T Factor & Spillover
Home Forums Products Stompboxes T Factor & Spillover
    • #106466
      oyarsa
      What is the difference between the "Spillover" function, which allows the tail of the effect to continue when changing presets,…..and "DSP+FX " bypass function, which seems to accomplish the same thing?
      When would you choose one method over the other?
    • #119122
      Mainly that "spillover" only applies when changing presets, and DSP+FX only applies when entering bypass.
      So, as you point out, they do similar things, but at different times.
