spring reverb in h9k?
Home Forums Products Rackmount spring reverb in h9k?
    • #159191
      taylor12k
        i really like eventide’s Spring plug in…… is this possible to code/port to the h9000?
      • #159193
          The H9000 features an exact port of the H9 Spring algorithm. The Spring plug-in is also a port of the H9 algorithm, but we added a selectable tank size and pre/post option for the tremolo circuit that is only featured in the plug-in version. We’d like to add the plug-in version of Spring to the H9000 at some point but there is no set date for this.
          Besides those differences, you should be able to get the same sounds using the H9000 as the plug-in when using the small tank and post reverb tremolo settings.
        • #159204
          taylor12k
            oh wow, great! posted this question out of the studio.. should have waited and did a search of the algorithms first.. but thank you for pointing it out. i do like the tank size on the plug as well as the direct spring interaction…. hope it makes it to the h9k someday!
