Home › Forums › Products › Stompboxes › Switching presets in play mode w/ aux switch
March 31, 2016 at 9:47 pm #113384knutfinMember
I recently bought a two-button aux switch to use with the Timefactor. I want to assign preset up/down while in play mode. However, I cant seem to figure it out. The closest I got was switching banks, but that only works in bank mode.
What do I do?
April 1, 2016 at 2:53 pm #143067
Because the TF is Bank-based, it does not have a next/last preset concept. It probably should.
It worked with a midi mouse, though. It did just that. It was just to big.
Isnt there a way to effortlessly switch between presets and have access to repeat and tap at the same time with an aux switch. -
April 1, 2016 at 8:52 pm #143074gkellumParticipantknutfin wrote:
It worked with a midi mouse, though. It did just that. It was just to big. Isnt there a way to effortlessly switch between presets and have access to repeat and tap at the same time with an aux switch.
Yes, that would work as you want via MIDI because the MIDI Mouse is sending out program changes which is in turn selecting individual presets. Unfortunately, there's no mechanism to do the same via an aux switch.
Ah, I see. Probably should have done better research I guess. Well, thanks!
