TF Looper Varispeed – bug or normal?
Home Forums Products Stompboxes TF Looper Varispeed – bug or normal?
    • #106159
      I can't change the Varispeed Resolution setting when Looper state is Empty. I can change the display setting, but the loop I record defaults either to the the preset setting (when the preset is Looper) or to Octave resolution (when the Looper is not saved as a preset). Nor can I save a different Resolution to a preset when the Looper is Empty.
      Is this a quirk or a bug? Its a problem because I don't want to use up more presets for each Varispeed Resolution.
      But maybe there's a good reason that i'm not seeing?
    • #118491
      achaput
        Did you make sure that the Loop Start (Dly A knob) and Loop Length (Dly B knob) are not restricting the amount of record time?
