Studio 1.2?
Home Forums Products Plug-Ins Studio 1.2?
Viewing 5 reply threads
    • #111698
      BruceDicks
      I am sorry, but I am not able to figure out how to get this into studio 1. Will someone help? Thank you so much.
    • #126113
      DGillespie
      Hi Bruce,
      You should just be able to install it and scan your vst plug-in folder.
      Dan
    • #126114
      DGillespie
      Are you seeing any errors?
    • #126139
      BruceDicks
      Thank you. I am not getting an error. I have it download, but just cannot figure out how to get it into Studio 1?
    • #126140
      BruceDicks
      It says that it is activated in Ilok, but in I am not able to located it. In my all programs there is an Utlra folder but there is nothing in it.
    • #136840
      DGillespie
      I don't understand what you mean by "In all my programs there is an UltraChannel folder, but there is nothing in it."
      Are you able to load the plug-in in a DAW besides Studio One?
      Also, are you on Mac or Windows?  If you're on Windows, when you run the plug-in installer it will ask you which directory you want to use to install your plug-in.  You need to choose the directory that you use for your other VST plug-ins, and install either the 64 or 32 bit plug-in depending on which you need for Studio One.
      Dan
