SPX-90 “Symphonic”
Home Forums Products Stompboxes SPX-90 “Symphonic”
Viewing 3 reply threads
    • #115250
      pv_fan
      I was checking the board to see if anyone has come up a patch for the Modfactor or Pitchfactor that replicates the Symphonic patch from the old Yamaha SPX-90? I’m looking to recreate the sounds of Zack Wylde back in his early Ozzy days. I know it won’t be exact but at least somewhere in the ballpark would be great. Thanks.
    • #151591
      Quick question:  Is that what you have:  ModFactor, PitchFactor, hopefully both?
      I’ll bet you’ll get closer using two devices, for that 2-delays-per-side thickness.  If you have an H9, the PitchFuzz algorithm (without the fuzz) gets large, with 3 detunings and two delays.  In the meantime, I’ll see what I can do here.  I have 3 loaded H9s, plus another PF for good measure.
    • #151603
      In Tom’s mind, he wrote:
      I’m not overjoyed with these quick, single-preset attempts, but it’s a start.  Most say it’s a chorus; some call it a flanger [almost the same thing; shorter delay time].  I’ve seen it’s a tri-chorus, with a complex waveform.  I’ve also read it’s 2 delays per stereo side.  By ear, I do hear the zero-thru crossings that come from two delays; either one static, or two sweeps crossing each other.  Hard to tell with all that Wylde distortion going on.
      So I winged it.  For the CHORUS, I wanted FEEDBACK control [TYPE – SHIMMER].  You’re going to want to fine tune FEEDBACK & INTENSITY for best results (represented by the expression pedal programming here).  Too much gives the CHORUS a reverberant trail.  Too little, and you’re going to lose that characteristic sweep.
      Here’s a FLANGER variation.  Almost the same setup; less INTENSITY.  Same lopsided modulation from combining a TRIANGLE SHAPE / MOD SOURCE.  Keep the DELAY OFFSET high. It definitely sounds more FLANGER than Symphonic, but you do get that 2-delay combo effect.  To the extreme, if desired.  TYPE – JET also works well, but it thins out the distorted input a bit too much (being “intensely negative”).
    • #151610
      pv_fan
      Thanks to both of you for your replies. I’m going to give your presets a try, I’m sure they will sound great.
