Tap tempo
Home Forums Products Rackmount Tap tempo
Viewing 4 reply threads
    • #105947
      romadream
      Hi guys!!I've an Eventide Eclipse and i'd like to know if it's possible to connect a normal foot pedal to my Eventide to control the tap tempo during live situations 'cause i don't find the answer in the manual.
      Thank you very much for everything!
    • #118076
      IDeangelis
       Hi
      please specify (always) the operative system version of your Eventide. This is very important to determine its capabilities and related configurations.
      Thanks
      I
    • #118077
      romadream
      My software version is 3.00
      Thanx!
    • #129185
      IDeangelis
       Ok, that's an OLD version. You should install the latest one, V3.53
      A footswitch can be assigned under SETUP > TEMPO > TAP SRC, normally defaulting at INTERNAL; you can choose   FootSwitch 1 or 2.
      Updating to latest version is HIGHLY adviced.
      cheers
      I
    • #129187
      romadream
      Thank you so much man!You're the best!:)
      Hi from Italy!
      M.
