storing H8000 settings in a host sequencer?
Home Forums Products Rackmount storing H8000 settings in a host sequencer?
    • #105613
      jwhiting
        Is there a technical limitation that prevents EControl from being released as VST?
        What motivates my question is that I often use the H8000 as an insert effect in VST chains. I usually save my h8000 settings to disk using VSIG, and then load them up in parallel with the track i'm working on. This gets tedious, as I often end up with multiple configurations per song.
        It would improve my workflow if I could load patches and parameter configurations via a VST insert, and have the patches/parameters saved right in the song as part of the VST state
        Instead I basically just keep a large list of vsig files like: "mysongname-mytracknumber-dspA.sig" that i load/manage in parallel with my host sequencer song.
      • #117444
         We will consider VST in time, J.
        Best
