Home › Forums › Products › Stompboxes › Stereo Delay Recommendation for H90
- This topic has 5 replies, 3 voices, and was last updated 2 years ago by Fox Uncle.
December 9, 2022 at 12:47 am #167522Fox UncleParticipant
Hello Eventide Community, I would like to narrow down H90 delay programs or algorithms that will allow me to precisely delay the signal being output to the left and right channel. That is to say, I would like to nudge the left channel just enough so that the delay gives me a wide sounding spread between two amplifiers. Any recommendations or suggestions would be much appreciated. Thank you!
December 9, 2022 at 12:57 am #167523
Digital Delay would work for this, just make sure the A/B mix is set in the middle so Delay A goes to Left channel and Delay B goes to Right channel. Also, make sure you do not have Tempo Sync activated, so you can achieve milliseconds of delay. Mod Delay is another algorithm that would work keeping the same principles in mind. But the best algorithm we make for width generation is the iconic MicroPitch algorithm. Not only can you adjust a stereo delay but you can also adjust pitch in cent increments. Together, pitch and delay variations will give you the widest image possible. Similarly, the H910/H949 algorithm is also capable of this.
December 30, 2022 at 8:14 am #168055Fox UncleParticipant
This reply was much appreciated and part of why Eventide has such a great community behind its designs. What would be the reverb equivalent of this delay algorithm/program, allowing for similar width generation and control between two amps?
December 30, 2022 at 8:32 am #168056apalazzoloParticipant
Crystals (with the delay off)?
December 30, 2022 at 8:46 am #168058
DualVerb combines two different high quality studio reverbs (A and B) with independent controls for decay, size, pre-delay, and EQ. Mix between both for rich, dense stereo reverberation, or use this effect to smoothly transition between two entirely different reverb sounds. It has a Reverb A/Reverb B Mix – [VRBMIX] : mixer for A and B reverbs, in stereo this mixes stereo channels, set at extreme results in dual mono reverbs (A on left, B on right).
But reverb is less directional than delay so width generation is achieved mainly with modulation. My favorite reverb for this is ModEchoVerb, though you don’t get individual channel control like you would with DualVerb. But it’s still sounds massive in stereo.
December 30, 2022 at 8:53 am #168059Fox UncleParticipant
Thanks so much, everyone!
