Home › Forums › Products › Stompboxes › Stereo and Mixing Link ?
October 3, 2014 at 8:36 am #111985
Hello mister Eventide. Thank you so much for your Mixing
Link. It’s perfect to use a H9 with my saxophone.It works great but I’d like to know if you think about a stereo version ?
If not what could be the solution to create my own stereo system
with a Mixing link ?I want to send a mono signal to the H9 and to come out with
a stereo signal in order to use the great H9’s stereo effets.I think to add another mono DI box (radial proDI) to the
Mixing Link’s DI out.Microphone (mono) => MXLK (mono) => H9 (stereo)
=> volume pedal (stereo)=> OUT 1 => MXLK DI out => PA (IN 1)
=> OUT 2 => DI box => PA (IN 2)
Do you think it could work ? Do you see another
solution ? Has somebody already try this ?Thank you for your help.
Normal
021
false
false
falseFR
JA
X-NONES.G.
October 3, 2014 at 1:49 pm #126801
Hi S.G.
This is a good idea! Users have been asking for a MXLNK II that would account for a stereo return and a stereo DI. There are a few other features we would also like to incorporate in a ml II.
The setup you propose with the additional DI should work fine.
thanks.
j waltz
eventide
October 3, 2014 at 9:12 pm #126805
It's a very good news this MXLNK II's project.
I'd like to suggest an idea : could you put a knob to adjust separately instrument and microphone's Input Gain ? Or something to change the balance between that two Input…
But maybe you have already thought about it 😉
Thanks
S.G.
July 1, 2021 at 4:53 pm #158183
I’m very interesting in Mixing Link 2 as well.
It would be great to have stereo fx return and stereo outs as well as a “mute” button(s) to mute the mic/instrument input.
August 14, 2021 at 10:02 pm #158402
7 years after my first message, I’ve found the solution, a stereo preamp with 2 Inputs, stereo fx loop and output.
It’s the Zorg Blow!Blow!Blow! : https://www.zorgeffects.com/index.php/en/bbb-eng-detail
Eventide what about your Stereo Mixing Link v2 ?
