Tap Tempo Issue
Home Forums Products Stompboxes Tap Tempo Issue
    • #105344
      JNPMusic
      Hello! I noticed that when using the tap tempo it sums my delay into just one delay.
      Lets say I'm using the vintage delay with channel A set to 250 and channel B set to 500 and when I tap in the tempo it sums both to one. Is it possible to have both change accordingly? That is to be off set with the new tempo……..
      John…..
    • #116948
      achaput
       Hi John,
      The way to do something like this would be to turn Tempo ON. This is done by pressing the Encoder button once. Then you can set the delays to different rhythmic note values, such as a dotted eighth note and a quarter note, and when you tap tempo, the relationship between the two delays will remain.
      Alan
