TF Bypass Mode
Home Forums Products Stompboxes TF Bypass Mode
    • #113015
      All,
      I’ve got a TF running in a parallel FX loop on my amp and am now midi controlling preset selection and active/bypass status of the unit. I’m looking for a little guidence with respect to bypass mode – ideally I’d like to use DSP + FX in order for FX trails to continue on preset change however do I need to be concerned about phase issues when using this mode and the unit is in bypass? The unit is set to Killdry so does that mean that in bypass mode no signal passed through the unit or does the untreated signal still feed through?
      Appreciate your input.
      Regards,
      Simon
    • #141493
        I'll look into this and get back to you in a few days.
        But – I'm puzzled – why do you not just try it and see if it does what you want ?
        That would be less work than sending a question to this forum.
