Tap tempo (from midi) is registering half the tempo I input. Please help.
Home Forums Products Rackmount Tap tempo (from midi) is registering half the tempo I input. Please help.
    • #108459
      griffenstein
      Quick preface – many of the effects I rely upon are synced with a tap tempo so it matches up with the band/music.  When I tap, say, ~80bpm into my G-Major from ext. midi source, the internal clock reads my tap tempo, i.e., ~80pm.
      I am doing the exact same process with the Eclipse (v4.0) with my Roland FC-300 foot controller.  I assigned the extension of that pedal and I tried with different external midi assignments (ext 1, ext 2, ext 3, etc).  No matter though, because when I tap with the external midi controller at ~80pm, the bpm in the Eclipse will clock at ~40bpm.  This is actually really important to me.  Please help!  Thank you!
      -Ryan
    • #123170
      griffenstein
      Well, I actually figured out why it is registering half the tempo that I input.  My pedal was under the "latching" setting when the Eclipse registers a single beat under the "monetary" setting of the pedal.
      Having said that, is there any way I can set up the eclipse so it can register a beat for a latching pedal instead of a monetary one?
    • #123171
      Sorry – no. A tap is usually expected to be a momentary.
