Tap Tempo Displays wrong value after tapping.
Home Forums Products Stompboxes Tap Tempo Displays wrong value after tapping.
Viewing 6 reply threads
    • #107448
      JNPMusic
      I can't figure out why my tempo displays the wrong tempo after I tap it in. Does anyone know what can cause this?
      JP
    • #121139
      Information please:
      What value are you trying to tap in ?
      What value do you get ?
      What pedal ?
      What software ?
      Are you tapping the switch or by MIDI ?
    • #121140
      JNPMusic
      I'm using the timefactor. After I tap in a tempo it will display the wrong tempo, for instance I could do a slow tap and it would display 50bpm but if I tap a fast beat it would display something like 263bpm. I'm using a loop master tap tempo pedal w/polarity but it does the same thing with the one on the unit as well. The tempo plays back in the proper tempo, It's just displaying it incorrectly. Software V3 but it did it with all of them.
    • #132285
      JNPMusic:
      This sounds correct – what are you expecting ?
    • #132288
      JNPMusic
      I just realized it's bps and not ms. Can it display ms instead?
    • #132290
      JNPMusic
      OK I just checked it again to be sure and it's displaying in ms not bps… so it's still displaying the wrong ms tempo.
    • #132292
      It will display mS if tempo is off (green light not flashing).
