Tap switch not working H90
Home Forums Products Stompboxes Tap switch not working H90
    • #187189
      tonymaxmusic
        Hey Tony from brooklyn NY here. I’m sorry if this has been answered already but I just got my H90 and I’ve watched all the videos on using tap tempo with an external switch, I’ve gone to the calibration and it was successfully calibrated, it shows up in my I/O, I’ve got tempo set to Program, but I’m still not able to change the tempo on my presets in my List. Please help. I’m using a standard tap switch with a TRS cable.
      • #187197
          It sounds like you’ve set up the proper external connection.  Maybe it’s the final assignment part that’s missing?
          https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/play-modes/perform.html#map-to-external-controllers
          That section (and the one below it) might get you there.  I guess it’s possible that the ‘presets’ / Programs you’re targeting on your List aren’t set Tempo = ON.  It can get a little confusing at first try, as you can control at Program or Preset level – with or without Tempo ON – depending on which Performance Parameter you are binding the Aux Switch to.
