I’m looking for a higher quality power supply for the sometimes noisey H90. I’m curious if this will fix its USB woes.
If the noise happens only when you connect the USB cable, it’s most likely due to a ground loop issue in the studio. Making sure all devices share the same power outlet might help fix the problem.
I’ve been given that advice & it helps a bit but the H90 is still one of the noisiest (& most expensive) pieces of gear in the studio.
I don’t have the USB issue with any of my USB synths – Waldorf, Korg, Behringer, Arturia.. I’ve loads of USB devices even Boss USB fx pedals – are dead quiet.
My question still stands – I think these units need a better power supply.
