Tap tempo in Orville..?
Home Forums Products Rackmount Tap tempo in Orville..?
Viewing 3 reply threads
    • #106706
      vibeunit
        Hi there!,
        Is there a way of doing, or making a tempo function in the Orville?
        Would make life SO much easier when adjusting tempo delay presets
        in sessions..  Big Smile
        Thanks in advance!
        Vibeunit
      • #119646
        Hello
        TapTempo in Orville is available from OS 3.002.
        Yours is on an older version, maybe?
        I
      • #119647
        vibeunit
          Thanks for the quick response! , I have OS 3.002 installed, how do you access the
          the tap tempo function,  can you explain..?
          Vibeunit
        • #130762
          Please refer to Orville User Manual V3, page 88, avaiable from the Eventide website:
          http://www.eventide.com/AudioDivision/Support/Harmonizers%20and%20Rack%20Products/Orville.aspx
          this will explain you System Tempo that works with all parameters like T_Dly/T-rate/T_Decay
          all the best
          I
