Switch presets via MIDI ?
Home Forums Products Stompboxes Switch presets via MIDI ?
  • This topic has 4 replies, 2 voices, and was last updated 2 weeks ago by joecozzi
Viewing 4 reply threads
    • #189176
      patric oconnor
        In program mode is it possible to switch between presets using MIDI CC ? I know incrementing up and down through presets is possible using midi cc but I want to be able to select a preset in program mode using midi in the same as I can using the foot switches. Thanks .. 🙏
      • #189177
        joecozzi
          No. The H90 will only change Programs with program changes (PC) no matter what mode you’re in. You can also use a MIDI controller to increment, decrement, increment+load, decrement+load, bank up, bank down, active or bypass. In the System Menu > MIDI > MIDI-Global Control, you can assign CC# to each of these functions.
        • #189178
          patric oconnor
            Thanks – figured out how to get it to work with PC commands from my midi foot switch…🙏
          • #189179
            patric oconnor
              btw: The PC commands for changing presets only work if I stay in Bank 1 and want to switch between presets.  There is no CC command for switching between presets – only CC commands for increment /decrement . Midi implementation in the H90 is useless for my requirements ..
            • #189180
              joecozzi
                Please excuse my lapse in terms as I confused Presets with Programs; my fault. You are correct, there is no way to switch PRESETS via MIDI. It is best practice to create Programs with different presets as these will change seamlessly with spillover. But the work has to be done in advance of using MIDI.
                On the other hand, it is possible to changes presets using the front panel controls in real time or with H90 Control on iPad or your computer.
