Home › Forums › Products › Stompboxes › Stompbox Live Use Tips?
December 4, 2009 at 1:50 am #106688
Craigy
MemberHey guys,
I've started using a Timefactor at gigs and just wondering if anyone has any good tips on the best way to use the TF (or the other stompboxes) when in a live situation.
I'm currently using it in bank mode but with the new release (50 banks) going back around to get to Patch 1:1 is a mission. Is a good approach to put all the patches you need in say the first 5 banks and lock the pedal down to only 5 banks before a gig?
I find it is quite easy to accidentally hit one of the knobs on the pedal, changing that patches settings. Is there a way to lock the patch when playing live? Is there an easy way to 'undo' the changes to a patch when this happens?
Anything else? Perhaps buying a footswitch to go through my banks is a good option?
Greatly appreciate any help,
Paul -
December 4, 2009 at 4:43 pm #119605
achaput
ModeratorHi Paul,
Craigy:
Yes, limiting the banks for live use is the recommended way to go. You could also use an Aux Switch to control Bank Down, which could make Presets easier to access.
Craigy:
There is a way to lock knob positions to prevent accidental changes. It's a System Menu item called "CATCHUP."
To activate CATCHUP, first enter System Mode by holding down both the Right Footswitch and the Encoder for a few seconds. Then Turn the Encoder knob clockwise until you see UTILITY. Press the Encoder Button to enter the UTILITY Menu and you will see CATCHUP.
Press the Encoder button to enter the CATCHUP menu and turn the Encoder knob from OFF to ON.
Exit System Mode by pressing and holding the Right Footswitch and Encoder knob again.
When CATCHUP is ON, a knob will not change your Preset setting until you turn it to the physical location of the saved setting.
December 18, 2009 at 5:34 am #119655
Craigy
MemberThats great, thanks for that Archaput, worked a treat!
December 18, 2009 at 5:36 am #119656
Craigy
MemberThats great! Thanks for that, worked a treat! Fantastic to have such dedicated staff on board here. Keep up the top work.
