Home › Forums › Products › Stompboxes › Switching Time/Modfactor order in pedalboard?
September 30, 2008 at 2:21 pm #105852
discospring
MemberIs anyone using a signal switch pedal (or another method) to change the order of Timefactor & Modfactor on their pedalboard?
What's the best way to achieve this?
Both 'factors have 2 inputs and outputs so it should be possible to connect them in both orders with an A/B switch before them – but the dual in/outputs are for either mono or stereo signals. I'm confused about what sacrifices that would entail.
Can anyone explain, please?
October 17, 2008 at 6:15 pm #117957
discospring
MemberMy question was answered by helpful folk at http://www.tdpri.com/forum/stomp-box
The best solution seems to be the LoopMaster Effect Sequence Reverser, a switch-box with In, Out, and 2 Send/Receives. Hoping this will work. Here's a link:
November 8, 2008 at 4:28 pm #117999
alwalt
ParticipantI am using a 2 channel amp. So, I use a Boss Line Selector to switch between channels. In order to have the TF on both signal paths, I use both A and B inputs/outputs. By doing this, I loose the twin delay option, but I can handle each delay on a patch separatedly. For example, I can have A delay on 0 and B delay on 5. This would fit if have my A channel for rythm and B for lead, just stomp on the LSelector and the delay automatically goes on or off depending on which channel I use. You can mix two delay times on a patch also, having longer delays on one channel. Lots of uses this way, but requieres time to get it organized…
July 18, 2009 at 9:11 am #129927
oddb0d
MemberBoth the input and output are seperate if you have plugs in both jacks. I plan on doing this….
Loop 1 -> Pitchfactor L
Loop 8 -> PitchFactor R
In most cases they would mutually exclusive. I think that would give you a two position Mono Factor.
October 31, 2011 at 2:35 am #122775
zerenato
MemberThe solution for me is a boss line selector and a rocktron patchmate .Patchmate send 1 >boss A return ,boss send A>patchmate return1,patchmate send 8>boss B return,boss send B > patchmate return 8,boss output > in modfactor,out modfactor > boss input.The mode of line selector in A+B mix,use levels of the ls-2 to match the two signals, excuse me for tthe bad english.
