylib (60092.50.5) <03EEAAED-DDDC-32D4-B7BA-4266AB62DB75> /usr/lib/system/libcommonCrypto.dylib
0x7fffc7513000 – 0x7fffc751afff libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
0x7fffc751b000 – 0x7fffc7523fff libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
0x7fffc7524000 – 0x7fffc75a7fdb libcorecrypto.dylib (442.50.21) <291DA62F-6958-370F-82ED-7073538A3D3A> /usr/lib/system/libcorecrypto.dylib
0x7fffc75a8000 – 0x7fffc75d9fff libdispatch.dylib (703.50.38) <54B02414-5908-3EF0-B4D2-230B7FEB1CF7> /usr/lib/system/libdispatch.dylib
0x7fffc75da000 – 0x7fffc75dfffb libdyld.dylib (434) <1A9911CF-F5BC-385A-9644-45264C4F08D8> /usr/lib/system/libdyld.dylib
0x7fffc75e0000 – 0x7fffc75e0ffb libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
0x7fffc75e1000 – 0x7fffc75edfff libkxld.dylib (3789.73.27) <24E6C535-1FBC-338D-841A-C9CDB376DE9D> /usr/lib/system/libkxld.dylib
0x7fffc75ee000 – 0x7fffc75eefff liblaunch.dylib (972.70.2) <DB690F9D-4A72-38F3-A82C-44E7B27BE4C9> /usr/lib/system/liblaunch.dylib
0x7fffc75ef000 – 0x7fffc75f4ff3 libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
0x7fffc75f5000 – 0x7fffc75f7ff3 libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
0x7fffc75f8000 – 0x7fffc75f9ffb libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
0x7fffc75fa000 – 0x7fffc7612ff7 libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
0x7fffc7613000 – 0x7fffc7613ff7 libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
0x7fffc7614000 – 0x7fffc76a1fef libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
0x7fffc76a2000 – 0x7fffc76a5ffb libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
0x7fffc76a6000 – 0x7fffc76a9fff libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
0x7fffc76aa000 – 0x7fffc76c2fff libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
0x7fffc76c3000 – 0x7fffc76c9fff libsystem_dnssd.dylib (765.50.10) <0999444C-8148-3557-AC22-F5659D15FA62> /usr/lib/system/libsystem_dnssd.dylib
0x7fffc76ca000 – 0x7fffc76f3ff7 libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
0x7fffc76f4000 – 0x7fffc7716ff7 libsystem_kernel.dylib (3789.73.27) <1EF9EC60-1E99-3622-95ED-7230BE22C89A> /usr/lib/system/libsystem_kernel.dylib
0x7fffc7717000 – 0x7fffc775efe7 libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
0x7fffc775f000 – 0x7fffc777dff7 libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
0x7fffc777e000 – 0x7fffc77d7ffb libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
0x7fffc77d8000 – 0x7fffc77e1ff3 libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
0x7fffc77e2000 – 0x7fffc77ebff3 libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
0x7fffc77ec000 – 0x7fffc77f4fe7 libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
0x7fffc77f5000 – 0x7fffc77ffff7 libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
0x7fffc7800000 – 0x7fffc7803ff7 libsystem_sandbox.dylib (592.70.2) <19320A42-2E3B-361B-BBDA-2F5F2E87B100> /usr/lib/system/libsystem_sandbox.dylib
0x7fffc7804000 – 0x7fffc7805ff3 libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
0x7fffc7806000 – 0x7fffc780dffb libsystem_symptoms.dylib (532.50.48) <1C822669-BF39-3639-A00B-B9170A63F342> /usr/lib/system/libsystem_symptoms.dylib
0x7fffc780e000 – 0x7fffc7821ff7 libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
0x7fffc7822000 – 0x7fffc7827ffb libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
0x7fffc7828000 – 0x7fffc7851ff7 libxpc.dylib (972.70.2) <ABC3BB29-BCE6-3E50-8A71-4E56AEE28991> /usr/lib/system/libxpc.dylibExternal Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 24818
thread_create: 0
thread_set_state: 0VM Region Summary:
ReadOnly portion of Libraries: Total=594.7M resident=0K(0%) swapped_out_or_unallocated=594.7M(100%)
Writable regions: Total=2.4G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.4G(100%)VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 768K 5
Activity Tracing 256K 2
CG backing stores 35.7M 9
CG image 13.1M 174
CG raster data 1568K 15
CoreAnimation 432.6M 240
CoreImage 40K 5
CoreUI image data 4844K 37
CoreUI image file 428K 9
Foundation 24K 3
IOKit 15.5M 2
Image IO 17.7M 180
JS JIT generated code 8K 3
JS JIT generated code (reserved) 1.0G 2 reserved VM address space (unallocated)
Kernel Alloc Once 8K 2
MALLOC 746.7M 171
MALLOC guard page 48K 10
MALLOC_LARGE (reserved) 90.3M 12 reserved VM address space (unallocated)
Memory Tag 242 12K 2
Memory Tag 249 2428K 3
Memory Tag 250 23.5M 49
Memory Tag 251 44K 3
SQLite page cache 768K 12
STACK GUARD 56.2M 65
Stack 40.0M 67
VM_ALLOCATE 7152K 71
VM_ALLOCATE (reserved) 36K 2 reserved VM address space (unallocated)
WebKit Malloc 18.1M 39
__DATA 71.3M 451
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 136.0M 100
__POVERDDATA 16K 2
__POVERTEXT 16K 2
__TEXT 458.7M 418
__UNICODE 556K 2
dylib (reserved) 9608K 2 reserved VM address space (unallocated)
mapped file 142.2M 149
shared memory 16.4M 17
TOTAL 3.3G 2302
TOTAL, minus reserved VM space 2.2G 2302Model: MacBookPro13,3, BootROM 250.0.0.0.0, 4 processors, Intel Core i7, 2,6 GHz, 16 GB, SMC 2.38f7
Graphics: Intel HD Graphics 530, Intel HD Graphics 530, Built-In
Graphics: Radeon Pro 450, AMD Radeon Pro 450, PCIe, 2048 MB
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x15A), Broadcom BCM43xx 1.0 (7.21.171.133.1a2)
Bluetooth: Version 5.0.5f3, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: iLok
USB Device: iBridge
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1 -
November 23, 2021 at 5:49 pm #160831
Great, thanks so much for the info!
By chance, when this error happens, has the onboarding/tutorial been opened in the plugin?
November 23, 2021 at 7:18 pm #160834
Hey robibulesic, if you email support@eventide.com referencing this post, we have a test build which might fix this issue (so far we have not been able to reproduce in house).
November 24, 2021 at 1:48 am #160848
Hey tlongabaugh,
disabled the tutorial and the issue disappeared. Great! Thank you for your help.
I’ll inform support via email as well.
Cheers,
robi
November 23, 2021 at 10:16 pm #160843
I am having the same issue on Mac 10.12.6 but with Cubase 10 & 10.5. I just purchased Split EQ. Having read the previous entries I unchecked the the onboarding/tutorial box, stoping the the onboarding/tutorial from opening at startup. Cubase still crashed but next time i reopened Split EQ it closed just fine. As a test I opened the the onboarding/tutorial from the dropdown menu and the plugin crashed when I closed it.
Also if I have opened the the onboarding/tutorial and I uncheck “always on top” cubase crashes immediately. A very minor bug for an excellent plugin.
Regards,
Rob
November 23, 2021 at 10:21 pm #160844
Cubase Crash Report:
Process: Cubase 10.5 [1350]
Path: /Applications/Cubase 10.5.app/Contents/MacOS/Cubase 10.5
Identifier: com.steinberg.cubase10v5
Version: 10.5.30.365 (10.5.30.365)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Cubase 10.5 [1350]
User ID: 501Date/Time: 2021-11-23 19:18:47.257 -0800
OS Version: Mac OS X 10.12.6 (16G2136)
Report Version: 12
Anonymous UUID: DFA2A14C-1485-0F98-AF1B-CA396422CE74Time Awake Since Boot: 7600 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFYApplication Specific Information:
*** Terminating app due to uncaught exception ‘NSInternalInconsistencyException’, reason: ‘An instance 0x610000c09290 of class AVPlayer was deallocated while key value observers were still registered with it. Current observation info: <NSKeyValueObservationInfo 0x608002a22580> (
<NSKeyValueObservance 0x6180012453d0: Observer: 0x60800081a910, Key path: rate, Options: <New: YES, Old: YES, Prior: NO> Context: 0x7fdec7f75af0, Property: 0x618001249000>
<NSKeyValueObservance 0x610002e59ce0: Observer: 0x60800081a910, Key path: status, Options: <New: YES, Old: NO, Prior: NO> Context: 0x7fdec7f75af0, Property: 0x610002e570a0>
terminating with uncaught exception of type NSException
abort() calledApplication Specific Backtrace 1:
0 CoreFoundation 0x00007fff974e17eb __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fffac32248d objc_exception_throw + 48
2 CoreFoundation 0x00007fff9756019d +[NSException raise:format:] + 205
3 Foundation 0x00007fff98ec1ae4 NSKVODeallocate + 293
4 libsystem_blocks.dylib 0x00007fffacc90952 _Block_release + 102
5 libdispatch.dylib 0x00007fffacc268fc _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fffacc33aac _dispatch_main_queue_callback_4CF + 925
7 CoreFoundation 0x00007fff97496309 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9
8 CoreFoundation 0x00007fff9745731d __CFRunLoopRun + 2205
9 CoreFoundation 0x00007fff97456824 CFRunLoopRunSpecific + 420
10 HIToolbox 0x00007fff969b6ebc RunCurrentEventLoopInMode + 240
11 HIToolbox 0x00007fff969b6cf1 ReceiveNextEventCommon + 432
12 HIToolbox 0x00007fff969b6b26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
13 AppKit 0x00007fff94f4ba04 _DPSNextEvent + 1120
14 AppKit 0x00007fff956c77ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
15 AppKit 0x00007fff94f4038b -[NSApplication run] + 926
16 Cubase 10.5 0x0000000103731f88 Cubase 10.5 + 33705864
17 Cubase 10.5 0x000000010355e396 Cubase 10.5 + 31789974
18 Cubase 10.5 0x0000000103120691 Cubase 10.5 + 27342481
19 Cubase 10.5 0x000000010312421b Cubase 10.5 + 27357723
20 libdyld.dylib 0x00007fffacc5c235 start + 1Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fffacd8ad42 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007ffface78457 pthread_kill + 90
2 libsystem_c.dylib 0x00007fffaccf0420 abort + 129
3 libc++abi.dylib 0x00007fffab7f094a abort_message + 266
4 libc++abi.dylib 0x00007fffab815c2f default_terminate_handler() + 267
5 libobjc.A.dylib 0x00007fffac3246fe _objc_terminate() + 103
6 libc++abi.dylib 0x00007fffab812d49 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fffab812dc3 std::terminate() + 51
8 libdispatch.dylib 0x00007fffacc26910 _dispatch_client_callout + 28
9 libdispatch.dylib 0x00007fffacc33aac _dispatch_main_queue_callback_4CF + 925
10 com.apple.CoreFoundation 0x00007fff97496309 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9
11 com.apple.CoreFoundation 0x00007fff9745731d __CFRunLoopRun + 2205
12 com.apple.CoreFoundation 0x00007fff97456824 CFRunLoopRunSpecific + 420
13 com.apple.HIToolbox 0x00007fff969b6ebc RunCurrentEventLoopInMode + 240
14 com.apple.HIToolbox 0x00007fff969b6cf1 ReceiveNextEventCommon + 432
15 com.apple.HIToolbox 0x00007fff969b6b26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
16 com.apple.AppKit 0x00007fff94f4ba04 _DPSNextEvent + 1120
17 com.apple.AppKit 0x00007fff956c77ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
18 com.apple.AppKit 0x00007fff94f4038b -[NSApplication run] + 926
19 com.steinberg.cubase10v5 0x0000000103731f88 0x10170d000 + 33705864
20 com.steinberg.cubase10v5 0x000000010355e396 0x10170d000 + 31789974
21 com.steinberg.cubase10v5 0x0000000103120691 0x10170d000 + 27342481
22 com.steinberg.cubase10v5 0x000000010312421b 0x10170d000 + 27357723
23 libdyld.dylib 0x00007fffacc5c235 start + 1Thread 1:: CRASH THREAD
0 libsystem_kernel.dylib 0x00007fffacd8339e semaphore_timedwait_trap + 10
1 com.steinberg.cubase10v5 0x0000000103146e62 0x10170d000 + 27500130
2 com.steinberg.cubase10v5 0x0000000102531c71 0x10170d000 + 14830705
3 com.steinberg.cubase10v5 0x00000001031460e4 0x10170d000 + 27496676
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 2:
0 libsystem_kernel.dylib 0x00007fffacd8bd96 kevent + 10
1 com.eLicenser.POSAccess-DLL 0x0000000107e988bf 0x107dcb000 + 841919
2 com.eLicenser.POSAccess-DLL 0x0000000107e9b780 0x107dcb000 + 853888
3 com.eLicenser.POSAccess-DLL 0x0000000107e9df4d 0x107dcb000 + 864077
4 libsystem_pthread.dylib 0x00007ffface7593b _pthread_body + 180
5 libsystem_pthread.dylib 0x00007ffface75887 _pthread_start + 286
6 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 3:
0 libsystem_kernel.dylib 0x00007fffacd8c19e poll + 10
1 com.eLicenser.POSAccess-DLL 0x0000000107e95bec 0x107dcb000 + 830444
2 com.eLicenser.POSAccess-DLL 0x0000000107e3071a 0x107dcb000 + 415514
3 com.eLicenser.POSAccess-DLL 0x0000000107e7744c 0x107dcb000 + 705612
4 com.eLicenser.POSAccess-DLL 0x0000000107e77ce3 0x107dcb000 + 707811
5 com.eLicenser.POSAccess-DLL 0x0000000107e705e4 0x107dcb000 + 677348
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 4:: com.steinberg.dispatcher.0
0 libsystem_kernel.dylib 0x00007fffacd8ac6a __psynch_rw_rdlock + 10
1 libsystem_pthread.dylib 0x00007ffface73d70 _pthread_rwlock_lock + 471
2 com.steinberg.cubase10v5 0x0000000103191346 0x10170d000 + 27804486
3 com.steinberg.cubase10v5 0x000000010319357a 0x10170d000 + 27813242
4 com.steinberg.cubase10v5 0x00000001033d0e64 0x10170d000 + 30162532
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 5:: com.steinberg.dispatcher.1
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 6:: com.steinberg.dispatcher.2
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 7:: com.steinberg.dispatcher.3
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 8:: com.steinberg.dispatcher.4
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 9:: com.steinberg.dispatcher.5
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 10:: com.steinberg.dispatcher.6
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 11:: com.steinberg.dispatcher.7
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 12:: com.steinberg.dispatcher.manager
0 libsystem_kernel.dylib 0x00007fffacd83386 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fffacc3ea77 _os_semaphore_wait + 16
2 libdispatch.dylib 0x00007fffacc2f891 _dispatch_semaphore_wait_slow + 103
3 com.steinberg.cubase10v5 0x00000001033d10b2 0x10170d000 + 30163122
4 com.steinberg.cubase10v5 0x0000000103192066 0x10170d000 + 27807846
5 com.steinberg.cubase10v5 0x00000001033d0e64 0x10170d000 + 30162532
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 13:: com.steinberg.coremidi.notify
0 libsystem_kernel.dylib 0x00007fffacd8334a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fffacd82797 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff97457b44 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff97456fd1 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fff97456824 CFRunLoopRunSpecific + 420
5 com.apple.CoreFoundation 0x00007fff974962d1 CFRunLoopRun + 97
6 com.steinberg.cubase10v5 0x0000000101714c94 0x10170d000 + 31892
7 com.steinberg.cubase10v5 0x00000001033d0e64 0x10170d000 + 30162532
8 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 14:
2 com.apple.audio.midi.CoreMIDI 0x0000000105b5b9c1 XServerMachPort::ReceiveMessage(int&, void*, int&) + 107
3 com.apple.audio.midi.CoreMIDI 0x0000000105b71ba9 MIDIProcess::RunMIDIInThread() + 105
4 com.apple.audio.midi.CoreMIDI 0x0000000105b7ea9a XThread::RunHelper(void*) + 10
5 com.apple.audio.midi.CoreMIDI 0x0000000105b82053 CAPThread::Entry(CAPThread*) + 85
6 libsystem_pthread.dylib 0x00007ffface7593b _pthread_body + 180
7 libsystem_pthread.dylib 0x00007ffface75887 _pthread_start + 286
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 15:
0 libsystem_kernel.dylib 0x00007fffacd8abf2 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007ffface767fa _pthread_cond_wait + 712
2 libc++.1.dylib 0x00007fffab7a04cd std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3 com.apple.JavaScriptCore 0x00007fff9a46943c void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 108
4 com.apple.JavaScriptCore 0x00007fff9a4693bb bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 155
5 com.apple.JavaScriptCore 0x00007fff9a46928d bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadEntryPoint(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*) + 29
6 com.apple.JavaScriptCore 0x00007fff9a46953d void* std::__1::__thread_proxy<std::__1::tuple<void (*)(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*), bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*> >(void*) + 93
7 libsystem_pthread.dylib 0x00007ffface7593b _pthread_body + 180
8 libsystem_pthread.dylib 0x00007ffface75887 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 16:: StreamPreloadThread
1 libsystem_pthread.dylib 0x00007ffface76833 _pthread_cond_wait + 769
2 com.steinberg.GrooveAgentSE 0x000000011810b2a5 0x116671000 + 27894437
3 com.steinberg.GrooveAgentSE 0x0000000116ca7511 0x116671000 + 6513937
4 com.steinberg.GrooveAgentSE 0x000000011810b814 0x116671000 + 27895828
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 17:: StreamPreloadThread
2 com.steinberg.HALionSonicSE 0x000000011f49ecc5 0x11da15000 + 27827397
3 com.steinberg.HALionSonicSE 0x000000011e05c6bc 0x11da15000 + 6583996
4 com.steinberg.HALionSonicSE 0x000000011f49f234 0x11da15000 + 27828788
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 18:: Video Diascope
1 com.steinberg.videoengine 0x000000012e7537ca 0x12e577000 + 1951690
2 com.steinberg.videoengine 0x000000012e6f1abd 0x12e577000 + 1551037
3 com.steinberg.videoengine 0x000000012e752a94 0x12e577000 + 1948308
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 19:: Video Diascope
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 20:
2 libc++.1.dylib 0x00007fffab7a0572 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lock<std::__1::mutex>&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 126
3 com.paceap.eden.WrapPersist 0x0000000139074cbf 0x138e8c000 + 2002111
4 com.paceap.eden.WrapPersist 0x000000013907ba7b 0x138e8c000 + 2030203
5 com.paceap.eden.WrapPersist 0x000000013907ba02 0x138e8c000 + 2030082
6 com.paceap.eden.WrapPersist 0x000000013907b8d7 0x138e8c000 + 2029783
9 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 21:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fffacd8aeb6 __select + 10
1 com.apple.CoreFoundation 0x00007fff97492daa __CFSocketManager + 682
2 libsystem_pthread.dylib 0x00007ffface7593b _pthread_body + 180
3 libsystem_pthread.dylib 0x00007ffface75887 _pthread_start + 286
4 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 22:: StreamPreloadThread
2 com.steinberg.Backbone 0x000000013c8410de 0x13adae000 + 27865310
3 com.steinberg.Backbone 0x000000013b40fd3c 0x13adae000 + 6692156
4 com.steinberg.Backbone 0x000000013c8415d4 0x13adae000 + 27866580
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 23:: StreamPreloadThread
1 com.steinberg.Retrologue 0x0000000142bb84c2 0x1414b0000 + 24151234
2 com.steinberg.Retrologue 0x0000000141a5991a 0x1414b0000 + 5937434
3 com.steinberg.Retrologue 0x0000000142bb77a4 0x1414b0000 + 24147876
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 24:: VST Loader
0 libsystem_kernel.dylib 0x00007fffacd83392 semaphore_wait_signal_trap + 10
1 com.steinberg.cubase10v5 0x00000001031463c2 0x10170d000 + 27497410
2 com.steinberg.cubase10v5 0x0000000102c7559d 0x10170d000 + 22447517
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 25:: VST Loader
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 26:: VST Loader
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 27:: VST Loader
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 28:: VST Loader
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 29:: VST Loader
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 30:: VST Preloader
2 com.steinberg.cubase10v5 0x0000000102c763e0 0x10170d000 + 22451168
3 com.steinberg.cubase10v5 0x0000000102c759ea 0x10170d000 + 22448618
4 com.steinberg.cubase10v5 0x00000001031460e4 0x10170d000 + 27496676
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 31:: Video Preload
2 com.steinberg.videoengine 0x000000012e6b7032 0x12e577000 + 1310770
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 32:: Video Playback
2 com.steinberg.videoengine 0x000000012e60ba3e 0x12e577000 + 608830
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 33:: Video Buffer
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 34:: Timer
2 com.steinberg.cubase10v5 0x0000000102a8c368 0x10170d000 + 20444008
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 35:: MB Factory Scanner
2 com.steinberg.mediaservice 0x000000012e38a9eb 0x12e1f3000 + 1669611
3 com.steinberg.mediaservice 0x000000012e42b40b 0x12e1f3000 + 2327563
4 com.steinberg.mediaservice 0x000000012e38aff4 0x12e1f3000 + 1671156
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 36:: MB Database Writer
3 com.steinberg.mediaservice 0x000000012e23a027 0x12e1f3000 + 290855
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 37:: LRThread
1 com.steinberg.vst3.pluginset.cubase 0x0000000148f907aa 0x148eeb000 + 677802
2 com.steinberg.vst3.pluginset.cubase 0x000000014915c4c4 0x148eeb000 + 2561220
3 com.steinberg.vst3.pluginset.cubase 0x0000000148f8fa33 0x148eeb000 + 674355
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 38:: CIThread
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 39:: LRThread
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 40:: CIThread
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 41:: Baios Processing Thread
1 com.steinberg.baios 0x000000012e15549a 0x12e11d000 + 230554
2 com.steinberg.baios 0x000000012e13b75d 0x12e11d000 + 124765
3 com.steinberg.baios 0x000000012e154764 0x12e11d000 + 227172
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 42:
3 com.eLicenser.eLicenserCore-DLL 0x0000000150e20ea5 0x150de3000 + 253605
4 com.eLicenser.eLicenserCore-DLL 0x0000000150e20d4f 0x150de3000 + 253263
5 com.eLicenser.eLicenserCore-DLL 0x0000000150e20c1d 0x150de3000 + 252957
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 43:: MB Cleanup
2 com.steinberg.cubase10v5 0x0000000103145adb 0x10170d000 + 27495131
3 com.steinberg.cubase10v5 0x00000001032cbbca 0x10170d000 + 29092810
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 44:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fff965910f4 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6 com.apple.Foundation 0x00007fff98e7d11d __NSThread__start__ + 1243
9 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 45:: MB Value Collector
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 46:: JUCE Timer
3 com.eventide.spliteq 0x0000000176e13066 0x176b9e000 + 2576486
4 com.eventide.spliteq 0x0000000176e49f48 0x176b9e000 + 2801480
5 com.eventide.spliteq 0x0000000176e1c469 0x176b9e000 + 2614377
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 47:: Vst Prefetch Thread 0
2 com.steinberg.cubase10v5 0x0000000103327305 0x10170d000 + 29467397
3 com.steinberg.cubase10v5 0x0000000102cd4ac7 0x10170d000 + 22837959
4 com.steinberg.cubase10v5 0x0000000102cd3ab3 0x10170d000 + 22833843
5 com.steinberg.cubase10v5 0x0000000103327cdc 0x10170d000 + 29469916
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 48:: Vst Prefetch Thread 1
1 com.steinberg.cubase10v5 0x0000000103146397 0x10170d000 + 27497367
2 com.steinberg.cubase10v5 0x00000001033278b6 0x10170d000 + 29468854
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 49:: Vst Prefetch Thread 2
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 50:: Vst Prefetch Thread 3
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 51:: Vst Prefetch Thread 4
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 52:: Vst Prefetch Thread 5
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 53:: Vst Prefetch Thread 6
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 54:: Vst Prefetch Thread 7
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 55:: Vst CatchUp Thread 0
2 com.steinberg.cubase10v5 0x0000000102cd4837 0x10170d000 + 22837303
3 com.steinberg.cubase10v5 0x0000000102cd3ab3 0x10170d000 + 22833843
4 com.steinberg.cubase10v5 0x0000000103327cdc 0x10170d000 + 29469916
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 56:: Vst CatchUp Thread 1
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 57:: Vst CatchUp Thread 2
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 58:: Vst CatchUp Thread 3
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 59:: Vst CatchUp Thread 4
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 60:: Vst CatchUp Thread 5
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 61:: Vst CatchUp Thread 6
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 62:: Vst CatchUp Thread 7
5 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 63:: Vst Catchup Cycle Trigger Thread
1 com.steinberg.cubase10v5 0x0000000103146e7a 0x10170d000 + 27500154
2 com.steinberg.cubase10v5 0x0000000102cd3ef9 0x10170d000 + 22834937
3 com.steinberg.cubase10v5 0x0000000103327cdc 0x10170d000 + 29469916
4 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 64:: Vst Realtime Thread 1
3 com.steinberg.cubase10v5 0x0000000102cd4e37 0x10170d000 + 22838839
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 65:: Vst Realtime Thread 2
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 66:: Vst Realtime Thread 3
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 67:: Vst Realtime Thread 4
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 68:: Vst Realtime Thread 5
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 69:: Vst Realtime Thread 6
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 70:: Vst Realtime Thread 7
6 libsystem_pthread.dylib 0x00007ffface78d1e _pthread_suspended_body + 176Thread 71:: com.apple.coremedia.imagequeue.coreanimation
2 com.apple.CoreMedia 0x00007fff981dc1bb WaitOnCondition + 14
3 com.apple.CoreMedia 0x00007fff981dbe45 FigSemaphoreWaitRelative + 153
4 com.apple.MediaToolbox 0x00007fff9a9cb352 0x7fff9a7bf000 + 2147154
5 com.apple.CoreMedia 0x00007fff981dcb5a figThreadMain + 277
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 72:: com.apple.coremedia.videomediaconverter
4 com.apple.MediaToolbox 0x00007fff9a9c8ab6 0x7fff9a7bf000 + 2136758
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 73:: com.apple.coremedia.vtremotedecompressionclient.notifier
2 com.apple.VideoToolbox 0x00007fff9df2d150 0x7fff9de81000 + 704848
3 com.apple.CoreMedia 0x00007fff981dcb5a figThreadMain + 277
6 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 74:: com.apple.coremedia.scheduledfileio
4 com.apple.CoreMedia 0x00007fff981d3183 FigScheduledFileIOThread + 141
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 75:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 76:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 77:: com.apple.coremedia.vtremotedecompressionclient.notifier
6 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 78:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 79:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 80:
2 com.apple.AppleGVAFramework 0x00007fffa076f632 0x7fffa0736000 + 235058
3 com.apple.AppleGVAFramework 0x00007fffa076f561 0x7fffa0736000 + 234849
6 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 81:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 82:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 83:: com.apple.coremedia.vtremotedecompressionclient.notifier
6 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 84:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 85:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 86:
6 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 87:: com.apple.coremedia.imagequeue.coreanimation
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 88:: com.apple.coremedia.videomediaconverter
8 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 89:
6 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 90:: Dispatch queue: NSCGSDisableUpdates
2 com.apple.SkyLight 0x00007fffa8fa7f20 _CGSReenableUpdateForConnectionSync + 99
3 com.apple.SkyLight 0x00007fffa90ab532 CGSUpdateManager::enable_update(unsigned long long) + 532
4 libdispatch.dylib 0x00007fffacc2f524 _dispatch_call_block_and_release + 12
6 libdispatch.dylib 0x00007fffacc3c9a0 _dispatch_queue_serial_drain + 896
7 libdispatch.dylib 0x00007fffacc2f306 _dispatch_queue_invoke + 1046
8 libdispatch.dylib 0x00007fffacc286b5 _dispatch_root_queue_drain + 476
9 libdispatch.dylib 0x00007fffacc2848c _dispatch_worker_thread3 + 99
10 libsystem_pthread.dylib 0x00007ffface755a2 _pthread_wqthread + 1299
11 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 91:
0 libsystem_kernel.dylib 0x00007fffacd8b44e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007ffface75621 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 92:
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 93:
1 libsystem_pthread.dylib 0x00007ffface7548e _pthread_wqthread + 1023
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 94:
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 95:
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 96:
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 97:
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 98:
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 99:
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 100:
2 libsystem_pthread.dylib 0x00007ffface7507d start_wqthread + 13Thread 101:
1 libdispatch.dylib 0x00007fffacc3eb09 _os_semaphore_timedwait + 72
2 libdispatch.dylib 0x00007fffacc2f864 _dispatch_semaphore_wait_slow + 58
3 libdispatch.dylib 0x00007fffacc2a290 _dispatch_worker_thread + 275
6 libsystem_pthread.dylib 0x00007ffface7508d thread_start + 13Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff5e4f0da8 rdx: 0x0000000000000000
rdi: 0x0000000000000307 rsi: 0x0000000000000006 rbp: 0x00007fff5e4f0dd0 rsp: 0x00007fff5e4f0da8
r8: 0x00007fffacd19650 r9: 0x00007fffaccdba50 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x00007fff5e4f0f30 r13: 0x0000000000000030 r14: 0x00007fffb5b8c3c0 r15: 0x0000000000000008
rip: 0x00007fffacd8ad42 rfl: 0x0000000000000206 cr2: 0x00007fffb5b6e128Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133Binary Images:
0x10170d000 – 0x104d05ff7 +com.steinberg.cubase10v5 (10.5.30.365 – 10.5.30.365) <986B1B35-6098-388B-9CA3-E1005B39676D> /Applications/Cubase 10.5.app/Contents/MacOS/Cubase 10.5
0x105433000 – 0x105548fff +libgraphics2d.dylib (0) <D43124E4-BA39-33E3-92E4-33776535C76C> /Applications/Cubase 10.5.app/Contents/MacOS/libgraphics2d.dylib
0x105581000 – 0x105a70fc7 +libimagegenerator.dylib (0) <E9B941DC-C141-30BE-A1F9-8B75DD07D62D> /Applications/Cubase 10.5.app/Contents/MacOS/libimagegenerator.dylib
0x105b4e000 – 0x105b8cff7 com.apple.audio.midi.CoreMIDI (1.10 – 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x105bb9000 – 0x105bd2fff libexpat.1.dylib (15.1) <588CA992-60BB-363B-BEE7-3CC0A26C1AFA> /usr/lib/libexpat.1.dylib
0x107dcb000 – 0x107eebfff +com.eLicenser.POSAccess-DLL (1.32.0.1) <99B66B5E-4318-3C02-9F55-5B058EF232FF> /Library/Application Support/eLicenser/*/Synsoacc.bundle/Contents/MacOS/Synsoacc
0x10a3c6000 – 0x10a3cdffb com.apple.symptoms.SymptomReporter (1.0 – 1) <F60DF8ED-2625-3F1C-88C6-7A5D439CDB08> /System/Library/PrivateFrameworks/Symptoms.framework/Frameworks/SymptomReporter.framework/SymptomReporter
0x10ad5a000 – 0x10ad76fff +com.steinberg.hubservice (2.0.20.35 – 2.0.20.35) <61EF6DE9-9940-3A48-9E7A-AA7D389028A4> /Applications/Cubase 10.5.app/Contents/Components/hubservice.bundle/Contents/MacOS/hubservice
0x10aed1000 – 0x10aee3ff7 com.apple.webcontentfilter.framework (5.1 – 5.1) <A14119D8-EC14-30A2-8FF2-95FF52F97652> /System/Library/PrivateFrameworks/WebContentAnalysis.framework/WebContentAnalysis
0x10c24c000 – 0x10c277ff7 +com.steinberg.CoreAudio2ASIO (3.2.4.37 – 3.2.4.37) <360BB4EA-C129-3745-8838-F954619AC67C> /Applications/Cubase 10.5.app/Contents/Components/coreaudio2asio.bundle/Contents/MacOS/coreaudio2asio
0x10c288000 – 0x10c28cfff com.apple.audio.AppleHDAHALPlugIn (279.48 – 279.48) <ECA84145-2AC4-347D-BBC0-933AAAC15356> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x10c297000 – 0x10c297fff com.apple.VideoDecodeAcceleration (1.1 – 10) <E9B70867-70AE-392B-ACF3-AC9F08A18654> /System/Library/Frameworks/VideoDecodeAcceleration.framework/Versions/A/VideoDecodeAcceleration
0x10c29d000 – 0x10c2b1ff3 com.apple.AudioServerApplication (1.0 – 200.9) <4977039B-FC27-3D6E-9B3E-81B3071ADBB3> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServerApplication
0x10c2c1000 – 0x10c2c5fff +com.WavesAudio.WavesReWireDevice.10.0.0 (10.0.0 – 10.0.016) <486106C5-C489-3D53-9BA5-738A388EABED> /Library/Application Support/Propellerhead Software/*/WavesReWireDevice.bundle/Contents/MacOS/WavesReWireDevice
0x10d7f5000 – 0x10d7f7fff com.apple.AppleIntelSKLGraphicsVAME (10.25.24 – 10.2.5) <4A601592-DDA8-35FA-9AD1-8B926CB49D92> /System/Library/Extensions/AppleIntelSKLGraphicsVAME.bundle/Contents/MacOS/AppleIntelSKLGraphicsVAME
0x10dbf3000 – 0x10dc30dc7 dyld (434) <33DB4E37-BC29-37A4-92AB-30328E66A8FA> /usr/lib/dyld
0x10e45c000 – 0x10e602fff GLEngine (14.0.16) <C21BEA53-21B2-3EBB-84C6-CFCAB4D6012A> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x10e641000 – 0x10e707ffb com.apple.AMDRadeonX4000GLDriver (1.54.3 – 1.5.4) <40057C70-805F-3644-B70D-85001198E0A2> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x10e721000 – 0x10ec5fff3 ATIRadeonX4000SCLib.dylib (1.54.3) <F9943A58-F6F5-354B-B272-D2FDEBD4840D> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x10ecfe000 – 0x10ed28fff GLRendererFloat (14.0.16) <8CB95D3F-453E-3FD1-B9AE-E72E00A9562F> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x10f28c000 – 0x10f2a6ff7 com.apple.security.csparser (3.0 – 57740.60.30) <0BC326E3-8C75-354E-BD83-D792AB80EE5B> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x10f379000 – 0x10f3b8ffb com.apple.glut (3.6.9 – GLUT-3.6.9) <86C343B3-1F37-3359-922E-91A7E8656440> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
0x116357000 – 0x116377fff com.apple.CoreNLP (1.0 – 78.2) <B686BDA2-A162-3D70-9257-FEB0592DBD7E> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x116671000 – 0x11af5cfef +com.steinberg.GrooveAgentSE (5.0.40.237 – 5.0.40.237) <56B444CC-6089-382A-97EC-7B5111DB0693> /Library/Application Support/Steinberg/*/Groove Agent SE
0x11d93e000 – 0x11d974ff7 +se.propellerheads.rex.library (1.7.0 – 1.7.0) <55A4808A-FF69-8A7F-B907-32627CC33D78> /Users/USER/Library/Application Support/Propellerhead Software/*/REX Shared Library.bundle/Contents/MacOS/REX Shared Library
0x11da15000 – 0x1231c4f5f +com.steinberg.HALionSonicSE (3.4.30.148 – 3.4.30.148) <1B34A91B-7A86-356B-AD7F-1D4FFBAF5960> /Library/Application Support/Steinberg/*/HALion Sonic SE
0x129c5d000 – 0x129c6cfff com.apple.TimeSync (1.0 – 503.1) <D06817FE-7DEC-3F8C-9484-2EA4CFBC0889> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
0x129c7e000 – 0x129c89fff +com.avid.Sibelius-ReWireDevice (1.0.3 – 1.0.3) <DD55FF33-AA47-358F-B84B-1B593AF39155> /Applications/Sibelius.app/Contents/Resources/Sibelius ReWire Device.bundle/Contents/MacOS/Sibelius ReWire Device
0x12a493000 – 0x12c63b67f +net.steinberg.vsttransitcore (1.0.65 – 1.0.65) <8D88618E-5FBC-36F0-B2AA-5A5785CA51FD> /Library/Application Support/Steinberg/*/vsttransitcore.bundle/Contents/MacOS/vsttransitcore
0x12c877000 – 0x12c969fff +com.steinberg.aaffilterbundle (4.0.10.10 – 4.0.10.10) <19BD3F83-A8A3-3934-9EC4-D6DBF3F94743> /Applications/Cubase 10.5.app/Contents/Components/AAFfilter.bundle/Contents/MacOS/AAFfilter
0x12c9ea000 – 0x12caf1ff7 +com.steinberg.omffilter (4.0.20.70 – 4.0.20.70) <87661B78-8672-39BD-B6CC-9E720E98CD16> /Applications/Cubase 10.5.app/Contents/Components/omffilter.bundle/Contents/MacOS/omffilter
0x12cb06000 – 0x12df88fff +com.steinberg.vst3connectcomponents (4.0.44.360 – 4.0.44.360) <5C9A8884-76C6-3520-A7F9-16424EFD0D45> /Applications/Cubase 10.5.app/Contents/Components/vstconnect.bundle/Contents/MacOS/vstconnect
0x12e11d000 – 0x12e1cbfcf +com.steinberg.baios (2.8.0.75 – 2.8.0.75) <965C8F04-C959-3000-ACBC-3CCD71B652F2> /Applications/Cubase 10.5.app/Contents/Components/baios.bundle/Contents/MacOS/baios
0x12e1f3000 – 0x12e526fff +com.steinberg.mediaservice (2.4.1.2 – 2.4.1.2) <AA6CB5D9-5FC6-3F43-81DC-FF063677ADE8> /Applications/Cubase 10.5.app/Contents/Components/mediaservice.bundle/Contents/MacOS/mediaservice
0x12e577000 – 0x12f0f8ff7 +com.steinberg.videoengine (3.0.1.9 – 3.0.1.9) <FEA391E3-23AA-3C42-AEA8-62C5EF574DF1> /Applications/Cubase 10.5.app/Contents/Components/videoengine.bundle/Contents/MacOS/videoengine
0x132dc0000 – 0x132e2bff7 +se.propellerheads.rewire.library (1.8.7 build 145 – 1.8.7) <B284579F-660F-3550-8327-64DBEDC9A218> /Library/Application Support/Propellerhead Software/*/ReWire.bundle/Contents/MacOS/ReWire
0x132e3e000 – 0x133596fff +com.ableton.live-engine (9.7.7 [2018-06-22_b058f6a52c] – 9.7.7 [2018-06-22_b058f6a52c]) <CF4B6A67-D8F8-3818-9659-657AA18BFA68> /Applications/Ableton Live 9 Standard.app/Contents/Resources/Ableton Live Engine.bundle/Contents/MacOS/Ableton Live Engine
0x133958000 – 0x1339b4ff7 com.apple.audio.CoreAudioKit (1.6.6 – 1.6.6) <DD6F8D1F-69EE-335A-8654-72B24E25423D> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x1339fa000 – 0x133b26ff7 com.apple.AudioVideoBridging (506.1 – 506.1) <ABFF7D29-9D86-37CD-9F05-2D5388ECDA09> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
0x133bdb000 – 0x133c63fff +se.propellerheads.rewire.library (1.8.2 build 127 – 1.8.2) <5F06EB11-5154-02BE-9431-8FCD77CF0173> /Users/USER/Library/Application Support/Propellerhead Software/*/ReWire.bundle/Contents/MacOS/ReWire
0x133c9c000 – 0x133dd2fff +com.steinberg.araservice (1.0.30.21 – 1.0.30.21) <6BE3E533-1801-35AB-B478-EF179821C887> /Applications/Cubase 10.5.app/Contents/Components/araservice.bundle/Contents/MacOS/araservice
0x133df0000 – 0x133ed5ff7 +com.celemony.melodyne.vst3 (5.1.1 – 5.1.1.003) <933848AD-B9E6-3E20-AF86-66749E657BBC> /Library/Audio/Plug-Ins/VST3/Melodyne.vst3/Contents/MacOS/Melodyne
0x133ef7000 – 0x133f4bff7 +com.Steinberg.SpectraLayers.vst3 (7.0.30.251 – 7.0.30.251) <DB29B5C8-1749-35A4-9F13-922EA1C3190C> /Library/Audio/Plug-Ins/VST3/SpectraLayers.vst3/Contents/MacOS/SpectraLayers.vst3
0x133f9b000 – 0x134b20fcf +com.steinberg.audioalignment (1.4.10.11 – 1.4.10.11) <FD78AE63-E03A-3342-B9B8-EDA72B61CAF2> /Applications/Cubase 10.5.app/Contents/Components/audioalignment.bundle/Contents/MacOS/audioalignment
0x134b78000 – 0x134cd0ff7 +com.steinberg.Eucon (7.3.0.6 – 7.3.0.6) <112C2C14-F011-39EC-A553-FE85F5F5262E> /Applications/Cubase 10.5.app/Contents/Components/euconadapter.bundle/Contents/MacOS/euconadapter
0x134d0e000 – 0x134d7cff7 +com.steinberg.headtracking (1.3.0.42 – 1.3.0.42) <FA270F4F-7319-3049-B0A0-8F54B842BDA1> /Applications/Cubase 10.5.app/Contents/Components/headtracking.bundle/Contents/MacOS/headtracking
0x134d8e000 – 0x134da0fff +com.steinberg.hostchannelaccess (1.1.10.10 – 1.1.10.10) <0544F5BF-C5F6-3300-8587-CF1984815E08> /Applications/Cubase 10.5.app/Contents/Components/hostchannelaccess.bundle/Contents/MacOS/hostchannelaccess
0x134dac000 – 0x134dcdfff +net.steinberg.goproremoteski (1.01 – 1.0) <FF0907BD-B92C-3AD0-88DE-F3CA5CF50091> /Applications/Cubase 10.5.app/Contents/Components/goproremoteski.bundle/Contents/MacOS/goproremoteski
0x134dd8000 – 0x134e6aff7 +com.steinberg.VSTPlugManager (3.1.80.32 – 3.1.80.32) <A2810326-D39F-3B64-93F7-CCB6BB9BE938> /Applications/Cubase 10.5.app/Contents/Components/VSTPlugManager.bundle/Contents/MacOS/VSTPlugManager
0x1353bd000 – 0x1353c2ffb +de.steinberg.hwremote.FaderPort_Cubase (2.0.0.0) <11287B7F-79E6-351C-B3BE-A9C2ADFCE044> /Library/Application Support/Steinberg/*/FaderPort_Cubase.bundle/Contents/MacOS/FaderPort_Cubase
0x1366d9000 – 0x138b3f57f +com.celemony.melodyne.shared (5.1.1 – 5.1.1.003) <42E71906-2356-38BB-83DB-2B276C007C3A> /Library/Application Support/Celemony/*/MelodyneCore
0x138e8c000 – 0x13916fff7 +com.paceap.eden.WrapPersist (5.3.1 GM [b3099, 7ac2feeb3d] – 5.3.1.3099) <65AFC25E-B288-3280-BB8F-3274D9BC3F6D> /Library/Frameworks/PACEEdenExperience.framework/Versions/Current/WrapPersist.bundle/Contents/MacOS/WrapPersist
0x1391b0000 – 0x13abfc15f +net.steinberg.vsttransitextension (1.0.14 – 1.0.14) <A5912A5F-A12C-36C9-B510-3514C2C6A8E6> /Library/Application Support/Steinberg/*/vsttransit.bundle/Contents/MacOS/vsttransit
0x13adae000 – 0x14024ff0f +com.steinberg.Backbone (1.1.10.151 – 1.1.10.151) <41239E30-DBC2-33D6-8A8F-024046ACAC80> /Library/Audio/Plug-Ins/VST3/Steinberg/Backbone.vst3/Contents/MacOS/Backbone
0x1414b0000 – 0x145860f7f +com.steinberg.Retrologue (2.2.50.249 – 2.2.50.249) <4E09C69D-9D10-36DD-9FB3-3875AB49CE1F> /Library/Audio/Plug-Ins/VST3/Steinberg/Retrologue.vst3/Contents/MacOS/Retrologue
0x148eeb000 – 0x14bbebf57 +com.steinberg.vst3.pluginset.cubase (9.0.10.289 – 9.0.10.289) <F5A546BF-613A-3E58-AB9E-99AA19C90169> /Applications/Cubase 10.5.app/Contents/VST3/Cubase Plug-in Set.vst3/Contents/MacOS/Cubase Plug-in Set
0x14bfca000 – 0x14f8e0ecf +com.steinberg.vst3connect (4.0.44.360 – 4.0.44.360) <7768A63A-D641-3AA1-821D-69002B52E5E3> /Applications/Cubase 10.5.app/Contents/VST3/VST Connect.vst3/Contents/MacOS/vstconnectplug
0x150de3000 – 0x15107c713 +com.eLicenser.eLicenserCore-DLL (2.0.5.563) <58BD1FDD-E368-330F-B3CD-1135EF42C673> /Library/Application Support/eLicenser/*/eLicenserCore.framework/eLicenserCore
0x176b9e000 – 0x177dfdffb +com.eventide.spliteq (1.0.4 – 1.0.4) <FB753B99-310F-3138-8682-8E5DB440A97C> /Library/Audio/Plug-Ins/VST3/Eventide/SplitEQ.vst3/Contents/MacOS/SplitEQ
0x18dab6000 – 0x18dd1afff com.apple.AppleIntelSKLGraphicsVADriver (10.25.24 – 10.2.5) <9D005C89-8051-39C4-8687-5684EC996202> /System/Library/Extensions/AppleIntelSKLGraphicsVADriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsVADriver
0x18ddae000 – 0x18de2dfff com.apple. AMDRadeonVADriver (1.54.3 – 1.5.4) <F445222C-E2C6-3380-9C20-0F0A82CC64C5> /System/Library/Extensions/AMDRadeonVADriver.bundle/Contents/MacOS/AMDRadeonVADriver
0x18dee0000 – 0x18df2bff7 com.apple.AppleVADriver (5.0.36 – 5.0.36) <A6209C7C-918E-3A88-AE5F-89489D3AB70C> /System/Library/Extensions/AppleVADriver.bundle/Contents/MacOS/AppleVADriver
0x7fff9207e000 – 0x7fff923c3ff7 com.apple.RawCamera.bundle (7.04 – 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff923c4000 – 0x7fff924f5ff3 com.apple.AMDMTLBronzeDriver (1.54.3 – 1.5.4) <CAFA217E-CF84-382A-9B95-0036284ECBE5> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x7fff93bf3000 – 0x7fff93bf7ffb com.apple.agl (3.3.1 – AGL-3.3.1) <F44A14D8-1999-38BD-9B60-5E28B314C458> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff93bf8000 – 0x7fff93db9fff com.apple.avfoundation (2.0 – 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff93dba000 – 0x7fff93e5cff7 com.apple.audio.AVFAudio (1.0 – ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff93e5d000 – 0x7fff93f26ff3 com.apple.AVKit (1.1 – 356.12) <1A0929CC-BD23-377D-8A22-6C092409AA9D> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
0x7fff93f27000 – 0x7fff93f27fff com.apple.Accelerate (1.11 – Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff93f28000 – 0x7fff93f3fffb libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff93f40000 – 0x7fff94459feb com.apple.vImage (8.1 – ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff9445a000 – 0x7fff945cbff3 libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff945cc000 – 0x7fff945e0ffb libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff945e1000 – 0x7fff949d7fef libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff949d8000 – 0x7fff949eefff libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff949ef000 – 0x7fff949f5fff libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff949f6000 – 0x7fff94a0aff7 libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff94a0b000 – 0x7fff94b92fe7 libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff94b93000 – 0x7fff94c45fff libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff94c46000 – 0x7fff94c46fff com.apple.Accelerate.vecLib (3.11 – vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff94f05000 – 0x7fff95cdeff3 com.apple.AppKit (6.9 – 1504.84.100) <E39CD613-0104-3E26-B424-BE83CED656F9> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff95cf0000 – 0x7fff95cf0fff com.apple.ApplicationServices (48 – 48) <36EB2785-BBD2-33F0-BB13-8C804D47110A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff95cf1000 – 0x7fff95d5fff7 com.apple.ApplicationServices.ATS (377 – 422.4) <78B556FF-28E6-3147-AE0D-8E0EC45EEE77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff95df9000 – 0x7fff95f28fff libFontParser.dylib (194.15) <FF329191-6339-363E-9D95-FFE9D55E7F60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff95f29000 – 0x7fff95f73ff7 libFontRegistry.dylib (196.8) <5E5F95FD-F69B-3F1A-9592-C0AB8F5FF57C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff95fd1000 – 0x7fff96004fff libTrueTypeScaler.dylib (194.15) <513743F9-500B-37C5-A925-A82E7182F3E9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff96071000 – 0x7fff9611bff7 com.apple.ColorSync (4.12.0 – 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff9611c000 – 0x7fff9616dfff com.apple.HIServices (1.22 – 594) <EF8432A1-15C5-360C-9D14-19ADA43FCFDC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff9616e000 – 0x7fff9617dff3 com.apple.LangAnalysis (1.7.0 – 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff9617e000 – 0x7fff961cbfff com.apple.print.framework.PrintCore (12 – 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff961cc000 – 0x7fff96207fff com.apple.QD (3.12 – 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff96208000 – 0x7fff96213fff com.apple.speech.synthesis.framework (6.6.2 – 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff96214000 – 0x7fff96420ff7 com.apple.audio.toolbox.AudioToolbox (1.14 – 1.14) <1F4026C6-23C1-39E8-823D-72298FECF75C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff96421000 – 0x7fff96421fff com.apple.audio.units.AudioUnit (1.14 – 1.14) <2CEE36AF-79E6-3B3E-B369-285E6C1886F7> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff9658a000 – 0x7fff96967fff com.apple.CFNetwork (811.11 – 811.11) <5E5A7D4D-BCBA-3995-8C13-4D01DE1FAB33> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff96981000 – 0x7fff96981fff com.apple.Carbon (154 – 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff96982000 – 0x7fff96985fff com.apple.CommonPanels (1.2.6 – 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff96986000 – 0x7fff96c8ffff com.apple.HIToolbox (2.1.1 – 857.8) <25E0AC26-27FE-32E5-9226-F4D42B25ED30> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff96c90000 – 0x7fff96c93ff7 com.apple.help (1.3.5 – 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff96c94000 – 0x7fff96c99fff com.apple.ImageCapture (9.0 – 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff96c9a000 – 0x7fff96d31ff3 com.apple.ink.framework (10.9 – 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff96d32000 – 0x7fff96d4cfff com.apple.openscripting (1.7 – 172.1) <78F3256B-AF4C-324A-A591-ECA4443A469F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff96d4d000 – 0x7fff96d4eff3 com.apple.print.framework.Print (12 – 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff96d4f000 – 0x7fff96d51ff7 com.apple.securityhi (9.0 – 55006) <0DA7BABC-CE24-35FC-BF23-8EDF72D8C237> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff96d52000 – 0x7fff96d58ff7 com.apple.speech.recognition.framework (6.0.1 – 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff96d59000 – 0x7fff96e38ffb com.apple.cloudkit.CloudKit (651.14 – 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff96e39000 – 0x7fff96e39fff com.apple.Cocoa (6.11 – 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff96f83000 – 0x7fff97010fff com.apple.audio.CoreAudio (4.3.0 – 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff97011000 – 0x7fff97024fff com.apple.CoreBluetooth (1.0 – 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff97025000 – 0x7fff97320fff com.apple.CoreData (120 – 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff97321000 – 0x7fff973ceff7 com.apple.CoreDisplay (1.0 – 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff973cf000 – 0x7fff9786bfe7 com.apple.CoreFoundation (6.9 – 1350.10) <60A73360-EE24-33A2-BF37-08CB8B96D2D9> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff9786c000 – 0x7fff97eeefff com.apple.CoreGraphics (2.0 – 1070.22.1) <8A053296-AA99-371C-B9C5-FCBF87C6CEFE> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff97eef000 – 0x7fff98132ffb com.apple.CoreImage (12.4.0 – 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff98133000 – 0x7fff98198ff7 com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff98199000 – 0x7fff9824afff com.apple.CoreMedia (1.0 – 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff9824b000 – 0x7fff98296ff7 com.apple.CoreMediaIO (805.0 – 4932) <2A8AAD00-4F29-39C3-A371-3A8BA6200CAA> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff98297000 – 0x7fff98297fff com.apple.CoreServices (775.20 – 775.20) <22D3892B-719C-30B8-B84B-211CFE41AFA5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff98298000 – 0x7fff982e9fff com.apple.AE (712.6 – 712.6) <9E9B4EC3-564D-3BA9-A9A4-1603E1F97F40> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff982ea000 – 0x7fff985c5ff7 com.apple.CoreServices.CarbonCore (1159.8 – 1159.8) <2B661676-E4F2-3E6F-BD25-DB685FCCA06A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff985c6000 – 0x7fff985f9fff com.apple.DictionaryServices (1.2 – 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff985fa000 – 0x7fff98602ff3 com.apple.CoreServices.FSEvents (1230.50.1 – 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff98603000 – 0x7fff9876fffb com.apple.LaunchServices (775.20 – 775.20) <9106FF16-9587-313F-822C-2CD56204903E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff98770000 – 0x7fff98820ffb com.apple.Metadata (10.7.0 – 1075.41) <FE2BC948-5014-3C50-9ED7-F9544B611363> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff98821000 – 0x7fff98880fff com.apple.CoreServices.OSServices (775.20 – 775.20) <82D7E763-999D-31A0-AAE7-4F7A40105739> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff98881000 – 0x7fff988f1fff com.apple.SearchKit (1.4.0 – 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff988f2000 – 0x7fff98937ff7 com.apple.coreservices.SharedFileList (38 – 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff989c0000 – 0x7fff98b0dffb com.apple.CoreText (352.0 – 544.18) <B883809B-561B-31C5-949E-D2564B6F808A> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff98b0e000 – 0x7fff98b43ff3 com.apple.CoreVideo (1.8 – 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff98b44000 – 0x7fff98bb5ffb com.apple.framework.CoreWLAN (11.0 – 1200.31) <7300F2B4-0976-37F3-95E9-4B3BC102ED01> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff98be8000 – 0x7fff98bf3ff3 com.apple.DirectoryService.Framework (10.12 – 194) <45BEA292-4550-3082-8CE7-5D6CE7E0052A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff98bf4000 – 0x7fff98cb2ff7 com.apple.DiscRecording (9.0.3 – 9030.4.5) <9397E609-CB54-37B2-B28E-D4BC6C34BFAB> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff98cb3000 – 0x7fff98cb8fff com.apple.DiskArbitration (2.7 – 2.7) <F47E07A4-D69D-312A-82C8-A1EE3C7C0EAC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff98e4a000 – 0x7fff991f2ff7 com.apple.Foundation (6.9 – 1349.93) <A3CF1205-DE81-37FE-A574-0D381DECF122> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff9921e000 – 0x7fff9924ffff com.apple.GSS (4.0 – 2.0) <453B5C6D-08B0-3199-AFC8-C71BABD6B704> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff9930f000 – 0x7fff993b2ff7 com.apple.Bluetooth (5.0.5 – 5.0.5f7) <DC83B429-A8C1-34F1-9FD9-C9BB99156DBE> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff993b3000 – 0x7fff99449fff com.apple.framework.IOKit (2.0.2 – 1324.60.8) <46DA8966-AC27-3F51-BBB2-359A229BB0F7> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff9944a000 – 0x7fff99450ffb com.apple.IOSurface (159.12 – 159.12) <E3D6FCED-F938-30A3-AD08-0998B674A492> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff99451000 – 0x7fff994a2ff7 com.apple.ImageCaptureCore (7.0 – 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff994a3000 – 0x7fff99603fef com.apple.ImageIO.framework (3.3.0 – 1599.13.1) <B48585FF-3B2D-32F6-85A6-07ECDDB2A6E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff99604000 – 0x7fff99608fff libGIF.dylib (1599.13.1) <79C31DCF-3D95-32DE-9869-C1FA91F7C572> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff99609000 – 0x7fff996f9ff7 libJP2.dylib (1599.13.1) <5E34964D-36BC-3DDD-936B-D859B39117BB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff996fa000 – 0x7fff9971dffb libJPEG.dylib (1599.13.1) <863E6D9C-E45A-33F7-8C52-2D2B81FCAE63> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff9971e000 – 0x7fff99745ff7 libPng.dylib (1599.13.1) <06282D7B-70EC-34A5-9240-A80FD18DC2D0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff99746000 – 0x7fff99748ff3 libRadiance.dylib (1599.13.1) <823DDB0C-6BD0-3073-ABE4-313FDA38E3B4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff99749000 – 0x7fff99797fff libTIFF.dylib (1599.13.1) <B48CCFEF-BD6E-37EA-8F1C-CC2CF6775A0E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff998f5000 – 0x7fff9a4fffff com.apple.JavaScriptCore (12603 – 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff9a500000 – 0x7fff9a519ff7 com.apple.Kerberos (3.0 – 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff9a51a000 – 0x7fff9a550fff com.apple.LDAPFramework (2.4.28 – 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff9a551000 – 0x7fff9a574fff com.apple.speech.LatentSemanticMappingFramework (2.12.2 – 2.12.2) <E68CF07A-6EFB-34E6-B103-BEBE4AD57521> /System/Library/Frameworks/LatentSemanticMapping.framework/Versions/A/LatentSemanticMapping
0x7fff9a7a3000 – 0x7fff9a7a9fff com.apple.MediaAccessibility (1.0 – 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff9a7bf000 – 0x7fff9acf8ff7 com.apple.MediaToolbox (1.0 – 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff9acf9000 – 0x7fff9ad54fff com.apple.Metal (87.18 – 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff9b63d000 – 0x7fff9b645fff com.apple.NetFS (6.0 – 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff9b646000 – 0x7fff9b781fff com.apple.NetworkExtension (1.0 – 1) <B3037FB4-3A47-34E9-89FE-FE9AC27C8BFE> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
0x7fff9b81c000 – 0x7fff9b824ff7 libcldcpuengine.dylib (2.8.5) <0D182C1C-2593-34C8-B454-78D3F5FF5724> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff9b825000 – 0x7fff9b873ff3 com.apple.opencl (2.8.6 – 2.8.6) <E7958F3E-F56C-35EC-87CD-6ADFC25D4512> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff9b874000 – 0x7fff9b88dffb com.apple.CFOpenDirectory (10.12 – 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff9b88e000 – 0x7fff9b899ff7 com.apple.OpenDirectory (10.12 – 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff9b89a000 – 0x7fff9b89cfff libCVMSPluginSupport.dylib (14.0.16) <25655EB3-7BF6-36EC-BD17-47F4DF499D7F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff9b89d000 – 0x7fff9b8a0ff7 libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff9b8a1000 – 0x7fff9b8a5fff libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff9b8a6000 – 0x7fff9b8afff7 libGFXShared.dylib (14.0.16) <679D8495-1C5F-3932-A452-050A21E0EEBB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff9b8b0000 – 0x7fff9b8bbfff libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff9b8bc000 – 0x7fff9b8f8ff7 libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff9b8f9000 – 0x7fff9ba6fff3 libGLProgrammability.dylib (14.0.16) <46B8611A-D245-33BF-AA38-E44B2119DA12> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff9ba70000 – 0x7fff9bab1ff7 libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff9c419000 – 0x7fff9c427fff com.apple.opengl (14.0.16 – 14.0.16) <8D4CC067-4A70-34AE-945D-29407D780452> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff9c4c4000 – 0x7fff9c60bfff com.apple.QTKit (7.7.3 – 2978.8) <80B27C5D-087F-3B83-AF99-AD6BA2E1105D> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff9c60c000 – 0x7fff9c876ff7 com.apple.imageKit (3.0 – 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff9c877000 – 0x7fff9c93efff com.apple.PDFKit (1.0 – 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff9c93f000 – 0x7fff9ce65ff7 com.apple.QuartzComposer (5.1 – 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff9ce66000 – 0x7fff9ce89ffb com.apple.quartzfilters (1.10.0 – 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff9ce8a000 – 0x7fff9cf77fff com.apple.QuickLookUIFramework (5.0 – 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff9cf78000 – 0x7fff9cf78fff com.apple.quartzframework (1.5 – 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff9cf79000 – 0x7fff9d179fff com.apple.QuartzCore (1.11 – 453.41.2) <564FBF07-0072-3587-91BE-7B0EFD6FBC1D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff9d17a000 – 0x7fff9d1cffff com.apple.QuickLookFramework (5.0 – 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff9d1d0000 – 0x7fff9d1e9fff com.apple.SafariServices.framework (12607 – 12607.3.10) <481200D1-0ED9-33C0-AFDB-0EF2246DCF3D> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff9d6cc000 – 0x7fff9d6e3ff7 com.apple.ScriptingBridge (1.3.3 – 69) <F51B85CD-9C80-317E-B594-4A03612EAF52> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff9d6e4000 – 0x7fff9d9e6fff com.apple.security (7.0 – 57740.60.30) <2DD7275B-40E5-3F8C-8258-8C73DD3EE438> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff9d9e7000 – 0x7fff9da5cfff com.apple.securityfoundation (6.0 – 55132.50.7) <2AF6A217-45D3-30C2-86B6-F35AF827E698> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff9da87000 – 0x7fff9da8aff3 com.apple.xpc.ServiceManagement (1.0 – 1) <F2AACDEF-7DCC-35B9-A6B6-119FF8D83DBB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff9de11000 – 0x7fff9de80ff7 com.apple.SystemConfiguration (1.14 – 1.14) <98E76341-BB2F-3DF4-9DD4-F4AC7648EF0F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff9de81000 – 0x7fff9e22ffff com.apple.VideoToolbox (1.0 – 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff9e230000 – 0x7fff9f5b7ff3 com.apple.WebCore (12603 – 12603.3.8) <FE0B8503-5E89-3D55-BF48-1370FE81910A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff9f5b8000 – 0x7fff9f7a4ff3 com.apple.WebKitLegacy (12603 – 12603.3.8) <28A763DA-BA6C-3350-8200-6DEA86FF7878> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff9f7a5000 – 0x7fff9fb50fff com.apple.WebKit (12603 – 12603.3.8) <38192059-8C02-3BBC-BF1F-E1D5E3150E16> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff9ff5c000 – 0x7fff9ff63ffb com.apple.APFS (1.0 – 1) <6E79797E-26BD-3E49-891C-03B223F7BD59> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fffa06d9000 – 0x7fffa06f4ff3 com.apple.AppContainer (4.0 – 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fffa06f5000 – 0x7fffa0702ff3 com.apple.AppSandbox (4.0 – 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fffa0703000 – 0x7fffa0725ffb com.apple.framework.Apple80211 (12.0 – 1200.47.1) <F362FADE-B6F5-32B5-84E8-C3CE7FE5F851> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fffa0726000 – 0x7fffa0735feb com.apple.AppleFSCompression (88.50.3 – 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fffa0736000 – 0x7fffa07fefff com.apple.AppleGVAFramework (10.1.17 – 10.1.17) <0CA32A97-33A7-3A28-9508-7C73471BC7D2> /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
0x7fffa0826000 – 0x7fffa08b197f com.apple.AppleJPEG (1.0 – 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fffa08e1000 – 0x7fffa08e9ffb com.apple.AppleSRP (5.0 – 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fffa08ea000 – 0x7fffa08edff3 com.apple.AppleSystemInfo (3.1.5 – 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fffa08ee000 – 0x7fffa0940fff com.apple.AppleVAFramework (5.0.36 – 5.0.36) <149E882D-5DB1-3A2A-9D61-1D7C9A71A0D5> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fffa094a000 – 0x7fffa0951ff7 com.apple.AssetCacheServices (48.3 – 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fffa0ce4000 – 0x7fffa0d62ff7 com.apple.backup.framework (1.8.6 – 1.8.6) <2D75451A-8818-3D72-8480-489DF77D708B> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fffa0d8b000 – 0x7fffa0dc8ffb com.apple.bom (14.0 – 194.1.5) <304CDDD5-F138-3B3E-97B4-69CA7CE3D7CE> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fffa19ed000 – 0x7fffa1a14ff3 com.apple.ChunkingLibrary (173 – 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fffa1a15000 – 0x7fffa1aa1ff7 com.apple.CloudDocs (1.0 – 486.30) <74EA66DC-294A-3AFA-9FDF-711926907A35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fffa2339000 – 0x7fffa2342ffb com.apple.CommonAuth (4.0 – 2.0) <A71AD8F9-5CC8-3072-8A0B-F5427D3E8163> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffa24c7000 – 0x7fffa28a6ff7 com.apple.CoreAUC (226.0.0 – 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fffa28a7000 – 0x7fffa28d7fff com.apple.CoreAVCHD (5.9.0 – 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fffa2972000 – 0x7fffa297affb com.apple.frameworks.CoreDaemon (1.3 – 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fffa2a8b000 – 0x7fffa2a9bfff com.apple.CoreEmoji (1.0 – 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fffa2b60000 – 0x7fffa2b76ff3 com.apple.CoreMediaAuthoring (2.2 – 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fffa2b7d000 – 0x7fffa2c0dffb com.apple.CorePDF (4.0 – 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fffa2dd6000 – 0x7fffa2e06ff3 com.apple.CoreServicesInternal (276.2 – 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fffa3097000 – 0x7fffa3126ff7 com.apple.CoreSymbolication (62046) <2D4C3324-B647-3696-B92E-AAB1053EEB54> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fffa3127000 – 0x7fffa3266fe7 com.apple.coreui (2.1 – 431.3) <8D0FA478-9B6C-3D6D-8ADF-8677BA0BF134> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fffa3267000 – 0x7fffa3337ff3 com.apple.CoreUtils (5.1 – 510.31) <B6636BBF-D37E-360E-A3EE-61BDC1736EEA> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fffa3387000 – 0x7fffa33ecff3 com.apple.framework.CoreWiFi (12.0 – 1200.31) <1B3FE242-8AEB-38BD-84A4-65DBC476FEEA> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffa33ed000 – 0x7fffa33fbff7 com.apple.CrashReporterSupport (10.12 – 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fffa346d000 – 0x7fffa3477ffb com.apple.framework.DFRFoundation (1.0 – 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fffa3478000 – 0x7fffa347cff3 com.apple.DSExternalDisplay (3.1 – 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fffa34b2000 – 0x7fffa3527ffb com.apple.datadetectorscore (7.0 – 539.1) <D84B64BA-CD56-368E-A31A-AC47C3780D0B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffa3563000 – 0x7fffa35a2fff com.apple.DebugSymbols (137 – 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fffa35a3000 – 0x7fffa36b4fff com.apple.desktopservices (1.11.6 – 1.11.6) <225B3746-8626-34CD-8FA9-48A7C04ACCCF> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fffa36b9000 – 0x7fffa378efff com.apple.DiskImagesFramework (444.50.19 – 444.50.19) <A7C95C24-44EE-3EF0-BE04-628DFD04D57C> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fffa37f7000 – 0x7fffa3802fff com.apple.DisplayServicesFW (3.1 – 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fffa3811000 – 0x7fffa3846ff3 com.apple.SystemConfiguration.EAP8021X (14.0.0 – 14.0) <C773F8F3-3A7A-37EC-9990-C5FE10609965> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
0x7fffa3847000 – 0x7fffa3849ffb com.apple.EFILogin (2.0 – 2) <A74B0065-643F-3BC1-8FE9-E7CEAA29AD9A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fffa399c000 – 0x7fffa3dcdff7 com.apple.vision.FaceCore (3.3.2 – 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffa5124000 – 0x7fffa5124fff libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fffa5131000 – 0x7fffa513cff3 libGPUSupportMercury.dylib (14.0.16) <BE0ED0DC-DDE4-32F0-9315-39678785A538> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fffa53f5000 – 0x7fffa5411fff com.apple.GenerationalStorage (2.0 – 267.2) <22381303-B9A8-32D8-BDBF-871F0CDD81A5> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fffa542a000 – 0x7fffa5adcfff com.apple.GeoServices (1.0 – 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fffa5b22000 – 0x7fffa5b98ff3 com.apple.Heimdal (4.0 – 2.0) <9E554667-2A6D-3A86-883A-50C8AF98D0C0> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fffa61a8000 – 0x7fffa61b2fff com.apple.IOAccelMemoryInfo (1.0 – 1) <1E1A0D0F-681B-32E7-B849-772C7B0DFBD2> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fffa61b3000 – 0x7fffa61baffb com.apple.IOAccelerator (311.16.4 – 311.16.4) <F41EB563-1439-3745-BE98-4A4B6F45A7DF> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fffa61bc000 – 0x7fffa61d0ff7 com.apple.IOPresentment (1.0 – 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fffa61d1000 – 0x7fffa61f3fff com.apple.IconServices (74.4 – 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fffa628f000 – 0x7fffa629fff3 com.apple.IntlPreferences (2.0 – 216) <7A417848-2A43-35A3-9CD4-61F33D573C56> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fffa62da000 – 0x7fffa6491fff com.apple.LanguageModeling (1.0 – 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fffa64dd000 – 0x7fffa64e1ff7 com.apple.LoginUICore (4.0 – 4.0) <44AE6B20-40EF-3437-9D1B-134B5E006017> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fffa658d000 – 0x7fffa664fff3 com.apple.MMCS (1.3 – 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fffa6b01000 – 0x7fffa6b04fff com.apple.Mangrove (1.0 – 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fffa6bdd000 – 0x7fffa6c11ff3 com.apple.MediaKit (16 – 845) <883DC63F-F90F-3FB9-8C23-9CECD72EBCDE> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fffa6c12000 – 0x7fffa6d72ffb com.apple.MediaRemote (1.0 – 1) <24B6D0D5-E41F-366E-8881-BD427639BD34> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
0x7fffa6d73000 – 0x7fffa6d8effb com.apple.MediaServices (1.0 – 1) <C7097932-E6BF-396A-B838-785000FBF58D> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
0x7fffa6db2000 – 0x7fffa6e2bff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 – 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fffa6e3d000 – 0x7fffa6fa8ff7 com.apple.mobiledevice (988.250.11.100.2 – 988.250.11.100.2) <E3A6F6AC-EF91-3A77-8AD8-82D51C7F0388> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
0x7fffa6fa9000 – 0x7fffa6fb7fff com.apple.MobileKeyBag (2.0 – 1.0) <F30A4E9C-FAB8-3FD7-B881-5021F40C12FB> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fffa6fc8000 – 0x7fffa6ff0ff7 com.apple.MultitouchSupport.framework (368.16 – 368.16) <F6EFB289-F4B1-36E7-88D4-D1C7B1630A23> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fffa70a2000 – 0x7fffa70adfff com.apple.NetAuth (6.2 – 6.2) <E1D6BFF0-7F37-3866-9925-5DF40EB3A1F4> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fffa70ba000 – 0x7fffa7137fff com.apple.Network (1.0 – 1) <1B93BA06-3544-370F-8349-471826F5B24C> /System/Library/PrivateFrameworks/Network.framework/Versions/A/Network
0x7fffa7986000 – 0x7fffa79c7ff3 com.apple.PerformanceAnalysis (1.148.3 – 148.3) <DE16079A-5267-372A-9435-E993EB41252A> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fffa8074000 – 0x7fffa80aeffb com.apple.ProtectedCloudStorage (1.0 – 1) <FD1F4A30-A8A4-3570-98E0-347117CE99A7> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fffa80af000 – 0x7fffa80c9fff com.apple.ProtocolBuffer (1 – 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fffa80ca000 – 0x7fffa80d9ff7 com.apple.QuickLookThumbnailing (1.0 – 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fffa80e2000 – 0x7fffa8105ff3 com.apple.RemoteViewServices (2.0 – 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fffa8dcf000 – 0x7fffa8dd2fff com.apple.SecCodeWrapper (4.0 – 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fffa8e61000 – 0x7fffa8eeefff com.apple.Sharing (696.2.67.1 – 696.2.67.1) <267A3C7C-BB70-3E92-B773-A3F9EDD12E84> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffa8f0f000 – 0x7fffa9175ff3 com.apple.SkyLight (1.600.0 – 170.3.11.11) <0F7F9F9B-90E2-3FE4-9A39-DE7EC10DAF79> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fffa9355000 – 0x7fffa9361ff7 com.apple.SpeechRecognitionCore (3.3.2 – 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fffa9a4d000 – 0x7fffa9ac1fdf com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fffa9ce1000 – 0x7fffa9d0dff3 com.apple.framework.SystemAdministration (1.0 – 1.0) <CD5B74B1-01ED-369E-AB11-1DA59F2C2A24> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fffa9f00000 – 0x7fffa9f06ff7 com.apple.TCC (1.0 – 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fffa9f92000 – 0x7fffaa058ff7 com.apple.TextureIO (2.8 – 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fffaa0cc000 – 0x7fffaa0cdfff com.apple.TrustEvaluationAgent (2.0 – 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fffaa0ce000 – 0x7fffaa25fff3 com.apple.UIFoundation (1.0 – 490.8) <0342C3E6-AB89-3F0D-A9CE-5F2CD3587B75> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fffaad2e000 – 0x7fffaadeefff com.apple.ViewBridge (283 – 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fffab239000 – 0x7fffab23ffff com.apple.XPCService (2.0 – 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fffab310000 – 0x7fffab312ffb com.apple.loginsupport (1.0 – 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fffab367000 – 0x7fffab382ff7 libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
0x7fffab383000 – 0x7fffab38efff libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
0x7fffab38f000 – 0x7fffab41fff7 libCoreStorage.dylib (540.30.1) <85C0A366-F901-36E3-854A-FE8A14A04A72> /usr/lib/libCoreStorage.dylib
0x7fffab420000 – 0x7fffab421ff3 libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fffab422000 – 0x7fffab635fff libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
0x7fffab651000 – 0x7fffab658fff libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
0x7fffab659000 – 0x7fffab659fff libOpenScriptingUtil.dylib (172.1) <0F1BA407-97D1-36F6-882D-A355EAAD5E00> /usr/lib/libOpenScriptingUtil.dylib
0x7fffab65a000 – 0x7fffab65effb libScreenReader.dylib (477.40.7) <F7305560-6CF0-3000-8301-72E04BEAA693> /usr/lib/libScreenReader.dylib
0x7fffab65f000 – 0x7fffab660ffb libSystem.B.dylib (1238.60.2) <58358A17-4318-3AD9-B18E-CC36502B9127> /usr/lib/libSystem.B.dylib
0x7fffab6cc000 – 0x7fffab6f7ff3 libarchive.2.dylib (41.70.2) <907D1FB1-9A65-33F5-AFC8-0B6E5AE9D83A> /usr/lib/libarchive.2.dylib
0x7fffab6f8000 – 0x7fffab774fc7 libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
0x7fffab778000 – 0x7fffab778ff3 libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
0x7fffab779000 – 0x7fffab789ff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fffab78a000 – 0x7fffab798ff7 libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
0x7fffab799000 – 0x7fffab7efff7 libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
0x7fffab7f0000 – 0x7fffab819ff7 libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
0x7fffab81a000 – 0x7fffab82affb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fffab82b000 – 0x7fffab841fcf libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
0x7fffab842000 – 0x7fffab842ff7 libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
0x7fffab843000 – 0x7fffab844ff3 libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
0x7fffab8fe000 – 0x7fffab9e2ff7 libcrypto.0.9.8.dylib (64.50.7) <B34BC0FA-18ED-37C5-9D46-393803CADEBB> /usr/lib/libcrypto.0.9.8.dylib
0x7fffab9e3000 – 0x7fffabb73ff7 libcrypto.35.dylib (11.50.4) <11578EE7-5538-3543-AAE5-A9B3E91536B2> /usr/lib/libcrypto.35.dylib
0x7fffabb74000 – 0x7fffabb7ffff libcsfde.dylib (540.30.1) <0C2B183B-16D9-3D5F-962D-0A09C7063211> /usr/lib/libcsfde.dylib
0x7fffabb80000 – 0x7fffabbd3ff7 libcups.2.dylib (450.4) <2DA65D4A-1428-3F74-869A-E16246DE88C7> /usr/lib/libcups.2.dylib
0x7fffabbd4000 – 0x7fffabc26fff libcurl.4.dylib (95.70.5) <ED932C5D-6FA2-364A-B562-3F67D1B40C71> /usr/lib/libcurl.4.dylib
0x7fffabc27000 – 0x7fffabc2eff3 libdscsym.dylib (148.3) <1FF45ED3-4518-3431-BD66-88461B3395AC> /usr/lib/libdscsym.dylib
0x7fffabc50000 – 0x7fffabc50fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
0x7fffabc5e000 – 0x7fffabc5ffff libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
0x7fffabc60000 – 0x7fffabc65ff7 libheimdal-asn1.dylib (498.50.12) <1AC5AB99-2E62-3B9C-ADE4-AE65CFCDA471> /usr/lib/libheimdal-asn1.dylib
0x7fffabc66000 – 0x7fffabd58ff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fffabd59000 – 0x7fffabf7effb libicucore.A.dylib (57168.0.1) <99D53A36-19F6-34F0-86AB-D8BD6C9BD3AD> /usr/lib/libicucore.A.dylib
0x7fffabf84000 – 0x7fffabf85fff liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
0x7fffabf86000 – 0x7fffabf9fffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fffabfa0000 – 0x7fffabfb6ff7 libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
0x7fffabfb7000 – 0x7fffac25fff7 libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
0x7fffac292000 – 0x7fffac30cff3 libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
0x7fffac30d000 – 0x7fffac6df047 libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
0x7fffac6e0000 – 0x7fffac6e1fff libodfde.dylib (23.50.1) <744F1E66-11EB-3A4D-8944-722F39C55278> /usr/lib/libodfde.dylib
0x7fffac6e2000 – 0x7fffac6e6fff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
0x7fffac6e7000 – 0x7fffac718fff libpcap.A.dylib (67.60.2) <B2D36AD8-D5C8-3875-AC81-4787A15E44C2> /usr/lib/libpcap.A.dylib
0x7fffac735000 – 0x7fffac751ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
0x7fffac752000 – 0x7fffac78bfff libsandbox.1.dylib (592.70.2) <9017CBC7-DC59-3668-8E86-738D141AF11C> /usr/lib/libsandbox.1.dylib
0x7fffac78c000 – 0x7fffac79effb libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
0x7fffac79f000 – 0x7fffac7a0ff3 libspindump.dylib (231.3) <1A34FC5F-2E60-3C81-9F4A-C1FF0FE39FE1> /usr/lib/libspindump.dylib
0x7fffac7a1000 – 0x7fffac8efff7 libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
0x7fffac94b000 – 0x7fffac99effb libssl.35.dylib (11.50.4) <81C74F15-DE70-3B59-BB9D-9224646B49CC> /usr/lib/libssl.35.dylib
0x7fffac99f000 – 0x7fffac9effff libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
0x7fffaca34000 – 0x7fffaca37ff7 libutil.dylib (47.30.1) <88CC63B3-0EDF-306E-9AB5-D87EBE0F3F16> /usr/lib/libutil.dylib
0x7fffaca38000 – 0x7fffaca45ff7 libxar.1.dylib (417.1) <78B14DC5-5256-3820-8259-117C5046BB9F> /usr/lib/libxar.1.dylib
0x7fffaca46000 – 0x7fffacb35ff3 libxml2.2.dylib (30.24) <D84C6B99-6D4C-3651-8086-387D631CBA37> /usr/lib/libxml2.2.dylib
0x7fffacb36000 – 0x7fffacb5ffff libxslt.1.dylib (15.9.3) <F57ED43F-7912-3C99-8500-AB0EEE9FA178> /usr/lib/libxslt.1.dylib
0x7fffacb60000 – 0x7fffacb71ff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fffacb80000 – 0x7fffacb84ff7 libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
0x7fffacb85000 – 0x7fffacb8ffff libcommonCrypto.dylib (60092.50.5) <4C8A7FE1-C190-3015-A744-66F8220EAF6A> /usr/lib/system/libcommonCrypto.dylib
0x7fffacb90000 – 0x7fffacb97fff libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
0x7fffacb98000 – 0x7fffacba0fff libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
0x7fffacba1000 – 0x7fffacc24fdb libcorecrypto.dylib (442.50.22) <E36CE660-855A-3166-8B9C-645C514B2C52> /usr/lib/system/libcorecrypto.dylib
0x7fffacc25000 – 0x7fffacc56fff libdispatch.dylib (703.50.38) <54B02414-5908-3EF0-B4D2-230B7FEB1CF7> /usr/lib/system/libdispatch.dylib
0x7fffacc57000 – 0x7fffacc5cffb libdyld.dylib (434) <4A0E66C1-4596-38E6-898E-BD2660478D3D> /usr/lib/system/libdyld.dylib
0x7fffacc5d000 – 0x7fffacc5dffb libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
0x7fffacc5e000 – 0x7fffacc6afff libkxld.dylib (3789.73.50) <E2CCB6DE-F92B-33CE-81A8-DDC42E62B62D> /usr/lib/system/libkxld.dylib
0x7fffacc6b000 – 0x7fffacc6bfff liblaunch.dylib (972.70.5) <1F770D9B-3892-3BBB-9471-68DDDDB0F69A> /usr/lib/system/liblaunch.dylib
0x7fffacc6c000 – 0x7fffacc71ff3 libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
0x7fffacc72000 – 0x7fffacc74ff3 libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
0x7fffacc75000 – 0x7fffacc76ffb libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
0x7fffacc77000 – 0x7fffacc8fff7 libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
0x7fffacc90000 – 0x7fffacc90ff7 libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
0x7fffacc91000 – 0x7fffacd1efef libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
0x7fffacd1f000 – 0x7fffacd22ffb libsystem_configuration.dylib (888.60.3) <094DBBF4-276A-3A11-8AF3-72743CC338E6> /usr/lib/system/libsystem_configuration.dylib
0x7fffacd23000 – 0x7fffacd26fff libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
0x7fffacd27000 – 0x7fffacd3ffff libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
0x7fffacd40000 – 0x7fffacd46fff libsystem_dnssd.dylib (765.50.11) <B87F96B8-2694-3DB3-9923-1B4E2245C8BF> /usr/lib/system/libsystem_dnssd.dylib
0x7fffacd47000 – 0x7fffacd70ff7 libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
0x7fffacd71000 – 0x7fffacd93ff7 libsystem_kernel.dylib (3789.73.50) <932ACBB6-9962-3839-AEE3-D8AA6BF1DD02> /usr/lib/system/libsystem_kernel.dylib
0x7fffacd94000 – 0x7fffacddbfe7 libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
0x7fffacddc000 – 0x7fffacdfaff7 libsystem_malloc.dylib (116.50.9) <82647590-DAEF-3499-8BF3-F1E3048861FE> /usr/lib/system/libsystem_malloc.dylib
0x7fffacdfb000 – 0x7ffface54ffb libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
0x7ffface55000 – 0x7ffface5eff3 libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
0x7ffface5f000 – 0x7ffface68ff3 libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
0x7ffface69000 – 0x7ffface71fe7 libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
0x7ffface72000 – 0x7ffface7cff7 libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
0x7ffface7d000 – 0x7ffface80ff7 libsystem_sandbox.dylib (592.70.2) <19320A42-2E3B-361B-BBDA-2F5F2E87B100> /usr/lib/system/libsystem_sandbox.dylib
0x7ffface81000 – 0x7ffface82ff3 libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
0x7ffface83000 – 0x7ffface8affb libsystem_symptoms.dylib (532.50.48) <1C822669-BF39-3639-A00B-B9170A63F342> /usr/lib/system/libsystem_symptoms.dylib
0x7ffface8b000 – 0x7ffface9eff7 libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
0x7ffface9f000 – 0x7fffacea4ffb libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
0x7fffacea5000 – 0x7fffaceceff7 libxpc.dylib (972.70.5) <255AA6A1-26AA-33F6-BC11-3DCE12A0BC0F> /usr/lib/system/libxpc.dylibExternal Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 5272
thread_create: 0
thread_set_state: 0VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=2.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.8G(100%)VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 512K 5
Activity Tracing 256K 2
CG backing stores 2992K 5
CG image 1432K 47
CoreAnimation 404K 30
CoreUI image data 3712K 28
CoreUI image file 184K 5
Foundation 24K 3
Image IO 99.0M 119
JS JIT generated code 128.0M 5
JS JIT generated code (reserved) 896.0M 2 reserved VM address space (unallocated)
Kernel Alloc Once 8K 2
MALLOC 1.4G 266
MALLOC guard page 48K 10
MALLOC_LARGE (reserved) 50.6M 3 reserved VM address space (unallocated)
Memory Tag 242 12K 2
OpenGL GLSL 256K 4
SQLite page cache 64K 2
STACK GUARD 408K 103
Stack 115.6M 141
VM_ALLOCATE 6508K 41
WebKit Malloc 18.0M 39
__DATA 139.8M 396
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 133.0M 66
__POVERDDATA 16K 2
__POVERTEXT 16K 2
__TEXT 893.6M 354
__UNICODE 556K 2
mapped file 103.3M 36
shared memory 16.4M 18
TOTAL 4.0G 1712
TOTAL, minus reserved VM space 3.1G 1712Model: iMac17,1, BootROM 170.0.0.0.0, 4 processors, Intel Core i7, 4 GHz, 32 GB, SMC 2.34f2
Graphics: AMD Radeon R9 M395, AMD Radeon R9 M395, PCIe, 2048 MB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1867 MHz, 0x00, –
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1867 MHz, 0x00, –
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1867 MHz, 0x00, –
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1867 MHz, 0x00, –
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x14A), Broadcom BCM43xx 1.0 (7.21.171.134.1a2)
Bluetooth: Version 5.0.5f7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@10,0,0
PCI Card: UAD-2 Satellite Thunderbolt – OCTO, Other Multimedia, Thunderbolt@193,0,0
PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@13,0,0
PCI Card: Universal Audio Apollo Twin – DUO, Other Multimedia, Thunderbolt@198,0,0
Serial ATA Device: APPLE SSD SM0512G, 500.28 GB
Serial ATA Device: Glyph StudioRAID TB2-0, 4 TB
Serial ATA Device: Glyph StudioRAID TB2-0, 2 TB
USB Device: USB 3.0 Bus
USB Device: USB3.0 Hub
USB Device: MCT USB3.0 External Graphics Device
USB Device: My Passport 25E1
USB Device: My Passport 25E3
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: USB2.0 Hub
USB Device: eLicenser
USB Device: BCF2000
USB Device: USB Multimedia Keyboard
USB Device: nanoKONTROL2
USB Device: MPK Mini Mk II
USB Device: FaderPort
USB Device: USB Receiver
USB Device: DL1016
USB Device: BCR2000
USB Device: Console 1
USB Device: mio
USB Device: Microsoft® Nano Transceiver v2.0
USB Device: USB Flash Drive
USB Device: QuNexus
Thunderbolt Bus: iMac, Apple Inc., 28.1
Thunderbolt Device: UAD-2 Satellite, Universal Audio, Inc., 1, 25.1
Thunderbolt Device: StudioRAID TB2, Glyph, 3, 25.1 -
November 23, 2021 at 10:26 pm #160845
==== BEGIN PLUGIN SUPPORT DATA ====
“PluginInfoComponentVersion”: “1.0.0”,
“System”: {
“JUCEVersion”: “JUCE v6.0.7”,
“OperatingSystemName”: “Mac OSX 10.12.6”,
“OperatingSystem64Bit”: true,
“ComputerName”: “Roberts-iMac”,
“UserLanguage”: “en”,
“UserRegion”: “US”,
“DisplayLanguage”: “en-US”,
“DeviceDescription”: “iMac17,1”,
“DeviceManufacturer”: “Apple”,
“DeviceIdentifiers”: [
“c655c”
“NumCpus”: 8,
“NumPhysicalCpus”: 4,
“CpuSpeedInMegahertz”: 4000,
“CpuVendor”: “GenuineIntel”,
“CpuModel”: “Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz”,
“MMX”: true,
“3DNow”: false,
“SSE”: true,
“SSE2”: true,
“SSE3”: true,
“SSSE3”: true,
“SSE41”: true,
“SSE42”: true,
“AVX”: true,
“AVX2”: true,
“AVX512F”: false,
“AVX512BW”: false,
“AVX512CD”: false,
“AVX512DQ”: false,
“AVX512ER”: false,
“AVX512IFMA”: false,
“AVX512PF”: false,
“AVX512VBMI”: false,
“AVX512VL”: false,
“AVX512VPOPCNTDQ”: false,
“Neon”: false,
“MemorySizeInMegabytes”: 32768,
“PageSize”: 4096,
“RunningInAppExtensionSandbox”: false
“HostSettings”: {
“Host”: “Steinberg Cubase 10.5”,
“Format”: “VST3”
“PluginEnvironment”: {
“PluginName”: “SplitEQ”,
“PluginVersion”: “1.0.4”,
“PluginArchitecture”: “Intel”,
“PluginSupportInformationVersion”: “0.1.0”,
“SampleRate”: 48000.0,
“BlockSize”: 384,
“TotalInputChannels”: 2,
“TotalOutputChannels”: 2,
“MainBusInputChannels”: 2,
“MainBusOutputChannels”: 2,
“DoublePrecision”: false,
“LatencySamples”: 3592,
“NonRealTime”: false
“STATE”: {
“plugId”: 1399866705,
“plugVer”: “1.0.4”,
“PARAMETERS”: {
“PARAM”: {
“id”: “prc1”,
“value”: “0.0”
“PARAM_1”: {
“id”: “trf1”,
“value”: “10.10000038146973”
“PARAM_2”: {
“id”: “tof1”,
“PARAM_3”: {
“id”: “tos1”,
“value”: “1.0”
“PARAM_4”: {
“id”: “trq1”,
“value”: “1.0”
“PARAM_5”: {
“id”: “toq1”,
“value”: “1.0”
“PARAM_6”: {
“id”: “trp1”,
“value”: “0.0”
“PARAM_7”: {
“id”: “trw1”,
“value”: 0.0
“PARAM_8”: {
“id”: “top1”,
“value”: “0.0”
“PARAM_9”: {
“id”: “tow1”,
“value”: 0.0
“PARAM_10”: {
“id”: “mss1”,
“value”: “0.0”
“PARAM_11”: {
“id”: “slb1”,
“value”: “0.0”
“PARAM_12”: {
“id”: “prc2”,
“value”: “1.0”
“PARAM_13”: {
“id”: “typ2”,
“value”: “0.0”
“PARAM_14”: {
“id”: “tof2”,
“value”: “100.0”
“PARAM_15”: {
“id”: “trb2”,
“value”: “0.0”
“PARAM_16”: {
“id”: “tob2”,
“value”: “0.0”
“PARAM_17”: {
“id”: “srb2”,
“value”: “1.0”
“PARAM_18”: {
“id”: “tos2”,
“value”: “1.0”
“PARAM_19”: {
“id”: “trq2”,
“value”: “1.0”
“PARAM_20”: {
“id”: “toq2”,
“value”: “1.0”
“PARAM_21”: {
“id”: “trp2”,
“value”: “0.0”
“PARAM_22”: {
“id”: “trw2”,
“value”: 0.0
“PARAM_23”: {
“id”: “top2”,
“value”: “0.0”
“PARAM_24”: {
“id”: “tow2”,
“value”: 0.0
“PARAM_25”: {
“id”: “mss2”,
“value”: “0.0”
“PARAM_26”: {
“id”: “slb2”,
“value”: “0.0”
“PARAM_27”: {
“id”: “prc3”,
“value”: “1.0”
“PARAM_28”: {
“id”: “typ3”,
“value”: “1.0”
“PARAM_29”: {
“id”: “tof3”,
“value”: “400.0000305175781”
“PARAM_30”: {
“id”: “trb3”,
“value”: “0.0”
“PARAM_31”: {
“id”: “tob3”,
“value”: “0.0”
“PARAM_32”: {
“id”: “srb3”,
“value”: “1.0”
“PARAM_33”: {
“id”: “tos3”,
“value”: “1.0”
“PARAM_34”: {
“id”: “trq3”,
“value”: “1.0”
“PARAM_35”: {
“id”: “toq3”,
“value”: “1.0”
“PARAM_36”: {
“id”: “trp3”,
“value”: “0.0”
“PARAM_37”: {
“id”: “trw3”,
“value”: 0.0
“PARAM_38”: {
“id”: “top3”,
“value”: “0.0”
“PARAM_39”: {
“id”: “tow3”,
“value”: 0.0
“PARAM_40”: {
“id”: “mss3”,
“value”: “0.0”
“PARAM_41”: {
“id”: “slb3”,
“value”: “0.0”
“PARAM_42”: {
“id”: “prc4”,
“value”: “1.0”
“PARAM_43”: {
“id”: “typ4”,
“value”: “1.0”
“PARAM_44”: {
“id”: “tof4”,
“value”: “800.0000610351562”
“PARAM_45”: {
“id”: “trb4”,
“value”: “0.0”
“PARAM_46”: {
“id”: “tob4”,
“value”: “0.0”
“PARAM_47”: {
“id”: “srb4”,
“value”: “1.0”
“PARAM_48”: {
“id”: “tos4”,
“value”: “1.0”
“PARAM_49”: {
“id”: “trq4”,
“value”: “1.0”
“PARAM_50”: {
“id”: “toq4”,
“value”: “1.0”
“PARAM_51”: {
“id”: “trp4”,
“value”: “0.0”
“PARAM_52”: {
“id”: “trw4”,
“value”: 0.0
“PARAM_53”: {
“id”: “top4”,
“value”: “0.0”
“PARAM_54”: {
“id”: “tow4”,
“value”: 0.0
“PARAM_55”: {
“id”: “mss4”,
“value”: “0.0”
“PARAM_56”: {
“id”: “slb4”,
“value”: “0.0”
“PARAM_57”: {
“id”: “prc5”,
“value”: “1.0”
“PARAM_58”: {
“id”: “typ5”,
“value”: “1.0”
“PARAM_59”: {
“id”: “tof5”,
“value”: “1599.999877929688”
“PARAM_60”: {
“id”: “trb5”,
“value”: “0.0”
“PARAM_61”: {
“id”: “tob5”,
“value”: “0.0”
“PARAM_62”: {
“id”: “srb5”,
“value”: “1.0”
“PARAM_63”: {
“id”: “tos5”,
“value”: “1.0”
“PARAM_64”: {
“id”: “trq5”,
“value”: “1.0”
“PARAM_65”: {
“id”: “toq5”,
“value”: “1.0”
“PARAM_66”: {
“id”: “trp5”,
“value”: “0.0”
“PARAM_67”: {
“id”: “trw5”,
“value”: 0.0
“PARAM_68”: {
“id”: “top5”,
“value”: “0.0”
“PARAM_69”: {
“id”: “tow5”,
“value”: 0.0
“PARAM_70”: {
“id”: “mss5”,
“value”: “0.0”
“PARAM_71”: {
“id”: “slb5”,
“value”: “0.0”
“PARAM_72”: {
“id”: “prc6”,
“value”: “1.0”
“PARAM_73”: {
“id”: “typ6”,
“value”: “1.0”
“PARAM_74”: {
“id”: “tof6”,
“value”: “3200.00048828125”
“PARAM_75”: {
“id”: “trb6”,
“value”: “0.0”
“PARAM_76”: {
“id”: “tob6”,
“value”: “0.0”
“PARAM_77”: {
“id”: “srb6”,
“value”: “1.0”
“PARAM_78”: {
“id”: “tos6”,
“value”: “1.0”
“PARAM_79”: {
“id”: “trq6”,
“value”: “1.0”
“PARAM_80”: {
“id”: “toq6”,
“value”: “1.0”
“PARAM_81”: {
“id”: “trp6”,
“value”: “0.0”
“PARAM_82”: {
“id”: “trw6”,
“value”: 0.0
“PARAM_83”: {
“id”: “top6”,
“value”: “0.0”
“PARAM_84”: {
“id”: “tow6”,
“value”: 0.0
“PARAM_85”: {
“id”: “mss6”,
“value”: “0.0”
“PARAM_86”: {
“id”: “slb6”,
“value”: “0.0”
“PARAM_87”: {
“id”: “prc7”,
“value”: “1.0”
“PARAM_88”: {
“id”: “typ7”,
“value”: “3.0”
“PARAM_89”: {
“id”: “tof7”,
“value”: “10000.001953125”
“PARAM_90”: {
“id”: “trb7”,
“value”: “0.0”
“PARAM_91”: {
“id”: “tob7”,
“value”: “0.0”
“PARAM_92”: {
“id”: “srb7”,
“value”: “1.0”
“PARAM_93”: {
“id”: “tos7”,
“value”: “1.0”
“PARAM_94”: {
“id”: “trq7”,
“value”: “1.0”
“PARAM_95”: {
“id”: “toq7”,
“value”: “1.0”
“PARAM_96”: {
“id”: “trp7”,
“value”: “0.0”
“PARAM_97”: {
“id”: “trw7”,
“value”: 0.0
“PARAM_98”: {
“id”: “top7”,
“value”: “0.0”
“PARAM_99”: {
“id”: “tow7”,
“value”: 0.0
“PARAM_100”: {
“id”: “mss7”,
“value”: “0.0”
“PARAM_101”: {
“id”: “slb7”,
“value”: “0.0”
“PARAM_102”: {
“id”: “prc8”,
“value”: “0.0”
“PARAM_103”: {
“id”: “trf8”,
“value”: “20000.0”
“PARAM_104”: {
“id”: “tof8”,
“value”: “20000.0”
“PARAM_105”: {
“id”: “tos8”,
“value”: “1.0”
“PARAM_106”: {
“id”: “trq8”,
“value”: “1.0”
“PARAM_107”: {
“id”: “toq8”,
“value”: “1.0”
“PARAM_108”: {
“id”: “trp8”,
“value”: “0.0”
“PARAM_109”: {
“id”: “trw8”,
“value”: 0.0
“PARAM_110”: {
“id”: “top8”,
“value”: “0.0”
“PARAM_111”: {
“id”: “tow8”,
“value”: 0.0
“PARAM_112”: {
“id”: “mss8”,
“value”: “0.0”
“PARAM_113”: {
“id”: “slb8”,
“value”: “0.0”
“PARAM_114”: {
“id”: “styp”,
“value”: “0.0”
“PARAM_115”: {
“id”: “trsp”,
“value”: “0.5”
“PARAM_116”: {
“id”: “trdc”,
“value”: “0.300000011920929”
“PARAM_117”: {
“id”: “smoo”,
“value”: “0.01999999955296516”
“PARAM_118”: {
“id”: “rLev”,
“value”: “0.0”
“PARAM_119”: {
“id”: “rSol”,
“value”: “0.0”
“PARAM_120”: {
“id”: “oLev”,
“value”: “0.0”
“PARAM_121”: {
“id”: “oSol”,
“value”: “0.0”
“PARAM_122”: {
“id”: “phsi”,
“value”: 0.0
“PARAM_123”: {
“id”: “rpan”,
“value”: 0.0
“PARAM_124”: {
“id”: “rwdt”,
“value”: 0.0
“PARAM_125”: {
“id”: “opan”,
“value”: 0.0
“PARAM_126”: {
“id”: “owdt”,
“value”: 0.0
“PARAM_127”: {
“id”: “gbmd”,
“value”: 0.0
“PARAM_128”: {
“id”: “rgsc”,
“value”: “1.0”
“PARAM_129”: {
“id”: “ogsc”,
“value”: “1.0”
“PARAM_130”: {
“id”: “bypi”,
“value”: “0.0”
“PARAM_131”: {
“id”: “bype”,
“value”: 0.0
“DATAPARAMS”: {
“PROPERTY”: {
“name”: “prSl”,
“value”: “Default.tidex 1”,
“persist”: 2,
“undoable”: false
“PROPERTY_1”: {
“name”: “abSl”,
“value”: 0,
“persist”: 0,
“undoable”: false
“PROPERTY_2”: {
“name”: “anSt”,
“value”: “0 0 1 2 2 1 0 1 1 0”,
“persist”: 2,
“undoable”: true
“PROPERTY_3”: {
“name”: “azeb”,
“value”: true,
“persist”: 0,
“undoable”: false
“PROPERTY_4”: {
“name”: “eqMn”,
“value”: false,
“persist”: 0,
“undoable”: false
“PROPERTY_5”: {
“name”: “zLvl”,
“value”: “-12 12”,
“persist”: 2,
“undoable”: false
“PROPERTY_6”: {
“name”: “epTb”,
“value”: 0,
“persist”: 2,
“undoable”: false
==== END PLUGIN SUPPORT DATA ==== -
November 24, 2021 at 12:38 pm #160856
Hey Rob, based on your crash report this is indeed the same crash. We were able to (finally!) reproduce in-house, and have a fix. If you email support@eventide.com referencing this post we can send you a test build to try out.
November 25, 2021 at 1:44 am #160862
Thanks for your response! Glad to be of help. I’ll send support an email. Dig the plugin!
Regards,
Rob
