Home › Forums › Products › Stompboxes › Tempo Off parameter via midi?
- This topic has 5 replies, 3 voices, and was last updated 3 years, 1 month ago by
oortone.
August 24, 2022 at 4:09 pm #165143
In many algorithms there’s a “button”: Tempo on/off in the GUI of the editor.
Is this not controllable via midi cc like the other GUI parameters?
I know there’s a key combination on the actual H9, but I would like midi. Not doable?
August 25, 2022 at 3:57 pm #165147
Not MIDI CC/PC, but thru special MIDI SysEx System Variables it looks like this is possible…
Here’s the DISCLAIMER
A large amount of information is stored in the form of system variable. For example, most of the information to be found under System Mode is stored as system variables.
In addition, various control states are also indicated by system variables, such as bypass, MIDIclock present, etc. Because these system variables are so all-embracing, they should be changed with care and some forethought. The user has the consolation that any damage done can always be undone by “Restoring Factory System Settings,” as described in the User Manual (UM).
From the above, it will be clear that the following is intended for expert users only, and neophytes or MIDIots should read no further. Little further support is available, and these should be USED ENTIRELY at your own RISK. -
August 25, 2022 at 4:12 pm #165148
This is my best guess without testing… it should be readable/writable under sysex doc “system variable 7”
sp_tap_syn (x)
x=0 (tempo off)
x=1 (tempo on) -
August 26, 2022 at 4:16 am #165155
OK, thanks a lot. I’m not unfamiliar with sysex although I know it’s time consuming to set up. I’ll save this for a rainy day. 🙂
August 28, 2022 at 6:22 pm #165174
just make 2 identical presets, only one with tempo off, and use PC to switch?
August 29, 2022 at 2:55 pm #165185
Yes, thanks. But I was planning to make a remote control (using a midi controller) when editing presets so that would not be very practical. But it’s no big deal. I’m just a bit puzzled since all other parameters visible are accessible by midi cc.
