Temp Active for Aux Switch
Home Forums Products Stompboxes Temp Active for Aux Switch
    • #111857
      HellenButterlips
      I just recieved my first Eventide product in the mail – the brilliant TimeFactor. So far, I'm McLoving it. I've been able to set it up to work with my programmable looper via MIDI, and the process was much simpler than I anticipated. I'd now like to setup an Aux switch to work as a temporary active feed. I've been able to set it up as a duplicate Active/Bypass switch, but I'd like it to operate as a true momentary switch where it is only Active when the switch is depressed. There are some riffs/melodies where I would like to only send particular notes through the delay. Is it possible to program the Aux switch in such a way?
    • #126552
      You could try using it to control the MIX knob. See UM.
    • #126558
      HellenButterlips
      I thought about that, but then I'd lose the tails.
