Synthonizer Alg help
Home Forums Products Stompboxes Synthonizer Alg help
Viewing 7 reply threads
    • #112149
      Boynigel
      does anyone have any setting suggestions or tricks to getting the Synthonizer algorithm to track better?  it tracks worse than an early 80's guitar synth.  my input level into the h9 is good fwiw.  my first real disappointment with my h9's.   i'm not even playing fast phrases.  as there a fix?
    • #127141
      mine tracks very well. Are you using low output pickups? I see a diference when I change guitars. My higher output pickups guitar behaves better.
    • #127142
      Boynigel
      my input levels are pretty much textbook meaning they're as hot as they can be without going into the red when viewed in H9 Control.  my compressor helps sightly, and i DO mean slightly.  it's too bad because all the other algs are stellar, but this one is a turd in my experience.
    • #127145
      wedelich
      Hi boynigel,
      The Synthonizer is very monophonic.  Are trying to play chords or letting other notes ring out (Like pulloffs then switching to another string without muting, etc) ?  If so, it might not track as well because it's looking for a single solid note.
    • #127171
      Boynigel
      i get that it's monophonic.  no chords.  i'm playing very slow, simple lines.  when i hit a single note that i simply want to sustain, it will glitch into an entirely different note within 3 seconds half the time.  the other half of the time i get lucky and it doesn't glitch.  i need predictability though.
    • #137804
      Imerkat
      use your neck pickup and roll of the tone knob
    • #137823
      wedelich
      boynigel:
      It sounds like your level just gets too low to track.  Try increasing the input level to your H9, you can do this in H9 Control or by pressing and holding the left footswtich while moving from Active to Bypass.  Alternatively, you can try boosting your signal before the H9, or using some compression before the H9.
      Also, imerkat had some good suggestions, neck pickup and tone roll off.  The neck pickup will give you a more sinusoidal like note, and the tone roll off will help with low-level interfering noise.
    • #137826
      KCStratman
      I'm not much of a pitch shift / harmonizer guy, never had a PitchFactor or more than a couple PF algos on my H9s. When I got Maxxed out, I had to try some of the heavier effects just for fun. I found that the Synthonizer, played into with clean tone, neck pickup tone rolled all the way down, and mild-medium compressor settings as suggested, tracked single notes quite well including slow bends and some faster bends. I was surprised to get good tracking of most bends and when an unmuted adjacent string is allowed to vibrate it loses tracking and causes a very interesting swallowed gargling sonic artifact which is an effect unto itself.
