System settings not saved
Home Forums Products Stompboxes System settings not saved
Viewing 3 reply threads
    • #108788
      ctc
      When I go into the system editor and change the RCV CH from 1 to 2, and press and hold the encoder and the right foot switch to leave system editor mode, then I turn the timefactor off and then back again it reverts to RCV CH 1. All other system settings that I change are also lost… Huh?
    • #123475
      Are you using the Eventide power supply ? If not, please do so. Otherwise, you should contact support@eventide.com
    • #123476
      ctc
      Yes, I use your wall wart.
      I think the problem is related to configuring the timefactor with both MIDI in and outs connected to MIDI enabled equipment and the USB connected to a computer. Once I unplugged the USB cable everything worked as expected. Thx.
    • #134572
      That surprises me – can't think what difference it would make. But, as long as you are up and running, all is good.
      Note that the TF will ignore the DIN5 MIDI if the USB is connected.
