tap tempo with midi controller(zoom 8080)
Home Forums Products Rackmount tap tempo with midi controller(zoom 8080)
    • #106010
      stratocasius
      hello guys
      I've been able to setup the eclipse to change Eclipse programs via my Zoom 8080, my problem is, how can i set it up to "tap" tempo using the Zoom?
      Using version 3.51
      thanks guys
    • #118174
      IDeangelis
       Hi
      I don't know how your Zoom works…but regarding Eclipse, TapTempo can be controlled via MIDI CC messages or footswitches connected to Pedal 1/2 inputs, or MIDI Clock.
      To patch any source to TapTempo go to SETUP > TEMPO > TAP SRC and set it to Foot Sw1 or 2 if you intend to use any of them or to any Exeternal #, avoiding #1 which is patched to Input Level (Pedal 1) by default. Once you hace choosen an External #, go to SETUP > EXTERNAL > EXT# x (x=the number you have choosen in the previos stage). Here you can select the MIDI CC message sent by your controller to Eclipse to remote Tap Tempo.
      have fun
      I
