Tap Tempo From Midi Question
Home Forums Products Rackmount Tap Tempo From Midi Question
    • #105720
      payanr
      Hi Guys :
      I'm a big fan of the ECLIPSE but I'm kind of stock here.
      The idea is to control the tempo from a boss footswitch (thru a GCX Midi Footswitch)
      This is the picture :
      I'm controlling the Eclipse w/ GCX Ground Control (Midi pedalboard) and this pedalboard has a Expression pedal input…I just bougth a BOSS footswitch (Momentary) and connected TO the GCX, configured inside the pedal so he can transmit the tapping to… let's say CC# 011 OK?
      Now, I just want the Eclipse to listen to CC# 011 for the global tempo…easy uh?
      Thanks for your time.
    • #117646
      IDeangelis
       Very easy!
      You can connect the footswitch directly to Eclipse and use it as Tip or Ring for Tap tempo. Or you can study the Eclipse manual which perfectly describes how to control parameters from CC messages.
      First you need to patch an External to CC #11. Then you'll patch that external to tap tempo. Done.
    • #122721
      tonosity
      I'm trying to set the
      global tempo of the Eclipse via MIDI using a momentary MIDI foot
      switch, without much luck. Well, obviously, I'm doing something
      wrong. I've reset the Eclipse to it's factory settings, and then set
      it up with the following configuration:
      Setup–>MIDI–>Channel:
      1
      Setup–>Externals–>Ext#3–>Source:
      MIDI Single
      Setup–>Externals–>Ext#3–>Channel:
      base+0
      Setup–>Externals–>Ext#3–>Cntrl:
      con: 12
      Setup–>Tempo–>Tap
      Src: ext3
      Setup–>Tempo–>Mode:
      Global
      MIDI CC word values sent
      to the Eclipse for a tempo of 100 BPM on channel 1: 012, 100 from the
      MIDI foot switch.
      If anyone can let me know
      the error in my setup, I'd really appreciate it! Thanks very much!
