TF/MF actual mA requirements?
Home Forums Products Stompboxes TF/MF actual mA requirements?
Viewing 3 reply threads
    • #105286
      Crysstalized
        I have a Timefactor and will be adding a Modfactor to my pedalboard when they come out. Unfortunately, the TF style wall wart is just too big to have two of them on my board. What is the actual mA requirements for the pedals? I am looking to be running it off of a Voodoo Lab Pedal Power AC, which would provide me 1 jack for 9v 1200mA, but the other would need to be used for another 12v pedal (there are two 9v *or* 12v outputs at high current available), leaving me several 9v 600mA outputs to use for a TF/MF. Thanks!
      • #116826
         The User Manual you have says:
        Specifications
        Power Supply
        9 VDC, 1200 ma, Tip hot (+)
         Idea
      • #116830
        Crysstalized
          I realize that is what the manual says, but I was looking for the actual usage as manufacturers usually provide adaptors that exceed the requirement of the pedal. Would you be able to get that info?
        • #116832
           Don't use anything below the specs! These units have a lot of power and require a feed at specs statement.
          I
