tap tempo issue!
Home Forums Products Stompboxes tap tempo issue!
    • #105358
      hi, loving timefactor(serial tf-0090x) to death but have an issue with tap tempo. when the unit barely inputs right tempo, for instance i tap for 120bpm speed and the unit will display 60bpm. it takes a several attempt to get it right. I also have tried external unlatched switch but the same result again. i saw another user had the same issue and i was wondering whether it's a faulty unit or it is a generic timefactor issue that will be fixed in future update? any help would be appreciated. regards
    • #117002
         The time factor averages the tapped value over  a number of taps, so you will have to hit the switch 4 or more times to get a result.
         Does this explain the problem, or is it something else ?
