Syncing problems with TF and MF, Is This normal
Home Forums Products Stompboxes Syncing problems with TF and MF, Is This normal
Viewing 3 reply threads
    • #106670
      baidie
      First of all, these pedals are inspirationally awesome.Here's the problem. If I midi sync out from Timefactor to Modfactor, Tap Tempo via a boss FS-5U connected to timefactor which is set to quarter note triplets and modfactor is set to 4 bars on flanger, I get quarter note triplets with timefactor and quarter note modulation with modfactor. I change the value to 1 bar, 2 bar etc , but still quarter note modulations. So I midi sync out of the modfactor to timefactor and hook the fs-5u to modfactor, now I get my quarter note triplets with timefactor and modfactor 4 bar sweep.Yeah Baby cool. But is this normal? Due to the limited space on my pedal board and the location of the midi ports and the order I like my pedals it would be nice if I could midi out from timefactor to modfactor. I should mention that either way I had no bpm issues just tempo bars division on Modfactor. Thanks in Advance, You guys are doing a great job and these pedals are the creme of the Crop
    • #119554
      wedelich
      Hi baidie,
      Thanks for compliments.  Which software versions on Mod and Timefactor are you using?
    • #119561
      baidie
      Hi, Sorry I realized right after I posted that I didn't mention the software versions. Both the MF and the TF are updated successfully to version 2.4.1 [5] Beta.After updating I initialized them both and then customized my settings for midi sync,  pedal function and patch range, etc.
    • #130684
      wedelich
      You're right.  I reproduced this myself using the newest beta software.  We'll definitely look into it.  For now, as workaround, I would just use the Modfactor as a clock master.
