sync MIDI clock on H8000fw?
Home Forums Products Rackmount sync MIDI clock on H8000fw?
    • #105684
      Siem
        Here's a problem I've had for ages:
        I've got a H8000fw connected to a Mac and use Cubase 4. I'm unable to sync the tempo. I've enabled the MIDI clock in C4, I can see the busy light going on – indication MIDI signals – on the H8000fw when I do this.
        Then I go to the tempo in setup, and set the source ot Midiclock.
        Nothing happens, tempo will incate whatever I indicated before.
        I remember having troubles with it when I used a PC before, but somehow I got it working at one point.
      • #117569
        Hi Siem
        the presets showing T_Dly (delays) – T_Rate (LFOs) – T_Decay (Verbs) can be synced to MIDI Clock.
        These parameters need to be set to a rhythmic value (1/4 note, etc.) to be synced. If set to OFF, absolute time/speed values (milliseconds/Hz) will be used instead.
        Also make sure MIDI is enabled under SETUP > midi.
        best
