Tempo – both MIDI and external tap tempo switch?
Home Forums Products Stompboxes Tempo – both MIDI and external tap tempo switch?
    • #189455
      Stratmaster
        I´m using an external tap tempo switch into my Morningstar MC6mk2 to set tempo for the H90 via MIDI and in the Systen/General setting I have the Temop set for Source Midi Clock. I would like to have an additional tap tempo switch connected to the H90 via the External Ctrl jack but is it possible to have both MIDI and an external switch setting tap tempo?
      • #189464
          You may use Tempo Sync for the preset to sync to the H90’s Tempo (or MIDI clock).
          If Tempo Sync is OFF, you can use the “Tap” perform parameter to tap the tempo in for your preset, while not following the H90’s tempo/MIDI clock.
          This is explained in the section of the user manual below, but let me know if you need further explanation or help setting this up:
          https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/play-modes/perform.html#tap-tempo
